Question about Maytag Atlantis MDG8400AW Gas Dryer
Hi, it seems the moister sensor is broken on my dryer. When it's set to autodry it just keeps drying for up to 24 hours.
    President:
  • 1,554 Answers
You are correct, there's a problem with the moisture sensor if the dryer is heating but keeps drying when set to Auto-Dry. Either the sensor bars are shorted/touching each other or it is covered with thin film. Disconnect power then check the sensor bars for short circuit and clean thoroughly. Please indicate the exact model number of the dryer should you need further help.
Posted on Nov 12, 2010
Tumble stops cycle when drying. its starts to dry but stops after a short while leaving the clothes still wet,after restarting several times the cothes dry
use multi meter and check moister sensor, cycling and hi limit thermostat lastly if it runs about 25 minutes then stops and need about an hour b4 it will start agin? u have bad motor windings
Nov 08, 2011 | Bosch Axxis WTL 5400 Dryer
Hi, I have problems with SAMSUNG Dryer Model # DV665JW/XAC. It does not dry clothes at all. Could u please help!!! cheers, lucina
you probably have a broken wire in the heating element. located on the back of machine, top right corner, behind panel.
remove the two screws
Sep 01, 2010 | Samsung Dryers
Dryer seems to take longer to dry things.
Remove the exhaust vents tubing and clean out thoroughly good. Any lint build up will make the moister sensor to keep the heat in check. If cleaned and still does not heat very well replace that sensor. If no heat is present replace the spark ignitor instead
Jun 19, 2010 | Dryers
Dryer just stopped drying. Seems to be no heat being produced .
Gas or electric? If gas clean the VENT tubing completely out. Any lint build up will cause the moister sensor the keep the heat in check
Jun 15, 2010 | Dryers
No hot air
clean all vent tubing and try again
the moister sensor will keep the burner off if lint is build up inside the exhaust duckwork
May 09, 2010 | Whirlpool LER5634L Electric Dryer
Running but taling a very long time to dry
The moister sensor is keep the burner to ignite to dry your clothes. First check the entire exhaust vent tubing for a blokage. The sensor will detect this and keep the burner off for fire hazzards. If very clear inside the tubing and inside the dryer as well the moister sensor is faulty instead providing you hear the spark ignitor making the clicking noise to ignote the burner when first started up
May 08, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Drier Model DE7800, Serial No 102094 87 Timer does not work when set to autodry (either regular or permenant press. Problem?
when on autodry, timer is not used, but a moisture sensor in the machine monitors the moisture lever in the clothes and shuts off machine when dry. no problem.
Sep 04, 2009 | Dryers
More dry/less dry setting on atlantis dryer
The more dry less dry settings are basically how much heat you want to use. This is the sensor drying. There is a moister sensor in the dryer that senses the moister on the clothing. When it senses no more moister it will shut off and tell you your clothes are done. The trick with this is that you want to make sure you don't mix your heavy clothing with your light stuff. A t-shirt will dry much faster then jeans and it will sense that the shirt is dry and shut off. I put mine on about the second or third line on the more dry setting and my clothes come out fine. If you are mixing your clothing just put it around the third line. It all really depends on what is being dried. If it's heavy set it for more, if it's socks and such set it lower. Let me know if you have any other questions and let me know if this was helpful for you. Good luck.
Jan 22, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
Sep 15, 2008 | Dryers
Whirlpool Dryer GEQ9858J autodry problem
Are you running the dryer in a relatively humid environment?
Sep 07, 2007 | Whirlpool GEQ9858J Dryer
Maytag Atlantis MDG8400AW Gas Dryer Logo
220 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
