WHEN UNIT CALLS FOR BLOWER TO COME ON, YOU CAN HEAR BLOWER MOTOR RELAY CLICK LOUDLY ON BOARD BUT DOES NOT COME ON...... CHECK LEADS COMING OFF BOARD TO BLWR MOTOR AND WAS GETTING NO POWER..... IM THINKING THE BOARD IS BAD( OR RELAY ON BOARD) AND THIS IS HAPPENING IN COOL, HEAT, AND FAN ONLY MODE
  • joshua_wilki Nov 11, 2010
    YES BUT THE RELAY IS HARD WIRED IN ON THE CIRCUIT BOARD
  • 2,299 Answers
I believe that you are exactly right. If you would like to know the part number and cost of the board, just give me the brand of the unit and the model number. I will find the cheapest place to get the board.
Posted on Nov 11, 2010
  • 4,059 Answers
Hopefully the problem is with the relay.The relay is a small usually black cube shaped electrical part plugged into the motor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the motor causing the problem.
Cool air from home vents with central AC outdoor unit fan will not turn on. Inside home really loud when on!!
its look like blower problem , 1st check blower speed controller, check blower motor , check its ball bearing etc , its does not have any link to external unit .
Jun 15, 2014 | Goodman Heating & Cooling
Our house is hot! The ac unit outside comes on and freezes up, and the blower is not coming on. We have had the inside thermostat changed and freon added and now a new capasitor but no luck.....HLEp
Man, it sounds like you have a heat pump with a bad defrost board or reversing valve. I assume your description of the unit outside freezing up is the condenser and the blower you refer to is the condenser fan motor. Or, is it the big copper line to the compressor that is freezing up? If so, have someone stand by the inside blower and listen for a click as you move the thermostat fan switch from auto to on a couple of times., Make sure at the time you are testing that the thermostat is in the off position. Those 2 switches operate separately. If you hear those clicks during the test you probably have a bad blower motor if there are are no clicks you may have a bad blower relay or board. Hope this helps good luck.
Aug 17, 2013 | Carrier XHB123D X/Y Series Heat/Cool Air...
Bryant furance cat.# 333BAV048080, with A/C cooling selected, blower motor during high speed operation stopped running, but the outside A/C unit was still running.Check that the motor is free wheeeling....
Hello, sincebthe motor will not run in heating and cooling the first thing to do is check the capacitor, set your meter to ohms and disscharge the capacitor with a screwdriver, if the capacitor is good the meters numbers should ramp up and down, if not the capacitor is bad. To check the motor turn off power to the unit and take you meter and measure from the common wire to each other wire coming from the motor, you should have resistance,if not the motor is bad and must be repalaced. To check the board place one meter lead on the cool/high speed motor tap and the other lead to ground, if therebis no power on a call for cooling the board is bad.
Jul 11, 2011 | Heating & Cooling
My ruud sillouette a/c system inside blower does not run even on fan only. The outside unit works. The low voltage board is getting the 38vac power across the red and ground. The blower motor will work...
You have an meter check for power between R and G if there is no power, than the stat is calling for the fan and the fan relay on the board should be closed. Use your meter and with one lead to ground follow the motor lead, back until you find where it is stopped, that would be the problem.
Jul 02, 2011 | Heating & Cooling
Blower motor relay switch problem I have a weather maker 8000, everything works fine but blower motor wont come on, just a click, and after it does not come on the the furnace stops, is this a blower...
Hello, if this is a electronic ignition Furnace the relay is located on the intergrated control board. The only problem is that you cannot replace only the relay on those boards, the whole board must be replaced.
Mar 07, 2011 | Heating & Cooling
Compressor runs, but blower won't. System off, fan switch on, blower won't run. Short red and green on back of thermostat starts compressor. Whatever, blower won't run. Can hear relay click on PCB, but...
dear sir
check pcb board or that cable which one caring electricity till blower check auxiliary relay who is responsible to make active supply for blower it can be faulty you can check by a electrical teaster when your hear sound of active of relay then you check blower electric connection there is electricity or not if there is electricity and blower won,t run it,s mean blower motor /capacitor is faulty if there is no supply for motor blower then it,s mean PCB bord is faulty and it,s need to repair replace.it,s up to you to repair by your self or take help to a technician .
thank you
hope answer the question
please vote!
Oct 01, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
1997 Isuzu Rodeo V6 4X4. I have only owned this vehicle for 3wks and the fan/ac wont blow at all out the vents. The blue light comes on when i push the ac button but that is all it does. I don't know which...
C-19 Blower motor fuse 25A located in cabin fuse box. Left hand footwell on LHD vehicles, right hand dashboard on RHD vehicles.
Start by checking blower relay B-36 in the engine compartment fuse and relay box. Remove the relay. Jumper directly from battery to pins 85 and 86. (also see here: http://www.fixya.com/cars/r5544622-wire_relay if you dont know about relays) The relay should click Now measure across pins 30 and 87. Measurement should be 0 ohm.
Remove the blower motor(3 screws on the bottom of the unit under the passenger side dash) and connect jumper leads from the battery directly to the blower motor to see that it operates.
The blower motor resister is mounted on the ducting between the motor housing and the heating unit. Remove to test
Measure :
  • pin 1-2 : 2.4 ohm
  • pin 2-4 : 0.9 ohm
  • pin 2-6 : 0.28 ohm
  • pin 2-3 : 0 ohm
Aug 21, 2010 | 1997 Isuzu Rodeo
I have a coleman evcon, and once in a while the smaller "blower motor" will come on, the "pilot" ( i think) will glow, and i can hear a relay click on and off, but the funace will not light, you can hear...
You need to change board and ignitor assembly. Go to hvac parts.com with model and serial number to get parts Power surges damage the boards all the time. Rus Let me know what happens
Dec 03, 2009 | Heating & Cooling
Heater/defrost/ac fan not coming on park avenue...can hear click
Check the connector to the blower motor. Turn it on and wiggle the connector.
Jan 10, 2009 | 1989 Buick LeSabre
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
