Question about Savin Office Equipment & Supplies
Savin 8035/8035g PCL6 - We have an error with JAM 003 and we have tried to find the jam but we have not been successful. I am not sure what needs to be done.
  • 17,970 Answers
There should be paper inside or may be when you removed jamed paper not proper way some pice of paper struck in the sensor thats why paper jamed lit up; clear the whole paper path it will solve problem if not there is any path sensor not working good. Just clean the path sensors.
Keep us updated.
Posted on Nov 11, 2010
How do I reset fuser code on savin 2513 with a sc544. I have checked the fuser lamp thermal fuses etc. From the power source in cable unplugged. The thermistor reads about 390 k ohms at room temp. It had a...
When reading the thermistor, grasp the sensing part between thumb and forefinger, if reading drops quickly the thermistor is probably goid, if so , unfortunately you may need a power supply board
Feb 12, 2015 | Savin Office Equipment & Supplies
Paper jam reset
make sure all access covers are closed...if they are then there is still paper somewhere inside the machine
Jan 19, 2014 | Savin Office Equipment & Supplies
Savin 8025e jam won't reset
Sometimes it just wants you to open a certain cover. open and close them all.
Mar 09, 2012 | Savin Office Equipment & Supplies
Savin c2824 wont print pdf files
If its showing drivers for a different machine then the first step should always be to completely remove and reinstall the drivers for the correct unit.
Mar 02, 2012 | Savin Office Equipment & Supplies
I have a Savin 2015 DP and it says that there is a paper jam. there is not, i have already cleared it and the light wont go off, therefore, my machine is out of service. any advice?
There is a sensor lever that gets stuck on these models. The sensor is located just below the drum . (might be on its own door cant remember) it should move freely if it is stuck in the jam position the jam wont clear.
If you still nee help reply and I will try and assist futher.
Good Luck
Apr 09, 2010 | Savin 9935DP Laser Printer
Says jam 2 check inside but there is no paper inside
make sure all paper is removed from paper cassettes. check all doors covers it is telling you to check. check fuser. you may have a swithc broken, bad or knocked out of position.
Oct 19, 2009 | Savin Office Equipment & Supplies
Savin 4035Esp - Functional Problem Message with Code SC863
Hello sir; SC 863 means your copier hard drive not good,you need to replace one. can't repair.
May 15, 2009 | Ricoh Office Equipment & Supplies
How to Clear carriage jam on HP PSC 1610 Printer? No obvious paper jam visible.
Dear it's the carriage jam error. so it mean that your carriage is jam not paper. so open the printer where you insert the cartridge. check whether it is jam or what . cartridge carrier is jam kindly turn off the printer and try to move the cartridge head by hand very gently and if seems to be stuck than check for anything which abort him to move freely so than might be anything like dust or else. when you get success in moving the head put some machine lubricant on the rod on which head moves and check it ok.
Dec 04, 2008 | HP Office Equipment & Supplies
Fake paper jam
the roler, which picks the paper need to clean, try it
Oct 28, 2008 | Samsung ML 1610 Laser Printer
Savin 2513 Jam
Many printers have a paper jam alert.But you need to remove the jam the correct way. You can't just pull the paper from the machine. If you have the manual--look up the proper procedure to un jam the paper. The machine can detect if the paper is stuck and it will not know it is fixed if the proper method isn't used. The system has a mechanism that loosens the rollers to allow the paper to be removed without damaging the wheels.
Oct 12, 2008 | Office Equipment & Supplies
119 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
