Question about Philips 42PFL5332D 42 in. LCD Television
Philips cineos 37 PFL 9632 D / 10 Don´t start up. No picture, no sound. Standby lamp lights all the time.
SOURCE: Red light flashing
ctf1800,
I would love to have that service manual. My Philips 37PF7320A died 4 days ago with the typical 1-4 blinking lights. The fuses are fine but I found a 100 ohm 1/4 w resistor that was dead and replaced it, but no change. Now I have looked closer at the "dead" resistor and after the brown-black-brown and there is a poorly applied green band before the gold one, so I'm not sure what I have. I guess I need to get a high resistance tester off eBay.
jcarthur@verizon.net
Posted on Jan 31, 2008
  • 90 Answers
SOURCE: Red flashing light. Light flashes red 8 times pauses & repeats
power supply board going bad
Posted on Mar 03, 2009
  • 3 Answers
SOURCE: RED LIGHT BLINKS SEVEN TIMES
The most likely problem are two failed capacitors on the main board in the center of the TV The failed parts are easy to identify as the top of the cap will no longer be flat but will have bulged up. DO NOT attempt to remove the back of the TV unless you know what you are doing.
soldering on a circuit board will be required to fix this problem.
Posted on Aug 10, 2009
phil_frye
  • 295 Answers
SOURCE: My 42PF5321D/37 will not turn on, just flashes a
Most likely a power supply problem. If it's covered under the warranty take it in right away and have them fix it. If not a good Philip's service shop can fix it. They may have a flat fee repair charge?
Blessings,
A/V Guy
Posted on Nov 19, 2009
freetek
  • 5568 Answers
SOURCE: Philips lcd tv 42pfl5432d/37 no picture
If you feel you have isolated the problem board, you might check here for a replacement:
Jimmy's Parts
Posted on Nov 22, 2009
Philips pfl6007 power blinks 2 times
If power supply regulator board has any fault, this kind of blinks will occur to Philips brand TVs. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter". Blinking codes and details to Philips PFL series TVs are described in detail.
Apr 14, 2013 | Televison & Video
Power light glows orange for a minute then shuts down without ever having a picture or sound. I have replaced the lamp and clean the filters. This is a Philips Cineos Lcos 62 inch.
Watch at turn on to see if lamp fires up for even a second or two--if not either a ballast or the control that turns it on has detected another issue and is not allowing the lamp to come on.
Jun 07, 2012 | Televison & Video
My Philips tv 60PL9200-37 has sound,but NO picture. The front blue light flashes 6 times slow,pause,5 times fast. Once in a blue moon picture and sound are ok. What could be wrong?
When your television actually flashes the front blue light, it is passing a message that there is a problem inside the unit. There are 2 things you should check but my best bet is that it is the t-con board of the television that is bad. The other component you can check is the lamp, but if the lamp is faulty you will not be getting sound therefore the problem is from the t-con board.
It is located by the middle of the main panel of the television, once you get it replaced, the television will be in good shape.
Take care and good luck
Jan 02, 2011 | Philips 60PL9200D Projection Televisions
Philips Cineos flat screen TV vith Ambilight 37PF9631D/10, went in standby and blinking red power led diode once-two times in cicles.
Sounds like an issue with the power supply board. We will have to go component by component and you will need to knowledge of using a multimeter. If you are skilled enough to do this then let me know and I will help you troubleshoot it.
Mar 19, 2010 | Philips 37PF9631D 37 in. LCD HDTV
Philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Dec 15, 2009 | Philips 50PFP5332D 50 in. Plasma...
Standby light flashes 50 times then lamp light flashes, no picture or sound
standby light flashes 7 times then lamp light flashes, no picture or sound
Nov 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Do I need a new lamp?
99% chance your lamp needs to be replaced. Prices are in $120 -180 range. Search for "50PL9126D/37 lamp". they are available with or Without cage. Version with cage is preferred because it will be easier to install it.
Oct 08, 2009 | Philips Televison & Video
Subwoofer light
The subwoofer light stays red regardless of the state it is in despite it being labled a standby light. (It's more of a power on light) It seems that philips missed the point of what a standby light is.
I would have expected the light to have changed colour to indicate that the unit was operational and perhaps syncing with the receiver box.
May 17, 2008 | Philips Cineos HTS9800W System
Philips 42PFL5332D 42 in. LCD Television Logo
421 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
