Question about Sub-Zero 700TCLH Bottom Freezer Refrigerator
What does error code 24 mean? - Sub-Zero 700TCLH Bottom Freezer Refrigerator
  • Sub-Zero Master
  • 1,344 Answers
This error codemeans defrost under heat. The thing about it is chances are there really is no problem. There is a wire that runs from the drefrost thermostat in the freezer to the conrol heading. This wire is split into three sections, and sometimes signal is lost, or degraded, going back to the control so the machine thinks that the defrost heaters are not working properly. The only real way to fix this is to take th freezer wall out, find the wire which I think is blue, and cut the junctions and use wire nuts to tie them together. There are two junctions in the freezer , and one near the control board, but if you can live with seeing the 24 code and know there is no problem, I wouldn't worry to much. Most of te time calling a tech will only get you smeone trying to sell you a part you don't need. Hope this helped.
Posted on Nov 11, 2010
Magiccard Rio printer is giving error code 24:24
Error code 24:24 means that the sensors need to be replaced. This requires sending the printer back to MagiCard for them to replace the sensors.
Mar 01, 2013 | Magicard Rio Card Printer
Error code 24
2,4 is one of 5 error codes and means:
2blink-then 4 blink---------vertical circuit problem
The set may have a loss of sweep or even Glycol may have leaked from the picture tube above it onto the board in that area.
Vertical circuit is on middle board at front right edge.
Jun 16, 2012 | Mitsubishi WS-55311 55" Rear Projection...
1993 subaru legacy fault code error 2 slow flashes then 4 fast flashes what does this mean ?
it means 24 Code 24 ISC solenoid valve fault, go to any auto parts store and they will tell you the fix for this problem code. auto-zone etc.
Mar 15, 2011 | Subaru Legacy Cars & Trucks
Code F 24 what does it mean The washer dose not allow me to do anything when I push start. All the areas light up and flash with code F 24
The F24 error code indicates a problem with the water temperature sensor. code meanings should be under lower cover, remove panal.
Jul 13, 2010 | Kenmore HE2 Plus Front Load Washer
OBD Error Codes
I get an error code of 052 on the A/C control unit in my 2000 Mercury Grand Marquis. Does anyone know what this error code means?
May 26, 2010 | 2000 Mercury Grand Marquis
What does f-24 mean?
inside the machine should be repairmans instructions. this includes explanations for all the error codes.
you will have to remove the front access panel
May 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
1992 Jaguar XJ6..vcm error codes
code 24 is the ignition amplifier circuit
Sep 08, 2009 | 1992 Jaguar XJ6
Airbag error code 24. What does it mean?
Common fault on FORD
Usually due to a poor connection in the YELLOW PLASTIC CONNECTOR underneath the passenger seat.
Just push it together properly and it should clear the AirBag fault
May 28, 2009 | 2004 Ford Expedition
Code: C 2 ??
C2 error code means, that the drain is clutched.
Removed all dishwasher water with a cup.
Added a gallon of boiled water, waited 10 min and it worked again( so far).
Regards
Sigurd
Jan 28, 2009 | AEG 24 in. Favorit 80800 Free-standing...
Sub-Zero 700TCLH Bottom Freezer Refrigerator Logo
388 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
