Question about HP Photosmart C3180 All-In-One InkJet Printer
Help put me on-line ...
First the HP Photosmart All-in-One gave me an "offline", now and "error" in the Control panel. How do I make it online again? This all started when the USB plug was removed..
If unplugging the USB cord and powering down both the computer and printer didn't work, try removing all the ink cartridges from the printer, power it down again. When you power back up, wait for the message that tells you cartridge error or something about missing or empty cartridges, you'll understand once you try this. Then put the ink cartridges (black and all!) back into the printer, close the cover and let the printer prep itself. this worked for me!
Posted on Jun 21, 2008
    Guru:
  • 1,342 Answers
Turn off the printer and the computer. Plug the usb cable back in. Make sure it is securely plugged in on both ends. Turn the printer back on and restart your computer. It should be back online.
Posted on Jun 17, 2008
How to put printer back online
Try the steps listed here. It is a pretty solid troubleshooting guide for a printer showing as offline.
Sep 05, 2012 | HP Office Equipment & Supplies
HP Photosmart 2610 all-in-one printer keep going offline
You have make changes into you system setting by following mentioned steps, Click Start>Control Panel and then Printers and faxes and right click on your f380 and put it online. I have solved this problem so many time by doing this, it actually works
Sep 28, 2010 | HP Photosmart 2610 All-In-One InkJet...
How can I get this printer back on-line? This printer is offline and will not print.
  1. Click Start ->Control Panel->Printer and faxes
  2. Right click on the printer
  3. Select "use printer online".
Regards
Riztech
Aug 19, 2010 | HP Photosmart C5180 All-In-One InkJet...
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Photosmart 8250 won't print, says computer is off-line
Make sure printer is connected to computer.
Go to Start ,Control Panel ,Printers and make sure it does not say offline.
If it does right click it and select the option online.
If it does not then remove it and reboot the system.
Jul 28, 2009 | HP - HP Photosmart 8250 printer
HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Dec 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Printer D7260 Printer error
i do not have areason for why the printer continuously goes offline but there is a way to put it temporarily back online. Go to printers in the control panel. right click on d7260 and click on use printer online. This only seems to work for one or two docs before you have to repeat the process.
Nov 16, 2008 | HP Photosmart D7260 Printer
Photosmart 2575 printer is offline - won't print
In Vista make sure you are logged in as a administrator whenever you make any changes.
And if not to bring the printer online you will have to right click on the printer icon and right click on Run as administrator> and then try bringing the printer online and checdk if it works.
And you can delete the Microsoft XPS Document writer it is a default printer icon installed if in case you did not have a printer installed you can store them to print later.
Now that you already have a printer you can delete the Microsoft XPS Document writer.
Good Luck
Oct 02, 2008 | HP Photosmart C7180 All-In-One InkJet...
Printer Offline
here are the steps to do:
- click start icon
- goto control panel
- under control panel click printers folder
- then under printers folder there is an icon for photosmart c6100 printer - right click that icon then set as a default printer
- then right click the icon again and select use printer online
- after that you can see you printer has a checkmark and the status is ready.
Jul 12, 2008 | HP Photosmart C6180 All-In-One InkJet...
Good Day,
One thing you can try instead of deleting the doucment writer is to change the default printer. You can do this by right-clicking on the HP printer icon and selecting "set as default" from the drop down box. Also try turning the printer off and back on aswell as restaring the computer if you have'nt already. Did that printer ever work from that computer? How is it wired, by "switcher" do you mean a shared printer through you network(was printer sharing configured properly), or an A-B printer switch. Please clarify
Hope this helps for now
Jul 01, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
166 people viewed this question
Seeker5211
Seeker5211
