Question about GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker Microwave Oven appears to be working normally (light comes on, table turns, sounds normal), but it doesn't cook anything. Might there be an easy fix to this problem?
  • 863 Answers
Unscrew the screws holding the exterior shell to the unit, then lift off. Now unplug the magnetron and take it in the shop to match up the #s so you can get an exact replacement. Now install the new part and you should be re-heating left overs in no time. Make sure you discharge the capacitor before poking around inside or you will shock the hell out of yourself. Unless your sadistic and like that sort of pain, then forget about the last suggestion.
Posted on Nov 11, 2010
Turn table does not work. How do you fix it? I have a GE Spacemaker XL 1800, Model # JVM1842BD. Thank You
i have a ge 1800 model and it cooks fine but after awhile it shuts down and in about a hour it comes back on and ask you to set the clock.....
Jun 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
My microwave doesnt work
If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
Thanks,
micro
pls. rate..
Mar 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Not heating up anything
Tat would be a magnetron problem. The magnetron is what provides the heat
Apr 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Unit does not heat up the lighy works the timer works the turn table works there is no heat
Most likely the magnetron is at fault if everything else appears normal. This is the main part of a microwave & is an expensive part to replace, it might be more economical to buy a new microwave.
Sep 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Our oven would not heat,everything appeared normal lights worked fan worked timer worked tried again on cook 3 closed door and lights went out and we have nothing,I have 120 volts at plug.
Check the voltage at the primary winding of the highvoltage transformer. If it is 120 volt.then controll board part is. Now check the magnetron and related components. If the fuse and the diode are ok replace the magnetron
Jul 14, 2009 | GE Spacemaker JVM1740 Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker making odd noise
We are having the same problem with our XL1400. I suspect it has something to do with the turn table but don't know for sure. We would be willing to disconnect the turn table...anything to stop the noise but don't know how.
Mar 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
good day, try to check your cooking settings. tnx
Jan 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
