Question about Bose Wave Radio
I have a bose wave radio cd. the cd spins but won't start playing.
  • 863 Answers
Install the disc cleaner cleaning kit you bought from Wal-Mart so that the heads are cleaned of dirt and debris. Now try to play a disc. Also, check that the disc is not heavily scratched or got grime on it. You going to have to go have the disc re-surfaced and cleaned so it will play again.
If none of the above work, then you have to call Bose factory service and have them look into it if your within warranty. Otherwise, you gonna have to open this thing up and replace that failing optical drive or check for a loose power cable that connects to the optical drive.
Posted on Nov 11, 2010
Bose wave radio cd won't play cd's
If your CD is not scratched,the optical lens need replacement.
Apr 02, 2013 | Bose Awrc1g Wave Radio Cd Player Only -...
Bose wave awrc-1g cd player spins but does not play.
You have done what i would have suggested, the Bose Wave unit will need to back to Bose for service, and there is a good chance they will need to replace the laser pickup assembly and cost should be considered even thoe it is top of the line.
Apr 02, 2012 | Bose Wave radio/CD remote control -...
I copied some music to a disk with 4 different formats but the bose radio wont play any of them.
The Bose Wave Radio doesn't have a CD player. The Bose Wave Radio/CD does.
It will only play standard music CD's with standard CD Audio on them.
The manual is available at Bose.com.
Mar 15, 2011 | Bose Wave Radio
I have had a boise radio abdcd olayer for some time and know very little about its operations. today i played a cd and left the house and expected it to stop as it usually does. however, it keeps on...
With the typos and all it's just a guess, but I'll assume you mean the Bose Wave radio.
I suspect the CD Mode button has been pushed so that the mode is set to REPEAT.
The manual for the Bose Wave Radio / CD is here:
http://www.retrevo.com/support/Bose-Wave-Radio%2FCD-Radios-manual/id/19079bh132/t/2/
Jan 11, 2011 | Bose Wave Radio
Why does the CD function on my Bose Wave Radio/CD sometimes not work even though the CD is spinning?
Hi, when the lens of the CD player is weak, it can keep on spinning and not play. what you will need to do is to get a lens cleaner and clean the lens(instructions are on the lens cleaner.
If after cleaning and it still did not work, that means the lens is to weak to perform well. It will need to be changed to a new lens.
Take care.
May 27, 2010 | Bose Wave Radio
CD does not engage to play/ on/off button does not work on radio
I hope it is still under warranty and can be replaced, Bose products are littered with problems.
Pool loading of the CD can be a simple lens cleaning or a defective laser/transport.
First step is to unplug for 10 minutes then replug.
Failing that find the nearest service centre.
Hope this helps!
Cheers,
Jan 22, 2010 | Bose Wave Radio
I have a bose wave radio and cd player the cd
you sure have a problem with your cd pick up unit or servo drive,for that must bring it to your local repair shop
as for the poor recepcion olease try a better antena
Dec 18, 2009 | Bose Wave Radio
Cd does not play
Does the radio work? If not, make sure the volume is up. If so, the speakers are not blown. Return your product.
Oct 15, 2009 | Bose & Wave& Music System
Recorded audio CD will not play
Most likely the recorded format is wrong and that is the cause.
May 05, 2017 | Bose Wave Radio
Bose Wave Radio Logo
213 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
