Question about Black & Decker TRO390 1200 Watts Toaster Oven with Convection Cooking
Does not get hot - Black & Decker TRO390 1200 Watts Toaster Oven with Convection Cooking
The outlet plug gets very, very hot
STOP using the unit immediately. Your plug getting very hot indicates a very poor connection somewhere between your outlet and the oven switch. This is definately a fire hazard so do not use the unit until you have found and fixed the problem. It could also be the outlet itself not making a good connection with the plug. Look at that first. If the plug doesn't fit tight in the outlet, the outlet must be replaced. If the plug is tight, you may have a switch in the oven itself with a poor connection. The oven must be taken apart to find out where the problem lies if your outlet is good. You may find parts that are melted in the oven which would indicate a problem. It's hard to say exactly what the problem is without actually looking inside the oven to see whats going on. Whatever you do, DO NOT use the oven until the problem is fixed or the oven may end up being the least of your problems...
Mar 14, 2014 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Plug is too hot
Please see the answer I posted for the previous question concerning the plug getting hot. DO NOT use your oven until you have fixed the problem. This is a fire hazard....
Mar 13, 2014 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Recall: I bought a Euro Pro Convection/Toaster Oven w/Rotisserie and it caught fire today from a non-food related problem. Is there a recall on this item? There was no food in the oven and it was...
Today I was warming up a baked potato in mine it was on 350for about 20 min when I went to shut it off the nob melted right off the ovenit was so hot I could not shut it off had to unplug it and the top of the ovenwas also very hot, is there any recalls on the MODEL # TO161
Jul 11, 2009 | Toaster Ovens
How do I clean the drip tray and broiler pan?
The drip tray pulls out the back of the oven. It can be soaked in hot soapy water.
Jun 19, 2009 | Cuisinart TOB-165 1500 Watts Toaster Oven...
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
Slow to heat Haier Convection Oven
you are correct . it is the convection . the fan blows the air around and away from the elements ,when that is happening the elements can never get hot enough to glow , as the oven gets hotter and at some point the air is so hot even with it blowing the elements will start to get red ... this is good because todays elements are thin and cheep and melt easy so the fan keeps the heat away from them and the elements last longer ...... if this answer helped please rate it a 3 or 4 stars .this high rate will help keep me in the paid answer department ... thank you
Apr 04, 2009 | Haier RTC1700 1700 Watts Toaster Oven with...
Not hot toaster
you have to ask the guy you got it from if they have a spare part for it dont forget to bring it with you
Nov 04, 2007 | Oster 6297 Toaster Oven with Convection...
Black & Decker TRO390 1200 Watts Toaster Oven with Convection Cooking Logo
23 people viewed this question
Top Black & Decker Toaster Ovens Experts
Dave
Dave
Steve
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
