Question about Packard Bell Computers & Internet
Yellow icons next to my cdrw in device manager and my cdrw does not work how can i fix
  • 4,472 Answers
You can check your cable connections and jumper settings. Has anything been changed on this computer? Most likely the device has failed and will need to be replaced. A DVD-burner now can be picked up for about 30$
Thanks,
lee
Posted on Jun 17, 2008
Compaq presario v2000 wireless card not showing up in device manager
In Device Manager click the tiny arrow beside Network Adapters. This where the wireless card should be listed.
Next, locate the row of small icons just below the View tab at the top of Device Manager window.. Click the icon on the right "Scan for Hardware Changes".
Check again under Network Adapters to see if the wireless card is listed.
Or, check for any yellow exclamation marks in Device Manager list. An item might be named Unknown Device. Double-click it and select Update Driver.
Jul 01, 2014 | Compaq Presario 700 470024-192 Notebook
Bluetooth
Did you check the device manager on your computer? If so, do you see a yellow warning icon next to the Bluetooth driver? You may need to reinstall the drivers.
Go to the Device Manager by right clicking on "Computer" and selecting "manage".
Jun 28, 2013 | Computers & Internet
Dell Inspiron 1525 1526 24x CDRW/DVD Combo Drive cannot read to boot osDell Inspiron 1525 1526 24x CDRW/DVD Combo Drive Module Burner
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it if this fails you might try cleaning the lens it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
Jun 22, 2012 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Repair isatap drivers windows 7
if the drives are working, leave it be. There can be false positives. If the drives are slow or some thing else is odd, try the following solutions. Try to locate the driver needed by going to system devices and looking for a yellow or red icon next to a device. If there are no marked devices, you are probably ok.
Computer icon, properties, select device manager.
Open the properties for that device. details tab, properties and select hardware id. Copy the hardware id information and google it (sample:IDE\CdRomATAPI_iHAS324___B_______________________AL1A____ trimmed and adjusted becomes IDE\Cd Rom ATAPI iHAS324) Find drivers for that hardware if you can and update. You can also just uninstall the device and click rescan from the device manager menu. It should reinstall.
May 12, 2012 | Microsoft Windows 7 Home Premium 64BIT...
Hi!! please! how can I download driver for vf0040
GOTO CONTROL PANEL/ DEVICE MANAGER ... IF YOU SEE THERE WEBCAM YELLOW ICON ? JUST CLICK AND INSTALL AUTOMATIC UPDATE BY ONLINE...
THANK YOU...
May 24, 2011 | Creative Labs WebCam Live!
I have a sansa 8mg clip and usb cable attached to my computer but it will not read it to put songs on it or charge it.... but it works fine on my laptop. what can I do to fix this?
Have you try on another port? If yes, you may try to uninstall your device from Device Manager (Right click on My Computer Icon, find the hardware tab and select device manager).
Follow this step: 1. Attach your device to PC and go to the Device Manager. 2. Find ALL icon with the yellow exclamation mark, right click on it and choose to uninstall. 3. Select YES on ANY warning box. 4. Restart your PC. 5. Now you can attach your device again. 6. You may asked to install driver for your device. Just click yes/next and continue the installation.
Mar 18, 2011 | SanDisk Clip+ MP3 Player
Camera works in all respects BUT does not any longer record motion to hard drive. Can this be fixed?
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Dec 19, 2010 | Linksys Wireless-G Wireless Network...
I have a Samnsung SM-352N DVD CDRW Combo drive. But recently the drivers have got corrupted and I am unable to get back my DVD combo drive to work. In the Device Manager, the DVD CD RW drive is shown with...
control panel admistrive tools,computer management,device manager scroll down cd/dvd drives you should see a yellow question mark? right click to reinstall drivers or right click select enable or properties then general to troubleshoot or region select 4 you might uninstall reboot then reinstall
hope this helps
Oct 02, 2010 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
The CDRW/DVD doesn't work. Light comes on when inserting disc but the goes off. When I click open on the icon it says to "insert disc" This a Philips CDRW/DVD and when I go to the Hardware under...
When you are there in Device Manager use the option to update driver and see if that resolves the issue.
Are you burning a cd or dvd, or just reading disks; and what version windows are you using?
Mar 09, 2010 | Dell Dimension™ 4600C PC Desktop
Pc working good, but no sound
If you're using Windows, go to device manager [right-click My Computer, click Manage, and click Device manager in the Computer Management Console Window], next access your Sound device and make sure it does not have any yellow exclamation [conflicting drivers] or question [missing drivers] marks. If it doesnt and you still dont have sound, you'll need to download and install audio codecs from your Computer, or sound device manufacturers website...good luck
Jul 12, 2009 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
18 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
