Question about Lite On NA115 Motherboard
Liteon na115 mainboard can't display/load bios
Liteon NA115 can't even display bios on screen, i'd tried upgrading ram to pc3200-512mb,1st time plug the ram & try to load windows..it's normaly running ok...after shutdown & tried to switch on again..the bios won't even display and still no beep sound from mb,...upnlug all devices (VGA,MODEM,Reset CMOS etc) still the bios won't apprear/load..any solution for that matter ?Please Help..thank's
  • 58 Answers
1) Try re-seating the RAM
if it's still the same problem, then the power supply maybe bad.
Try with a good PS.
Posted on Jun 17, 2008
My SATA dvdrw drives are recognized, but don't find media.
try doing a firmwear update..make shure you are using dvd ram drivers...then when all else faild try loasding power dvd.. thats what i did and it werkd..
Feb 18, 2010 | Lite On LITEON 8X DVDRW +/- Burner
I intalled model iHAS324-32 Y to replace iHDS 11807-4 and vista wont run with it. Tells me to uninstall it and contact manufacturer. I uninstalled it and system works fine again without the disc drive.
Is your vista a 64 bit OS? If so this dvd-writer is compatible with 32 bit OS. You may need to upgrade the firmware for it. Maybe this link can help LiteOn firmware search.
I've upgraded firmware for a dvd writer already with no bad consequences but I have crashed one of my motherboards trying to do the same. So if you're not comfortable doing it, get the people you bought it from or some techie to do it for you. Hope this helps
Dec 22, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
Acer aspire one doesn't see liteon ez-dub
Linux operating systems may not support Liteon EZ-Dub External DVD Drive. Check on the Linux forums.
Jul 31, 2009 | Computers & Internet
It wont play any dvd disc
You should be install CyberLink PowerDVD Player and than try to play it.
Jul 23, 2009 | Lite On DVD+/-RW LITEON SOHW-1673S BGE %...
Write error message with liteon dvd writer..
I had the same issue with a liteon DVD drive I had. It worked fine and then one day it couldn't write to a DVD if I paid it to. I troubleshooted it for a few days, installed all the latest updates and patches and still nothing. From what I could tell, it baiscally died. So fortunately Liteons are relatively cheap so I just went out and got another LiteOn and it worked just fine. I would consider purchasing a new Drive.
May 04, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
LITEON LVW 5001 doesnt recognize DVD's
Laser either dirty or starting to go.Try cleaning laser with commerical disc cleaner,put a drop of rubbing alcohol on brushing.Laser can be cleaned manually with a Q tip dipped in rubbing alcohol but this requires opening burner.If you do this MAKE CERTAIN ELECTRICAL PLUG IS PULLED,lasers cause nasty burns.
Some times the problem is just the brand of disc,some brands don''t work in Liteon's.
If laser is going the burner can be replaced.Most of the Liteon 5001's used Liteon 401s burners,411s or 451s dvd burners all will work.The dvd burners mount from the bottom PC burners mount from the side so they would have to be adapted,many PC burners won't work in these older liteons some freeze up the second you hit fast forward.
Jan 18, 2009 | Lite On LITEON 8X DVDRW +/- Burner
Not recognized
Go into your BIOS and see if you can get it to autodetect the drive. You should be able to this but I can't tell you how to because all BIOS setups are different.
Then save your BIOS and reboot.
The drive should then be recognised as the right thing.
Hope this helps
Mowcius
May 16, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
Won't Recognize Blank Maxell DVD+R Disks that I Try to Burn!
sounds like your loose 4 prong may have shorted the burner drive on a power on- it may just be that simple- it died...
Jan 15, 2008 | Lite On Lite-On LH-20A1L-06 SuperAllwrite...
LiteOn NA115 continued
all you can do in this situation is to very carefully short out the pins with a screwdriver to discover which is which.
Sep 04, 2006 | Lite On NA115 Motherboard
Liteon na115
Hello vbrad511, We searched everywhere, and could not find any manual. You will also need drivers for the chipset. The best we could do is this link http://www.liteon.com/prod/getService.do?xml_id=4_6&xml_id=4_6 which you can email Lite-On and get the information or links emailed to you. Sorry that we were not more helpful. Please let us know how it goes for you. Best regards, nightdiver
Aug 26, 2006 | Lite On NA115 Motherboard
Lite On NA115 Motherboard Logo
445 people viewed this question
Top Lite On Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Paul King
Paul King
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
