Question about Karcher Pressure Washer 1800 PSI 15 GPM Model K348M
Water is leaking from the front seals,of a model 330m,cant find a parts diagram to describe info on seals so i can order.
    Scholar:
  • 100 Answers
See this link
Look to the bottom of the page and click on your model, let me know what parts you need, I usually have them in stock, justin@wmpcs.com
Posted on Nov 11, 2010
I am a novice. How do you replace the outer seal on the main large drive wheel, please
what maker of machine and model
there is a lot to undo to get it right
on a front loader I cant find a step by step
how to diy for a front seal renewal
watch this youtube if not clear for you ..its an LG front loader
ring a washing machine repairer
Washer Leaking Water LG Front Load Washer Door Boot Seal Replacement part...
Sep 22, 2016 | Washing Machines
I have a fuel leak coming from under a "hat looking device" about 1 inch in diameter that is connected to the top of fuel rail. This is a 2.4L DOHC returnless fuel system. I don't believe this is a
This part you describe is the fuel pressure regulator. If your car is working well, and you have a leak hear , you may only need a seal or gasket. GOOD LUCK FRIEND.
Nov 23, 2014 | Cars & Trucks
How to replace seal of ge top load washer
You have asked a number of questions. How old is the Washer?
Based on your questions, it may be time to replace. No I am not a
GE Rep. Parts can be ordered online. Google Appliance parts. They may be able to help with "how to's". If newer machine, still warranty? If so check with GE. Otherwise, if the tub isn't being over filled and spin out doesn't send water outside the outer tub which could explain the dripping. Verify gasket leak by leaving water in tub and measure height of water very carefully let stand several days and remeasure.
Remove top should be springs on the front. Push in, to release, tip-up top. Tub must be removed. Remove the agitator by removing the top plastic, should reveal top nut holding down the agitator. You will see a number of nuts holding the agitator tower to reveal gasket. There may be rusting and pin holes causing the leak. I would check this before attempting gasket. I had a similar issue, used JB Weld epoxy about 5 year ago, still not leaking. Possibly the agitator tower has a seal leaking at top. If so that is in transmission and should be replaced as well as the bottom gasket. It may be $200 part.
Due to all the trouble, I replaced it to prevent future failure. You may find a lightly used replacement washer for about that price.
Nov 18, 2014 | GE Washing Machines
My GE front load washer leaks during the fill cycle from between the soap dispenser drawer and the cabinet.Any Ideas
Find the whole model number of the machine and try the Sears PartsDirect section, paste the model number into the search window to see if there is an illustrated parts breakdown for that model.
This may help in locating possible leak sources:
http://www.searspartsdirect.com/partsdirect/
They have many thousands of diagrams from all different brands.
Sep 04, 2014 | Washing Machines
How to find and repair oil leaks in front of motor?
Ok ralph first off clean motor with engine brite found at any auto parts stores
next recommendation add oil base dye to motor oil allow to run for 30 min to circulate dye useing a uv lamp or black light and inspect front cover most cases the front seal is themost likely source of leaks due to contant revolutions on front main seal
in order to repar suspected seal total dissasembly of timing cover will have to be removed in some models the front main bearing journal will have to be removed as well.
upon removal of timing coverbinspect front mail seal race / face for burnishing of the crank seal face. Dirt an debri cut into the crank
you will have to order the front seal repair kit
consists of front seal and stainless steel wear ring wich is glued in with epoxcy
reassemble front timing cover gaskets an sealer may be needed once all the parts are reassembled run for 15 m7n an check for leaks
its also possible that the oil pan gasket could be leaking as well
install dye to find leak is the best course of action first
Jun 22, 2014 | 2003 Chevrolet Impala
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
I have a Maytag MDB9100AWB. During wash and rinse it leaks on the right side (as I am facing it). Cannot figure out where it is coming from. The seal on the tub seems(?) okay. Did not find a seal...
The symptoms you describe, STILL sounds like it could be caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps. I personally own a Maytag such as yours and experienced the same problem. It turned out to be a tub seal that was too compressed to seal properly.
The following link explains some of the common causes of dishwasher leaks and what you can do to prevent them:
http://www.fixya.com/support/r3555822-my_dishwasher_leaks
If the model number is correct, the part number for a replacement gasket is 902894.
Replacement part (if required) can be purchased at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and have great service. Prices vary between them, so shop and compare. The first three sites I have listed include helpful exploded view parts illustrations to assist you in locating and properly identifying any parts you may need.
This is a very simple repair. If you have questions, or require additional assistance, please post back and let me know. hope this helps you.
NOTE: There is NO seal along the bottom on this model dishwasher. That is why proper loading is also important. Water can be diverted over the front edge of the tub basin and cause drips and leaks if loaded improperly.
Jun 27, 2010 | Maytag MDB9100A Dishwasher
Kawasaki KX250F 2006 model coolent leak
There are two seals on the impeller pump. Replace the seals an the leak is stopped. Put in a new cover gasket as well.
Go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx Click on the "ENGINE COVERS" tab.
A “very helpful” rating for this answer? Thanks!
Jun 20, 2009 | 2006 kawasaki KX 250 F
Water leak????
umm the leak is coming from the seal within the front of dispensor??? i checked my partlook up and comes back as a seal( part number 8181747).. sears site has it listed as distrubution nozzle(mis marked)
Oct 28, 2008 | Kenmore Elite 45986 Front Load Washer
I have a Maytag (Performa) Top loader. The washing machine is leaking water from the pump. It appears that the rubber seal is causing the leak. Where can I get such a rubber seal?
Searspartdirect.com carries all the major brand names. Just type in your model number in the search menu and use the exploded view diagrams under the various parts headings on the next page. If you do not wish to order on line, or wish to use another website, use the part number provided on the Sears website. Maytag identifies some of their parts by different series. If the part you need is listed this way and you are confused, please post back and I can assist. Make sure you provide your model number for me. I hope this helps you.
Aug 11, 2008 | Maytag Washing Machines
Karcher Pressure Washer  1800 PSI 15 GPM Model K348M Logo
295 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
