Question about Indesit WA 125 Front Load Washer
1s70c indesit condenser dryer still blowing cold after elements replaced
This is most probably due to the thermostats at the rear of the heater failing. There are 2 and must be replaced as a pair.
Posted on Nov 27, 2008
This indesit reverse action dryer (1S31V) has stopped blowing out hot air. I took the back off and cleaned the fluff which had clearly caused the problem. Is there a thermostat or fuse that I need to...
Hi. I have a Hotpoint tumble condensing drier which had the same problem. The solution for me was to access the heating element at the back which involved taking the back off and locating the small metal thermostat which is the size of a two pence coin and 10mm thick.There
is a small hole in the centre and all I had to do was press a fairly thick needle into the hole until there was a click which reset the
thermostat and everything was working fine. This problem does still occur now and again. By the way the heating element is attached
to the removed back with cables giving a clue which helped me find
the unit. Hope this helps Regards Peter
Feb 11, 2013 | Dryers
Is70cuk dryer only blowing cold air, all filters are cleaned water emptied
the one shot stat has blown on the heater. remove rear heater cover and two smaller screws holding element to the cover. you will see the two round stats. both must be replaced. part numer is 1703200, aprox £25.
Jul 06, 2011 | Indesit IS70C Electric Dryer
My indesit is70c tumble dryer is just blowing cold air,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Indesit Dryers
I'm only getting cold air blowing out condenser
you need to call a techincian sound like your heater element when out are if this is a gas dryer your glow bar are your gas coil when out,sorry
Apr 24, 2010 | Dryers
Indesit 1560v wont dry cloths it is just blowing cold air . rear vent is clear
you must replace the thermostats on the element.
Oct 24, 2009 | Dryers
Tumble dryer running but only blowing cold air
If your dryer is turning then things are not so bad. If a dryer is not heating then you need to check a few things.
First disconnect the power to the unit. Then you must check the heating element and the limits which are mounted on the heating box.
Remove one lead from the element and check for continuity thru the element. If you have continuity then check the limit by measuring for continuity, again you must remove one of the leads. This should solve your problem
Sep 15, 2009 | Dryers
An indesit tumble dryer, only blowing cold air.
Most likely heating element or thermal cut-off is bad, or both.
Sep 14, 2017 | Dryers
Indesit dryer only blowing cold air
You need to check heater and thermostat(s), with a multimeter.
If o/k then could be faulty timer.
You did not state wether it was a vented dryer, or a condenser dryer., as this makes a difference to the solution, because other components are involved.
Dec 08, 2008 | Dryers
Indesit is70c dryer is not heating?
Take off the back plate of the drier to expose heating elements. There you will find two thermo switches, one with a hole in the middle of it. Push something like a pin into this hole until you hear a click. Re assemble back plate and it should work now
Feb 28, 2008 | Dryers
Indesit WA 125 Front Load Washer Logo
248 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
