Question about Frigidaire FRT21H7AS Top Freezer Refrigerator
I have a model 138w that just stopped, no noise ..just the light on inside
It making a noise and the ice maker stop working
Thank you for your inquiry, Joann siefert!
I see that your Frigidaire refrigerator is making noises and no longer producing ice. Have you attempted to replace your water filter? If your filter is bad that could cause ice to stop producing. I would recommend changing your water filter to see if that would help correct your issue. The noise could be a normal operating noise. If you have your manual you can look inside for normal operating noises. If you need your manual could you please provide me with your model number? You can locate the serial tag (which lists your model number) on the inside wall of your refrigerator. With that information I can further assist you. -Matt
Jan 23, 2015 | Frigidaire Refrigerators
Pilot not staying lit and keeps clicking on internal oven
What is the complete model number of your unit?
Dec 09, 2012 | Kitchen Ranges
Kenmore Dryer light comes on but control panel not operating
Your thermal-fuse is located on the back side of the bulkhead upper right hand cornerb68bc9a.jpg
Electrolux family of dryers newer models Dryer Service manual
I have repair photos and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 15, 2010 | Dryers
GE JVM1650 Microwave Making Loud Noise
hello Frank. Sorry to tell you that the magnetron is going bad and making that terrible noise. Since the inside of a microwave, even unplugged has up to 2000 residual and deadly volts of electricity I recommend either calling a pro or replacing the unit.
Jul 12, 2009 | Microwave Ovens
Kenmore dryer stopped running
Hi, I can determine a motor bad by the noise. Does it hum while holding the start button or is it a grinding deep sound? It can sound like the motor starts slow but once it gets going, it is ok. Sometimes the house lights will dim when the motor statrs going bad.
Let me know if I can help you further.
Vic
Jul 02, 2009 | Dryers
Whisling noise coming out of inside the refrigerator. Louder when freezer door is open. maybe ice maker area?
The whistling is caused by the air circulating fan located just behind the light. It is easily accessed by removing the light cover and the two small hex screws above the light. To stop the whistling I simply turned the freezer off and pulled the fan cover out slightly to reveal the fan blades. I then pushed the blades down, toward the bottom of the until the blades stopped and i could feel the shaft slightly protruding from the top of the blades. Repositioning the blade has stopped the incessant whistling. Hope this helps!
Apr 19, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Freezer stops freezing
How long has this happened and when did it begin. Your refrigerator has a control board located on the back inside a panel. You may need to unplug and look for burns on that board. Let me know for sure that the model is HSM25GFTSA
Thanks, Sea Breeze
Mar 22, 2009 | GE HSM25GFTSA Side by Side Refrigerator
My microwave is not heating up suddenly...its working fine till morning...suddenly it stopped heaing things....[lease suggest me with a solution
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Aug 09, 2008 | Microwave Ovens
Frigidaire FRT21H7AS Top Freezer Refrigerator Logo
87 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
