My thomson crt tv has lost the blue colour,what could be the cause?
    Problem Solver:
  • 17 Answers
Diode on back of crt socket board there should be three test off of crt with dmm diode test unless its labled good luck i hope this helped
Posted on Nov 11, 2010
  • 1 more comment
  • kashwatzs Nov 15, 2010
    thanks for your answer,i did check all the diode and they r ok.The problem is still there,nothing seems to change no matter what i do.
  • wayne wilken Nov 15, 2010
    another thing that thomson is notorius for pending on the model of the board that would help me a bunch but they are notorius for there on board tuner needing to be unsoldered and check all grounds and resolder i use to have to use a jewelers magnifying glass to see but resolder all the ground points under the tuner shield and that could do it for you if you could please send me the number of the motherboard like ctc162 or ???? thanks
    also i should have told im sorry i forgot but you have to float one end of the diode to test it on back of the crt socket board in case you are not familiar with float you have to remove one end of each diode either end cathode or anode then test it i hope this helped
MY TV MONITOR COLOUR IS FULLY CHANGED .NOW ITS ONLY GREEN COLOUR .TV COMPANY NAME IS THOMSON.HOW IT WILL CLEAR?
Your TV color drivers could be at fault. They run very hot and sometimes develop dry solder. You can confirm this by hitting the side of the TV when its on and see if the color comes back. If they do or even flicker get somebody to resolder the CRT base pcb of the TV.
Mar 14, 2011 | Televison & Video
Thomson R21DG8GBD SERVICE MODE ACCESS CODE WANTED
R21DG8GBD MY TV PROBLEM WAS NO RED SIGNAL BLUE & GREEN IS OK PICHER IS SHOWD PROBLEM
Oct 03, 2010 | Thomson 21DC320 21" TV
Red colour on screen
if crt pic tube magnitized need to degausse with coil
Jun 01, 2010 | Thomson 21DC320 21" TV
Red colour appearing on screen
Your tv could have one of several faults. None of which are to be tackled by anyone except a qualified engineer due to the electric shock hazard.the first problem could be the crt (tube) the second could be the componets on crt base circuit board ie resistors or ic.
With a tv 9 years old it may not be economical to carry out a reair.
Lost sound on my GE (Thomson)46GW947X1
pls. first open your tv menu and select sound & colour -sys see the sound-sys / colour-sys is maching with your country transmitiongh sys {EXP.: PAL-BG / NTSC-DK /NTSC- MN /SCEAM- I ) IF your not set purfictly pls select AUTO colour sys and set automaticly set colour & sound .[see user's menual book and set your tv.]
Oct 06, 2009 | GE 35GT695 TV
Colours missing from tv
There are three color guns in a TV that make up the picture. Red, Green & Blue. It sounds like you have lost the green color gun.
You can get it rpeaired again, but your TV sounds like it is ready for TV heaven.
Jul 25, 2009 | RCA 20F512T 20" TV
My TV colour has changed
You have lost red which could be the red driver integrated circuit or associated components or it can be the CRT, you will need to let a technician have a look.
SUPER8
Dec 01, 2008 | Televison & Video
TV COLOR WENT BROWN IN COLOR
It could not be the playstation that would cause the fault. The set was probably going to fail anyways.
A brown casted picture sounds like there is a loss of the blue colour drive in the set.
Some TV sets have colour temperature adjustments in the user menu. Check to see if your TV has that option, and that the colour temperature is properly set up. You can refer to the TV's instruction booklet for details.
A loss of blue drive can be from failed components in the video path, or in the bias circuits that control the CRT's cathold current.
It is also possible that the CRT is going defective, and is losing emission from the blue colour electron-gun.
You will have to bring the set to a service center that has an experienced TV tech who can make proper diagnostics, and give you an estimate for the cost of repair.
Jerry G.
Apr 29, 2008 | Philips 55PP9352 55" Projection Television
UN LOCK TV
turned the tv on ... blue screen ... red lock in left hand corner
Mar 28, 2008 | Thomson 24WK25U 24" TV
Retuning having moved to a new area
blue screen is due to problem in blue video circuit. please check 1 supply to blue video ckt. 2 crt base loose. 3 components in blue video ckt. 4 loose contact in blue cathode ckt in crt base. 5 blue video transistor. 6 signal coming to blue video from signal processor. 7 signal processor ic. good luck.
Sep 29, 2007 | Thomson 14MG135 14" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
