Question about Miele Vacuums
My Miele White Star Model # S3141 was running fine, then stopped mid-vacuuming. I changed the bag and cleaned the filters (which were dirty), let it cool off, and tried to start it up again, but no luck. What do I do now? Are there any repair places in Ft. Myers, FL?? Thank you for your help.
SOURCE: miele .s5210 Bag Vacuum
Solution #2 was close in my case. There are two slip rings at the hub of the cord reel. One of them was not making contact despite the fact that there are two separate contacts for each side of the mains power for redundancy (good design!) It wasn't too dificult to pull out the cord reel, pull the reel off the axle while disconnecting the retractor tape, and adjust the contacts.
Posted on Jun 25, 2007
reddevil6
  • 1673 Answers
SOURCE: stopped working - warning light on
There is an electronic circuit board on the motor that may have gone bad and will have to replaced, part # 06836740 and sells for around $75.00, for model S516. But if this a S316, then it could be the speed control mounted on the motor, Part # 04416342 and sells for around $83.00. Both of these models are Cat Naad Dog so you need the model number berfore you order a part.
Posted on Jan 17, 2008
reddevil6
  • 1673 Answers
SOURCE: miele vacuum cleaner not working properly
Is the suction low or ok at the vacuum without the hose attached? If it is ok, then there is a clog in the hose. If it isn't, then check filters, is the speed variable, is the contol set too low. Could be a bad motor, running too slow.
Posted on Mar 06, 2008
reddevil6
  • 1673 Answers
SOURCE: My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Posted on Mar 22, 2008
chris321918
  • 32 Answers
SOURCE: vacuum not picking up
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Posted on Jan 19, 2009
Miele Silver Moon Losing Suction Power
That is possible, also check for a.m. exhaust filter off the motor. Usually a very fine filter to stop dust that gets past the bag. May just need to open it up and clean out the accumulated debris.
May 02, 2013 | Miele s558 Silver Moon Vacuum
Tip
Miele vacuum cleaner suddenly stops
So this is a problem I identified in Miele's mid size ranged canister cleaners. Not only the S318...
If you go about cleaning on the highest power setting the engine will overheat after 5-10 minutes. It then will need around 20-30 minutes to cool down before you can use it again.
Tip: Don't run the machine on 100% power, instead turn the setting to around 80-90% and then you can enjoy good suction un-interrupted.
on Jan 28, 2010 | Miele S318 Bagged Canister Vacuum
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Red light came on, and vacuum won't operate. We changed the bag.
you have to make sure the filter is clean and there is no blockage in the hose. try this and hope everything is fine hope this helps. have a good day!
Jan 15, 2011 | Miele Blue Moon Bagged Canister Vacuum
Miele vacuum dust problem
Hello. The problem you are having can be rectified with the new Miele FJM bags.
http://www.mielevacuumbags.us/
Also, if you have never taken your machine into a vacuum repair shop for an internal cleaning, please do so. J.
May 24, 2010 | Miele S4210 Carina Bagged Canister Vacuum
My vacuum (miele s251i) will not turn on. I just changed the filters and bag. Just wondering if I have put the top filter in the wrong spot. Does it go under the black flip-up bit or on top of it? I do not...
Hello Miller_04,
Regardless of how the filter is put in the vacuum cleaner should turn on. Really is no way to put the filter wrong in these. I have a white star myself.
You can contact Miele Vacuum support and they can further troubleshoot or recommend a vacuum shop in your area to send it to for repairs
Miele Dealer Locator (vacuums: non repair)
(800) 579-4583
Monday-Sunday: 24 hours Miele Dealer Locator (vacuums)
(888) 785-2828
Sep 16, 2009 | Miele S251i Plus Bagged Canister Vacuum
Access to the Plug in Cable of Miele White Star Vacuum Cleaner
Problem solved. A guy posted on the internet a step by step explanation including photos of how to open a Miele White Star vacuum to get to the take up reel.
May 13, 2009 | Miele S251i Plus Bagged Canister Vacuum
Miele white star canister vacuum - won't turn on, but isn't clogged
Miele white star canister vacuum - won't turn on,...
I have the above canister vac, which after my son tried to vac the stairs, it rolled down the stairs on him, but still worked, after turned off/on. Then after turned off maybe 10-15 mins., stopped working when we tried the switch. My father in law is our fix it guy, but still having a problem with the switch. Is there a wiring guide we could look at?
Thank you!
ALevy
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can try to call the factory for the Miele S251i schematics / wiring diagram @ the phone number and website listed below or I put a few pieces of information listed below that might help.
1. The vacuum cleaner switches off automatically
A temperature limiter switches the vacuum cleaner off automatically if it gets too hot. Some models have a warning light (triangle) which comes on to indicate that it has overheated. Allow the appliance to cool down for approx. 30 mins. and remove any blockages to the air path.
2. The "Change dustbag" indicator stays on even when a new bag has been inserted
To ensure the dustbag change indicator gives a correct reading, lift the floor nozzle or power head off the floor slightly to prevent the vacuum created in the suction tube from influencing the reading.
3. The exhaust filter indicator is red
Change the exhaust filter and then press "Reset" to switch off the indicator light.
http://miele.com 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
www.AVACcorp.com 1-800-328-9430
Apr 18, 2008 | Miele S251i Plus Bagged Canister Vacuum
Miele Cat & Dog Vacuum
doubt it. could be dangerous to use. (had one burn up due to this)
Apr 23, 2007 | Miele Cat & Dog 326i Bagged Canister...
Vacuums Logo
241 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
