Question about Sansui Audio Players & Recorders
I have Sansui Micro 1302 DSSW Home theatre 5.1 Top loading. I think due to dust it stops reading the DVD than CD and than nothing. I have replaced the drive once, but I do not want to do the same every few months. How can I avoid the problem? Thanks.
5 Suggested Answers
bobhifi
  • 635 Answers
SOURCE: sony dav-dz555k home theatre system-dvd
You seem to be having a door sensor problem. When the CD tray closes a small switch under the loading tray shorts telling the microprocessor the door is closed and to stop the motor (either way when it opens or when it closes). A malfunction in this switch causes this symptom.
Posted on Mar 14, 2011
dunnbiker
  • 8546 Answers
SOURCE: Sony da 3400es receiver. System
How about the unplug and try it naked fix? Speakers blow, mice eat the wires, etc.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Apr 20, 2011
snakehead
  • 1074 Answers
SOURCE: My sony Home Theatre DAV-DZ290K,
okay just plug it out from the current outlet let it stand for one hour then plug back in if that does not remedy problem then your motor is bad or the ic that controls the open and close circuit.have a tech look if my remedy does not work..sometimes plug in and out do the fix cause all the set wants is to reset itself.
Posted on Sep 13, 2011
My sansui dvd home theater remote sht 5114 sd was missing I am searching in goole but no results how can buy new remote please help me
not sure which country you are from but this South African website has 12 different Sansui Remotes you need to find the model number on the back of your home theatre .
http://www.candiav.co.za/index.php/product-category/remote-dvd-home-theatre-sansui/
once you have the model number you have a better chance of finding remote.
found this
https://www.replacementremotes.com/sansui/remote-controls/
suggest contacting them and asking if they have the remote
Apr 14, 2018 | Sansui Audio Players & Recorders
Samsung home theatre HT-X30,
The DVD player may have failed.
Dec 19, 2013 | Audio Players & Recorders
I have a Sansui Model VRDVD4000 and the DVD player keeps saying "load disc" even when the disc is in the player.
few small things to try. Turn off unit, unplug for 5 minutes, plug back in, turn unit on.
There is a product called a cd/dvd lens cleaning disc. Worth the investment to have around.
Some DVD players simply will not read/play home made dvd's, or dvd copies.
Apr 28, 2010 | Sansui VRDVD4000 DVD Player/VCR
Cd/dvd stops reading disc half way then stops.loading tray sticks or has a delay
Disc stops playing due to tracking error from either a dirty source cd or a dirty blank. It is not the machines fault. Clean both discs thoroughly before recording. Even non visible dust can cause a stoppage. My Sony recorder does seem to be a little too sensitive to dust but it normally works fine.
Mar 09, 2010 | Audio Players & Recorders
Home Theatre not reading DVD
put a cd to play if does replace the laser
Jun 15, 2009 | Televison & Video
JVC home theatre system DVD/CD player has stopped working.
Please check the dvd layer lense. When there is lense problem this issue will occur.
Apr 03, 2009 | Audio Players & Recorders
It dosn't read the dvd
DVD/CD drive is bad.
As a general rule, the CD/DVD drive cleaning disks do nothing but attempt to scratch the lens by brushing off dust.
Mar 05, 2009 | RCA RTD300 DVD/VCR Home Theatre System...
203 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
