Question about EW-3005 Radar Detector
Recently came across an Early Warning SRD500. Does anyone know where I can get a manual for this?
My e46 bmw has some warning transmission light switched on the car judders when it changes gear im badly worried what it could be it was fine when i drove early was parked up for 15mins car switched off...
These transmissions are pretty robust so don't panic.
The first indication that some folks get that their battery is failing is that the transmission starts to act up and set failure codes. Is your battery original?
Some of the early e46 transmissions had a defective design that caused a snap ring to pop off, but that caused a complete failure, not a judder, so that is not your problem. These transmissions sometimes experience a failure of the internal temperature sensor, which is easy to diagnose and replace. You check it by checking the resistance across the sensor wires at the ECM plug.
Jun 29, 2011 | BMW 318 Cars & Trucks
Hello my handbrake light turns yellow when i release it and theres another yellow light on the dash too. its almost a full circle but not a complete circle with an exclamation mark in the middle. i drive a...
Its a warning to check brakes,pads have sensors to warn you early
Get all pads checked
Look in owners manual so you know what all warning lights are
May 17, 2011 | BMW 3 Series Cars & Trucks
I have an Electrolux Dishlex DX303 Dishwasher. Recently it has been stopping early in the cycle and the display shows -10. The selected program is flashing. The cycle will restart by pressing the program...
hi peter, according to manual book -10 is not filling water fast enough. check inlet hose and valve, check pressure switch and pressure SW hose and clean sump filter which located bottom of tub that plastic strainer and stainless mesh clean them spotless. sometimes caused by this filter block the water passage and change pressure sw's leadings. and clean sump as well. b4 suspect PCB this filter cause many problem like not heating water, doesn't keep water. if dirty filter is the one you will save at least $300- for service man to come out and change the PCB for nothing. I think clean the filter doesn't hurt anyone.
Service Man K
Aug 22, 2010 | Dishwashers
I just purchased a 2000 VW Beetle 1.8 Turbo but, there was no Owner's Manual included with the car. A light has come on my dashboard and i don't know what it's for. It's a blue light in the shape of a...
If the light goes out after engine gets alittle warm, this is normal. Since there is no temp guage, VW uses this light to inform that the engine is cold. When that same light flashes red, it means that the coolant is low or the engine is overheating.
Mar 02, 2009 | 2000 Volkswagen Beetle
Orange warning light
Could be anything from a low fuel indicator to a bad sensor to a preset hourmeter to tell the owner when it's service time to the self destruct button... You need to pop for a good service manual for your bike. An owners manual will tell you about this light (probably), but it's no good for anything more involved. Do you and your bike a favor and get a service manual. It will be the best money you ever spent on maintenance. It will save you money in the long run. Plus there is alot of good info in there about everything from changing oil to setting the suspension. Sorry I can't tell you what your light means
Nov 20, 2008 | 2004 BMW R 1200 C Montauk
PLEASE HELP
I'm sure anyone with an OBD reader can reset the warning for you you. Also you could search the Hummer forums to see if anyone has fix for this.
Aug 12, 2008 | 2005 Hummer H2
EW-3005 Radar Detector Logo
50 people viewed this question
Top EarlyWarning Vehicle Parts & Accessories Experts
Aaron Hackbarth
Level 1 Expert
okcchemist
Level 1 Expert
Tom Chichester
Are you an EarlyWarning Vehicle Part and Accessory Expert? Answer questions, earn points and help others
