Question about Ebel Classic 1157111/0225 Wrist Watch
I tried to change the time on my ebel by pulling out the stem. The stem fell off as well as a little black rubber circular thing. What do I do and what is the correct way to change the time. Please answer both questions.
3 Suggested Answers
dmbgo
  • 58 Answers
SOURCE: stem came out, question water resistance of watch now
Hi
The crown or winder, should have a very small o ring inside it, which seals on the watch case. Normally when replacing the stem this o ring would be replaced and lubricated with silicone grease to ensure water tightness. If this was not done there is no guarantee that it will still be waterproof (please dont forget to rate my answer, thanks)
Posted on Jun 23, 2009
SOURCE: How to remove stem to get to battery in ebel
On my men's classic wave, the stem is removed simply by pulling it out. It feels like it's requiring a lot of force, but it is designed to have resistance so that it's not pulled out accidentally when setting the time.
So to change the battery, you remove the 5 faceplate screws, remove the crystal and gasket, pull out the stem and then the whole face/movement assembly will pull forward.
NOT positive yours is the same, but that's how my men's Classic Wave is. Good luck!
Posted on Jan 19, 2011
I need to change the date
Changing the date for the FT500WVB watch is easy. Just pull out the stem of the watch to its first stop. Then turn the stem counter clockwise a couple of twists and the displayed date will increment (that is increase) by one day and you will hear a little click. Keep twisting the stem counterclockwise and the date will increase by one each time with a little click. Stop when you reach the correct date and push the stem back in to its fully seated rest position. Note- be careful not to change the date when the watch displays a time between 9pm and 1 am as setting the date in this time range may cause the watch to increment the date at noon rather than midnight.
Note also that if you want to set the time you just pull out the stem to its second stop position and twist the stem to advance the position of the hands of the watch. Then when the time is set, push the stem back in to its lowest rest position. So remember- first stem stop sets the date and second stem stop sets the time. That's it.
Mar 25, 2014 | Casio Forester FT500WV-3BV Wrist Watch
The stem seems stuck and I can't change the time on my watch. I can't remember having this problem before. Shouldn't it pull out easily so I can manually change the time? Thanks
hello some watches have a screw down crown turn the stem screw counter clockwise a few turns and then try pulling out gently. hope that helps
Mar 20, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
How to remove stem to get to battery in ebel ladies watch?
Dec 18, 2010 | Ebel Classic 1157111/0225 Wrist Watch
How change batery ebel sport classic
This is not a simple task.You need a watchmaker with knowledge of Ebel watches.The case is opened by removing the bezel and splitting the crown stem.The watch module then pulls out of the front of the case.This is not simple I advise you dont try.At www.rolexrepairs.co.uk they operate a postal service so your watch can be returned within 2 or 3 days.
Regards
Aug 20, 2010 | Ebel Sport Classic 1157111/9225 Wrist...
THE STEM FELL OUT OF THE CROWN AND WON'T SCREW BACK IN...CAN THIS BE REPAIRED
Yes, it can be repaired. A qualified watchmaker can do this for you.
Hope this helps,
Ken
www.YellowStoneWatch.com
Apr 11, 2010 | Ebel Classic Wave 9090F249725 Wrist Watch
Should you be able to advance the date complication with the stem on an Ebel Brasilia (quartz)? i have to wide my watch 24 hours to advance the date, that just doesn't seem right...
Watches change their date at midnight (ish), so when the date has changed,to advance the date another day, wind the hands backward past midnight and then forward again.
How much further back you have to wind the hands will have to be found by experiment.
Mar 12, 2010 | Ebel Brasilia #9255m41/62500 #1215598...
Battery change ebel watch
what size battery does a kc3585 watch take
May 05, 2009 | Watches
Ebel Wave lady's watch battery
to change the batt on an ebel womans watch i simple. 1 take out screws from bezel. 2 lift off , make sure to keep rubber gasket in place. 3 pull out stem to the set position. 4 be very carefull not to bend / touch hands. 5 turn case upside down, and you will see the opp side from the winder drop out slitely. with your fingernail pull downwards gently on works, then when you have it out a little on that side, turn it back over. and continue to lifft up gently, 5 as you do so, start to rowtate the works counter clockwise. the stem is made to .bend / swivel and the works will turn upside down and lay back into the case. to protect the face while installing the batt. 6 when done gently lift the same way but rowtate clockwise. but make sure you grab sides of works and not the face. ( the hands are very delicate) 7 take the batt to a jeweler to replace you will never find a batt with the same number ( ebel made sure of that ) they want you to pay 140.00 to 240.00 for them to do it. but a jeweler can match it. now that said, once you take the bezel off, your ebel warenty is void. so 140 -240 or $5.00 your choice i have had meny watches over the years all with rubber gaskets and have replaced batts is some five times and the gasket are still fine. and a batt will last 3 to four years. five in 15 years could cost you $ 1020.00 in the long run. hope that answers your question.
Feb 19, 2009 | Ebel Classic Wave 9090F249725 Wrist Watch
Need a new stem. Can I purchase on and get it put on myself
You have to open your watch and find movement number. Use an eyeglass as the numbers are very tiny. Number is pressed onto one of movement plates and shoud be letters ETA+number.
When this is done, visit your nearest watchmaker shop and ask for stem for movement ETA+number. Do not tell this is for Ebel or you will be charged accordingly to brand name.
There should be no problems for supplying ETA stem.
Dec 04, 2008 | Ebel Classic Wave 9090F249725 Wrist Watch
Ebel Classic Wave fitting a new crown
i have changed the battery on my and my wifes ebel classic wave watch,,
step 1 ...remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
step 2 ...remove all 5 gold bezel screws
step 3... be careful,, the bezel/crystal will pry off easy
step 4... be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
step 5.. small screwdriver and remove/replace battery
step 6... reinstall watch guts/bezel and gold screws
step 7... push crown back into watch
step 8... take wife and kids to dinner ,,you just saved three hunderd bucks
if have done it many times ,, you can do it !!!!
Dec 10, 2006 | Ebel Classic Wave 9090F249725 Wrist Watch
Ebel Classic 1157111/0225 Wrist Watch Logo
112 people viewed this question
Top Ebel Watches Experts
Coss
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Ebel Watch Expert? Answer questions, earn points and help others
