Question about Frigidaire GLTF2940ES Front Load Washer
Wont start cycle
Go to start a load of laundry, select cycle and it wont begin the cycle
    Problem Solver:
  • 12 Answers
Step 1 go to http://www.frigidare.com
Step 2 click on CUSTOMER SERVICE on top of page
Step 3 go to PRODUCT MANUALS and click on DOWNLOADS
Step 4 type in MODEL NUMBER and click on search
Step 5 your error code information is in the TECH DATA file there you can perform a full system check PLEASE READ ALL WARNINGS POSTED
Stpe 6 Also access and save or print your : OWNERS GUIDE, and OPERATING INSTRUCTION, and any other guides listed that are needed.
Step 7 save all PDF files to a new folder name it FRIGIDARE for easy availbility for viewing and printing.
Thank you and good luck.
Posted on Jul 14, 2008
When I start a load the washer just clicks and hums but won't begin the cycle, is this something I can fix?
Sounds like the plastic spline between the transmision and motor sheared apart...
Feb 17, 2015 | Washing Machines
LG washer #WM2655HVA won't start again after a cycle, unless unplugged, hand-turn drum, makes a beep, static spark as plugged back in, then a new cycle begins. Why?
Have you checked the wall power outlet for proper ground and
polarity? Try using another outlet near by using a "heavy duty"
3 prong extension cord. If problem persist chances are the Main
PCB is bad.
Aug 15, 2014 | LG SteamWasher Series WM2655HVA Laundry :...
Laundry detergent & fabric softener go into the washer at the same time immediately when started, the fabric softener should only be released when rinse cycle begins, how do I fix this?
without knowing what your machine is I would suggest that you start your load with only detergent in it the after it has filled and is agitating add the fabric softener-you may have to pause the cycle to do this-hope this helped-cheers Denny
Oct 21, 2013 | Washing Machines
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
When washer gets to spin cycle it shakes and moves about the laundry room and does not drain
You will have to quit washing your concrete blocks with your red bricks.
When this problems begins you have to readjust the load to balance the spin cycle.Move item around to make the load more pound wise equitable.
Jan 29, 2011 | Admiral Washing Machines
I was doing a load of laundry and the washer "froze" i tried to cancel the load but it wont stop.... i ended up unpluging it and even when i plugged it back in its still stuck!!!
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED Status light turns off.
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE3 has power but not starting wash.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
112 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
