Question about SmartParts SP-DPF56E Digital Picture Frame
I cannot put more than a few pictures on my jump drive to load into my digital picture frame. Also, I am unable to use my 4 gig jump drive on the picture frame; only one with small memory capabilities for less than 20 pictures. Is this typical? Do I need to format my larger jump drive?
  • Terry
    Terry Feb 19, 2018
    Manual only mentioned limit on size of individual pictures, and not the jump drive.
    https://www.manualslib.com/manual/651968...
    One negative review of this frame, despite its failings, suggested copying directly from a computer instead of a memory card.
    Habit-Forming:
  • 120 Answers
The older memory frames could only read a few MEGS of memory sticks, not Gig. That could be a problem, these were made cheap so the latest and greatest parts were not used. Plus newer cameras are 4 mb per image rather then the 600K of older cellphones/cameras. That may be a problem too.
You can reduce the SIZE of the image to 800x600 rather then the 3K or 4K many cameras now take. There is a free program called PhotoFiltre (French company) that is very easy to use, free (no spyware) and only a few megs in size.
Install program, go to FILE OPEN, get image on stick, choose IMAGE - SIZE and erase the width, type in 800 click OK and it will adjust the height automatically. Then choose SAVE. Your file will be smaller but you will not notice it on an 8" screen. Do this with the rest, you will then have lots of room for more. WARNING.. do this with COPIES as you cannot "re-enlarge" them ! ! And as I have said since the 90's, alwasy have 2 backup copies in separate places. Those external drive are cheap insurance.
Posted on Feb 20, 2018
  • 3 Answers
SOURCE: No USB Port on SP70BRS Digital Picture Frame
Put a memory card into a card read/writer and, once you've edited your pictures, place them on the card insert that in the frame and either use them from the card, or transfer them into the onboard memory.
Posted on Dec 28, 2008
Roynice152
  • 88 Answers
SOURCE: Unable to download pictures from computer to digital frame
The primary software is going to extract all the images, put only the images you want on the card, then insert into your picture photo frame.
Posted on Jan 08, 2009
  • 119 Answers
SOURCE: i put pictures on a san disk sdhc memory card
I couldn't find very specific information about your picture frame. I did find out it is from a company called Smart Parts and it is not a Kodak frame.
If I had to guess, I would say that the frame is not SDHC compatible. What this means is that it only will work with cards up to 2gb (SD).
I saw a review site (http://www.reviewcentre.com/reviews115912.html) that had a lot of reviews about how the frame does not like to read jpgs from the SD cards so this could be the issue if the one above is not.
My recommendation would be to try to use a 2gb card. If that does not work, try loading the pictures onto the frame directly from the computer.
Posted on Jul 13, 2009
  • 7 Answers
SOURCE: SmartParts Frame SPX7E only allows me to load 165 photos
2 answers...
To remove a picture, connect the frame to your PC via USB. you should see the frame appear as a drive, in my case,
36972 (E:)
open the drive as Explore, you can now see the pictures, and delete what you no longer want.
you can download the software from
http://www.smartpartsproducts.com/content/support/optipix/index.php
Posted on Oct 05, 2009
  • 7 Answers
SOURCE: RE: omnitech 8.5 digital picture frame. smartparts
I had same problem today, my software on the PC was version 3.03, I upgraded to 4.1, it seems to work better now.
These frames are a little flaky, sometimes I have to power it off, and on, for it to be recognized.
software at
Have a new 8 gig memory. Shows full before all pictures load, should have loads of room?
I would format it using your computer, then try loading in your photos again.
In Window, go to your file explorer, right click on the drive and click Format.
http://www.blogsdna.com/wp-content/uploads/2009/01/format-usb-drive.png
It's ok to do a 'quick format'.
This will delete everything on the drive.
Now try loading on your photos, and see if that made a difference.
Mar 07, 2011 | Philips 7FF2CMI/00 Digital Photo Frame
When I use my USB to connect my Philips Digital Picture Frame Keychain to my computer, nothing happens. There is no file for me to open and transfer pictures to. The only thing that oddly appears in "My...
I finally got one to work by 1) Disconnect the unit from your computer. 2)turning the unit off, 3) Reset the unit using a pin or small object. 4)Now reconnect to your computer.
I preformed this procedure and finally was able to load photo's and get the pre-loaded software to work.
Aug 16, 2010 | Philips (9FF2CME/37) Digital Picture Frame
Digital frame won't read memory cards
Did you format the card before trying to use it?
Dec 30, 2009 | Polaroid T831 Digital Camera
I have a 2 gig card that won't let you use that amount of room
Reformat he frame's internal memory.
1. Click on the "Macintosh HD" icon.
2. Click on "Applications".
3. Click on "Utilities".
4. Click on "Disk Utility".
5. "Kodak" drive should be in the list showing a white drive icon
6. Click that icon and select “Erase”.
7. Select the “MS-DOS file system (FAT16)” option and give it a volume name e.g. "Kodak". The format will begin when you click the “Erase” button below.
8. Try to copy the files to the re-formatted internal memory of the frame.
Dec 28, 2009 | Kodak EasyShare C315 Digital Camera
I need instructions on how to load pics to my Optimus 07A08 digital frame.
On the back of the frame remove the memory card, then You need to use a pc with a Memory card reader, you can get usb card readers that simply plug in your usb, then copy all the pictures you want on the card from pc.
Oct 29, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Jan 08, 2009 | SmartParts SPX8 Digital Picture Frame
HOW TO PUT MUSIC ON FRAME
I just received a gpx photo frame. I can not copy from my memory card to photo frame. Has built in 1 gig memory
Dec 24, 2008 | Nextar N7 - 7 Digital Photo Frame with...
Transfer pictures
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
Dec 13, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
Coby DP-887 Digital Picture Frame: Unable to transfer pictures to internal memory
The Coby DP-887 does not have built in memory so one cannot "load" pictures onto it. It is a viewer in every sense of the word. If you load pictures on a flash drive or memoory stick and plug that into the Coby DP-887 then you'll be able to view pictures or video.
Dec 22, 2007 | Electronics - Others
SmartParts SP-DPF56E Digital Picture Frame Logo
227 people viewed this question
Top SmartParts Photography Experts
Joseph Hoffmann
pictureman4u
Dayton Computer
Dayton Computer
Are you a SmartParts Photography Expert? Answer questions, earn points and help others
