Question about ASUS DRW-2014L1T DVD-RAM Burner
Hello - I have the Asus drw 2014L which have used without problem for two years for ordinary DVD burning with Adobe Premier Elements 4 and Nero 9. This past 10 days, the door has been sticking. Also, when going to burn on Premier elements, its not saying 'Ready ' as before, but Busy or No media. When it does let me go through first process of encoding media, its asking me to insert a blank disk, even though there is one already in the tray !. During past two years, the rewriter has had a lot of action ! Help and thanks
  • 5 more comments
  • spvlj Nov 11, 2010
    I have used lens cleaner , but that does not solve the problem
    The lens can still read the disk.
    Yes - that is correct. Primarily, I am using the top of range Verbatim
    Very many thanks for your consideration and advice
    In hindsight, can you please clarify what needs replacing eg just the DVD rewriter or other drives as well
    When you say drive, presume you mean the Asus DRW 2014L rewriter
    Thanks for your clarification.
    kind regards
    Les J
  • ASUS Master
  • 6,487 Answers
Thank you for the details information that you have provided us about the problem, just need to know some information here like can your drive still read disc or not at all?
Because it seems that the drive is already having some issues with its lens that is due to the heavy work load that it did it the past 2 years. Even if the drive can still read some disc losing the writing capability of a lens problem and you can try to run a lens cleaner on it and see if that corrects the problem.
Posted on Nov 11, 2010
  • 5 more comments
  • Mark Gil
    Mark Gil Nov 11, 2010
    OK thank you for the update, but the drive can still read disc? because with all the information that you provided the drive is already getting bad on its hardware side specially on the lens part of the unit and may need a replacement already.
  • Mark Gil
    Yes this happen to my older drive it started to stop recognizing blank disc that I have used for several years without and problem and after a few more months it just stop even reading disc , I believe that you already tried a different blank disc like a different brand is that correct?
  • Mark Gil
    OK thank you , sorry to say these but in just a few more months these drive will eventually stop working , so be ready to have it replace.
  • Mark Gil
    No worries thank you also for your time getting with us.
  • Mark Gil
    OK you can just simply replace the drive only.
  • Mark Gil
    That is correct or if you can locate a repair center near you to replace the lens of that writer.
  • Mark Gil
    No worries happy to assist you for your concern.
No how i can get nero smart for my compaq 610 asus dvd writer i m using window7
Nero 9 is a free burning utility available through the Nero software company that allows users to burn audio and video files to blank CDs and DVDs.
Just search 'Nero 9 download' on google.
Aug 20, 2011 | Compaq (158165-001) DVD Drive
Hello I bought yesterday an ASUS DRW-24B3ST and a new computer and can't install win7 from USB because of missing CD/DVD driver
my advice is use another computer that has a cd/dvd burner and burn the copy of windows on to a blank disk that way you should be able to install windows
May 12, 2011 | ASUS INT DVDR 8X SATA NERO 9-BLK -...
Have purchased a Panasonic TM700 and Aunsoft converter to create movies in all different formats. What format should I be using for Adobe Premier elements 9 to burn to DVD for standard DVD players?????
if you are using windows operating system then you shald try the windows meadia centre format eg windows vista operating system or windows 7
Feb 19, 2011 | Computers & Internet
Hello i have a lightscribe asus drw-2014L 1T disc drive it will not burn onto lightscribe discs but ok on normal printable & dvd-rw discs can u help me with the problem
The LightScribe feature of DVD burners with this capability requires that you are using burner software that has this function. Verify that the software you are using is lightscribe compatible. The software that comes with this drive(Nero) should be lightscribe compatible. After you burn the disc you do need to fip the disc over and the re-insert into the drive so that a label can be etched into the disc. The lightscribe discs look identical on both sides so only one side you can burn info and the other side is for the label so make sure that it is inserted on the right side for each process. If you put the disc in on the wrong side the initial data burn will not work. Also sometimes burners will have issues with certain brands of discs so you may also want to try a different brand and see if that helps. And another thing that you can try is updating the drive to the latest firmware. The firmware is to the drive kind of like what Windows is to your PC. Sometimes updating this file will fix problems like this. Here is a link to the firmware of your model. http://support.asus.com/download/download.aspx?SLanguage=en-us
You can download the file and run it to update your firmware. Caution: Before running the firmware make sure it is the correct file for your drive! There are a couple of variations to your model number and this one might not be the correct one. If you install the wrong file you could damage your drive inoperable or defeat some of it's features. I hope this information is of help with your problem and thanks for using FixYa.
Aug 20, 2010 | ASUS DRW-2014L1T DVD-RAM Burner
I got a ASUS DRW-2014L1T CD-RW and have no driver can anyone tell me pls where i can download a driver or post the link, would be very thankfull ( milojica90@hotmail.com for contacting me )
Here is the link for the ASUS downloads.
Choose Optical storage then DVD RW then your model number
The DRW-2014L1T is a DVD-RW and the drivers are incorporated with windows drivers. Are you looking for the burning software, like Nero or Roxio? Or is the unit not working at all?
My email is jdaniher@verizon.net.
Jun 27, 2009 | ASUS DRW-2014L1T DVD-RAM Burner
Video downloaded cuts off in adobe premier elements 4
There are occasions you find yourself facing DVDs as source videos for a project or need to do some "operation" on DVD with Adobe Premiere Pro. Whether it's for a wedding video, a sport highlight film, a video game demo, or some other project, more and more people have their video footage on DVDs (only) these days. Obviously this is not a wise move for editing - the video file has already been compressed, so you've already lost quality to begin with. But the fact is that you have to work with what you've got.
read more
http://www.dvdripperformacos.com/dvd-to-adobe-premier-pro/
Jan 16, 2009 | Adobe Premiere Elements 4
ASUS P4P800 SE DVD WRITER NOT WORK
Turn the burn rate down.If that does not solve the problem.reinstall the burn program.
Was this solution helpful? Show your Appreciation by rating it..RICHARDM69
Dec 14, 2008 | ASUS P4P800 SE (890552603657) Motherboard
ASUS DRW-2014l1t DVD burning problems.
Hi, try to buy optic lense cleaner of dvd.
Try also nero if also available.
Jan 19, 2008 | ASUS (GENEIRC DRW-1608P BLACK)...
My burned media from my new DVD Burner ASUS DRW-2014L1T isn't able to be read by my DVD Player
no data dvds work on the players.
use NERO 6 OEM to write Video DVDs or CDs they will run Players
Jan 07, 2008 | ASUS (GENEIRC DRW-1608P BLACK)...
ASUS DRW-2014L1T DVD-RAM Burner Logo
47 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
