Question about Refrigerators
It does not defrost like it used to. cold air does"t seem to get very cold for the bottom section. find water on the shelves sometimes. is there ice blocking the air flow?
Don't know if this is the solution but my ex used to work in appliance repair and he always said the first thing you should try is cleaning all the dust bunnies and **** out from under and behind your fridge. If the coils are gunked up, it affects the way the fridge works. They sell these long brush-looking things at hardware stores to get up under there. Hope this helps. Have a great day!
Posted on Nov 11, 2010
Set at the coldest setting the top two shelves won't freeze water, the bottom two shelves will and the thermometer reads -5. Is this worth getting fixed? Cost?
Your coils are frosted over. Want let the fan push cold air around. I am having that issue right now. Turns out it is the control board is not telling the fridge to auto defrost or what to do and when to do it.
May 26, 2015 | Freezers
Fridge section not cold, freezer section o.k.!
Normally, the cold is only generated in the freezer compartment, and then the cold is pulled or pushed throuch cooling tubes from the freezer section to the refrigerator section. So if your cooling tubes become blocked by ice (usually caused by a defrost circuit failure) then the freezer will seem to work fine but the refrigerator section will not receive the cold air it should.
Suggest you remove the food from the freezer section, then remove the shelves and then the back panel of the freezer. If there is a lot of ice on the evaporator then you should manually defrost the unit. Unplug it from the wall and use a hair dryer to melt the ice. There will be an entrance to a cooling tube right below the evaporator make sure the you keep blowing the hot air from the hair dryer down than tube until you can feel it in the refrigerator section.
If there was ice, you also need to troubleshoot the defrost circuit and find out which component failed. It is normally made up of the defrost heater, defrost thermostat and defrost timer and troubleshooting methods can be found in the tips section.
NOTE: There will be a lot of water to deal with when you defrost your freezer so make sure you are ready to handle it with buckets and large sponges or a wet/dry vac.
Jul 13, 2011 | Frigidaire Refrigerators
I have a GE Profile model # TPX2451YEBS side by side fridge. Both sides are not cold on upper part. The food in fridge on top 2 shelves and door shelves is just cool. The frozen food in door...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
The upper portion of the freezer turns off, causing the ice to melt. And the cooler side bottom drawer turns into a freezer. I can't figure out what's going on.
You have a frost blocked evaporator. Translation: The cooling coils, located behind the back wall inside the freezer section, have plugged up with frost (usually caused by a burnt out defrost heater, located at the bottom of these coils) which prevents the cold air from circulating inside the freezer, and into the top of the fresh foods section. At the same time, this blocked air flow allows very cold air at the bottom of the freezer section to migrate back into the bottom of the fresh foods section, and thus freeze item in the bottom bins of the refrigerator. Unload the freezer, take the shelves out and remove the back panel. Melt the frost with a hair blower, and change out the heater at the bottom.
Jul 08, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
