I get a disk error with all DVDs and the unit played fine a couple weeks ago before I packed it up in the box, moved it to my new place and tried it again. Any idea what it can be?
  • 4,472 Answers
First try a DVD lens cleaner.
Keep me posted,
Lee
Posted on Jun 17, 2008
Error sc300 on Ricoh mpc 7500. i replaced the drum unit and its fine but after two weeks the error came up again
The error code you gave shows several possibilities for your issue:
Drum charge corona wire, The output of the charge corona wire of the black PCU is abnormal.
Causes
• CGB power pack connection loose, broken defective • Check CGB power pack connection to BCU • CGB power pack defective • BCU defective • Replace OPC drum
Of the five possibilities above, replacing the drum is the most likely cause. Since you only had your drum for a couple of weeks I would take it back to where you purchased it and ask for replacement. Sometimes you get a bad drum out of the box from the manufacturer. It happens. If the same error code pops up again, I recommend you call your local Ricoh dealer for further troubleshooting.
Aug 26, 2016 | Ricoh Aficio Office Equipment & Supplies
Won't play blu ray after update
follow this guide and fix it. God bless you
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Nov 05, 2013 | Sony BDP-S3100 DVD/Blu-ray Player with...
My dvd won't play. every dvd i put in, it says bad disc. the vcr works fine. is it time for a new system. i tried a head cleaner and it says bad disc
Not necessarily time for a new one. I would give the DVD player a good cleaning before you consider a new unit. A good cleaning disk with some little bristles on it. Run it through three full times. DVD players are far more sensitive than VCRs and have to be cleaned even two weeks or so. When they get real dirty it can take some fooling with to get the DVD player to even accept the cleaning disk. But if it just won't accept the cleaning disk and you can't watch a DVD in it then it's time for a new one. I had a DVD player one time that took an hour of fooling around with before it got cleaned good enough to play DVDs. Worked for a couple years afterward.
Regards, Tony
Apr 19, 2011 | GoVideo Go Video DVD/VCR Combo
Hi, I bought this LG RC897T 2 years ago and have only used the DVD player about 60 times. I've bought original "US" TV Box set dvds and Chinese knock-offs, and wrote my own dvds and they all...
Hello Mark. Most likely your player is regionalized and not compatable ith those DVD's that won't play. To eliminate the regional setting on your player go to this link http://www.wisebread.com/make-your-dvd-player-region-free-in-seconds
It contains the step by step instructions on how to make your player region free. It also has an how to video and a full explanation of why the regionalization was installed in the first place. Joe
Thanks for choosing Fixya!
Jan 05, 2011 | LG RC897T DVD Recorder/VCR Combo
Wrong disk
I looked at everybody's ideas, and none of the ideas seemed to fit my situation. My DVD player has been working fine for one month. I got a new DVD today in the mail. It froze, and then began to display the WRONG DISK message. Then, nothing would play on the player, All of the DVDs that had worked fine before, now would not play. They all said WRONG DISK. I tried reaching under and trying to clean the laser lens, but that did not fix the problem. I am not saying that this will fix your problem, but this is what fixed mine.
1. Place the DVD player on a table
2. Plug in the DVD player.
3.Push the OPEN button so that the DVD platter extends outside of the player (It now looks like it does when it is ready for you to put a DVD in it to play it.)
4. Unplug the DVD player. (Now the power is off, and the platter is still extended.
5. Remove the cover of the DVD player being careful not to damage the extended platter.
NOTE: With the platter extended, looking slightly from the rear, under where the DVD is spun, you will be able to see the Laser lens. It will be covered by the mechanism that spins the DVD. The lens will be connected to a mechanism that that has two rails on either side.
6. Grasp the plastic surrounding of the laser lens area and pull the entire mechanism toward the rear of the DVD player.
CAREFUL: DO NOT YANK THE MECHANISM BACKWARDS as this will break off the laser unit. This mechanism is being moved with the resistance of many gears. PULL SLOWLY AND FIRMLY, and the entire mechanism will move on the rails until the laser unit is clearly visible to you and completely from under the spinning mechanism.
7. Since the lens was clearly visible now, and easily accessable, I carefully and lightly cleaned the lens with a Qtip and alcohol.
8. Replace the cover on the DVD player
9. Place a DVD on the platter.
10. Plug in the DVD player
You will find that you no longer get the WRONG DISK message and your DVDs will now play properly. As I said, just reaching under and cleaning the laser lens did not seem to fix the problem. It was only when I moved the entire laser unit from under the spinning mechanism, and forced the DVD player to realign itself when it powered on, did the DVDs begin to play again.
May 23, 2009 | Sungale DVD-2026 DVD Player
Recorded dvd's won't play in another dvr
The problem is not the dvds themselfs it is the other play that you are trying to play them in (some players do not play DVD- and DVD+ or any other of self recorded disks) Look on the players box to see all what types of disks it can play!
Please rate answer and help keep this site free
Jan 03, 2009 | Zenith XBR716
LG GSA.4040B doesn't recognize DVD's anymore , only CDs working
sounds simple
in the world the cd dvd creaters are using a new format of cd dvd making old players obsolite due to piracy these new cd dvds are becoming a pain a way they make you go out and purchase new players with updated formats
i found this out a few months ago when i bought a dvd from store it wouldnt work in a 7 month old dvd player so i got to thinking about it put in older cd that worked did a little investigating i want to know why new cd dvds werent working low and behold i found a tech site for the cd dvd compile build formats there it was piracy is getting knocked out by new cd dvd format this is so you cant copy direct to or from disks
if your older disks worked in drive and older disks burned in drive 9 out of 10 the problem lies with in new disks and what i explained up top
i hope this help you in your quest
Jun 02, 2008 | LG GSA 4040B (GSA-4040BI) DVD±RW...
DVD drive audio problem
The best thing to do is check the status of your speakers and the speaker plug
Mar 21, 2008 | Computers & Internet
Dvd loading
mine kinda has the same problem but it only happens with one movie Hairspray but it doesn't say error it just says loading for hours until i restart this system in order to get the DVD out. Need Help!!
Feb 16, 2008 | Sylvania SRD3900 DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
