Question about Vivitar ViviCam 8025 Digital Camera
I can not remove the SD card from camera it is working properly so must be in the right way but will not come out !
    Genius:
  • 1,177 Answers
Push the card in further and the latch will release allowing it to pop out slightly so you can get hold of it.
Posted on Nov 11, 2010
When i put my sd memory card back in my digital camera it said file error
This can be due to a corrupt configuration file in the SD card. I recommend:
1) Insert the card in the SD slot in a computer that has the slot
2) Go to "My Computer" (or "Computer" in Windows 7)
3) Right click the "SD card" icon
4)Click "Format..."
5) Press "Start"
Then you should be able to use the SD card properly with your camera.
Apr 05, 2011 | Cameras
HOW DO I CHANGE THE SD CARD ??
These are the physical specs of Kodak Easyshare V530
The bottom and the top of Kodak V530
The left side and the and the front of Kodak V530
The back -lcd display and the right side of Kodak V530
On the right side of the Kodak v530, just look at the above image, you will see a slot in the center of the silver band covered with white felt curtain that protects it from dust. On this slot is where the SD card is inserted. Just insert the card carefully, and feel the click when SD card is placed properly, and push the card carefully until it bounced back and release from the slot when removing the SD card.
Jul 18, 2010 | Kodak EasyShare V530 Digital Camera
Dropped camera and i now receive a message "access" i can only view previous shots...help sony cybershot dsc s90
in this condition your optic zoom is out off order & not work properly you cannot remove this problu at home so please go to your nearst sony service centre & fix your problum
Feb 05, 2010 | Sony Cyber-Shot DSC-S90 Digital Camera
Tell me how to format my sandisk camera card and erase the photos
your cam come's with data cord or USB BUS hub drive which can be easily connected to an y pc or note book pc or laptop but first see that you install the driver & software on your system for proper working or function of cam on the PC or Laptop after installing connect the cam to USB cable then it will automatically show each & every content on your PC or Laptop & their is the option of deleting every thing you need to erase so till then see your hope that it help you out ......!
Sep 29, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
SD memory prohibits functioning of Pentax E30
I know that usually, you should format the card for the camera that your going to use. Try formating it in the camera and see if that works. Let me know if I can do anything else for you,
Rob
Feb 22, 2009 | Pentax Optio E30 Digital Camera
Camera insist on memory full, but card is empty
Press "Menu" Press button to the right (towards a little flower on my camera) which takes you to the "setting" menu. scroll down to "format" right click again and it reads "All data deleted" and then gives you the option to "Format" or "Cancel". Select "Format" and then "ok" and pronto....your memory card is ready to go.
Nov 17, 2008 | Cameras
Memory card
Hi and welcome to FixYa.
Your camera will not work with an SDHC card. It must be an SD card.
Don't forget to format the card in the camera after you install it. Elsewise it won't work properly.
Thanks for coming to FixYa, and feel free to rate my solution.
Rob
Jul 28, 2008 | Pentax Optio T10 Digital Camera
SD card rejection
I have seen SD cards go defective. Also, enquire to the manufacture of the camera or at least the dealer to make sure that the model of SD card that you have is compatible. I have seen compatiblity issues with particular SD card types on specific models.
Jerry G.
Jun 06, 2008 | DXG Technology DXG-518 Digital Camera
SD Card Wont Work
Check if the SD card is iserted properly into the camera, eventually pull it out and push it back inside the camera. Also remove camera batteries , repeat the operation, and put back batteries.
If the card still does not work test the card into a different device, it is not unfrequent that an SD card comes defective from factory. In this case take the card back to the retailer and a have it changed.
If the card works on a different device, then it may be that the NV3 does not support 4 GB , there is no mention about max SD format supported in camera specs, or in the manual. In this case I suggest testing a 1 or 2 Gb card at the shop, and then buying right one.
Regards
Apr 02, 2008 | Samsung NV3 Digital Camera
Vivitar ViviCam 8025 Digital Camera Logo
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
