Question about Price Pfister T26-4CBY Avalon 4 Hole Kitchen Faucet with Matching Side Spra...
Valvers are open and no kinks in the hose still have slow water flow
    Genius:
  • 1,015 Answers
The first thing I would do is remove aererator from spout outlet. It should not be on very tight so you may be able to remove it by hand. If you are standing in front of faucet turn aereator clockwise or to your right to remove. If you cannot get it to turn wrap aereator with masking tape,duct tape or rag to keep from marring finish and use channel lock pliers or standard pliers to remove. There should be one or more brass or stainless steel screens and possibly a brass disc with a small hole in center. Also there should be a rubber washer that goes between faucet spout outlet and aereator. With all these removed , see if flow rate is improved. Carefully clean screens and disc. Reassemble in reverse order. Hope this helps.If this dosn't improve flow rate you may have to further disassemble vavle to find source of blockage. Thanks
Posted on Nov 11, 2010
I have a Miele g7856 and I just replaced the drain hose now I get a F2E code ?
The F 2E code indicates insufficient water coming into the dishwasher. Thus you should check that the shut-off valves for the incoming water lines are open. Make sure that the incoming water pressure hasn't decreased and that the water lines aren't kinked or blocked. You should also check the water inlet filters (at the screw connection of the hose) and the flow restrictor insert in the waterproof system.
Since the dishwasher was working before the drain hose was replaced, closed shut-off valves and kinked hoses are particularly likely. You may also want to replace the inlet hoses themselves. (Some anti-burst hoses will restrict the water flow if they detect a leak.)
I hope this helps.
Oct 19, 2016 | Miele Dishwashers
E 02 Error Message
There is a problem with the water supply. This could be a symptom of kinked hoses, clogged filters in the intake valve or low water pressure.
Turn off the water shut-off valves and disconnect the hoses from the washer and then the shut-off valves. Place a bucket under the hoses to catch any water that drains out of the hoses. Check the filters both on the washer and at the shut-off side of the hoses. Sometimes, you need to use needle-nose pliers to pull out the filters from the intake on the washer. Make sure that the hoses are not kinked when you reinstall them. You may want to replace the hoses. There are some hoses that will seal themselves if they detect a leak. This will slow the water flow to the washer.
While you have the hoses off the washer's intake, test the water pressure by measuring the water flow into your bucket when you open the valves.
Also make sure that the washer discharge hose is not below the washer's water level for your load size. This leads to the water flowing in and then out of the washer before it fills the machine.
I hope this helps.
May 05, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Low water flow
Make sure the hose behind the fridge is not kinking up, slowing down the flow rate of water.
Nov 17, 2011 | LG LFX23961 (226 cu ft) Bottom Freezer...
Cold water supply very very slow
This is a result of a restriction in any one of several places. Start with the washer off / unplugged from the outlet and shut off the water supply that feeds the washer's water supply hoses. The hot a cold water valves (those that are turned off independently of each other) should require the same number of turns to shut off. If not - one is open more than the other and could be a cause for the slow fill. Unscrew the hot AND cold water hose connectors from the washer. Inspect the inside of the connector to ensure there is nothing obstructing the hose itself. Make sure the rubber washer is seated properly, too. Check the entire length of both hoses to be sure there are no kinks or evidence of crushing. Also look for stretched circumference hose that indicate it could breakat any time. Damaged hoses should be replaced promptly to minimize chances of flooding should a hose burst. Hold the ends of the hoses inside the wash machine in such a way that splashing is reduced. Open the water supply and determine if the flow of water is the same or different for the hot and cold water. If the same, the problem is at / in the washer. If unequal flows are detected (with both valves opened the same amount) , the issue is probably with cold water supply or shut off valve. You'll probably have to call a plumber if the difference in flow bothers you that much.
If the flow is the same, it could be a problem with the water inlet or water supply solenoid inside the washer itself. Many washers have a strainer or filter inside the water supply connections. Check yours for foreign objects, debris or build up and clear any found.
Reassemble and and make sure connections are tight (do not use a wrench to tighten) enough to prevent leaking and turn of water supply. Operate the washer and compare cold and hot water flow while filling the tub. If still unequal, you'll have to either call for repair or look further for a restriction in the solenoid valve or deeper inside the machine if it bothers you that much or is painfully slow to fill.
I hope this helps and good luck. Please rate my reply - thanks!
Feb 08, 2011 | GE WBSR3140DW Top Load Washer
I HAVE A CODE F H THAT STOPS MY WASHER DURING THE 28 MINUTE DURING THE WASH CYCLE AND STOPS THE PROCESS WHAT DO I DO
F H shows when the water flowing into the machine( to fill it up) either does not flow when the control says to flow, or if the water continues to flow more than 10.5 gallons at one time, then the water inlet valve is stopped nd the F H is displayed.
press pause/cancel twice to clear the display. If no water is entering the washer, then chek the hot and cold valves are turned on and check for any kinks in the hoses. also, you may need to remove hoses from washer and check for dirt on the filter screens where the hoses attach.
If water entera the washer but there is too much (over 10.5 gal) then you havwe a whole host of other problems such as: drain pump slow or not working or clogged; pressure switch and small sensor hose to the tub are not dislodged or kinked; check wire connections to inlet valve and pressure switch, drain pump, flow meter, and centrol control board (CCU).
Good luck, Macgivor
Nov 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water flow of filter too slow
When was the last time you changed the water filter? If the filter is clogged from long usage it will slow down the water flow. Filters should be changed 6-12 months.
Jul 11, 2010 | LG LFX25971ST Bottom Freezer French Door...
Cold water filling of tub is extremely slow. No kinks
turn cold water off and remove hose from washer,next remove the screen from the water inlet and clean it and place it back in the valve, place hose back on the inlet,turn cold water back on and test cold setting,you should have good flow.
Dec 25, 2009 | Roper RTW4300SQ Top Load Washer
Moen Kingsley roman tub- no/slow hot water flow
sounds like you may have a little debri on hot side stem or kinked hose between valve and spout turn off water to house remove handle pull bonnet and remove stem turn water back on with stem removed see how water flow is be careful turning water on you could make a mess i am assuming the low pressure is in shower only
Apr 13, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Water flow very very slow though the pressure from main tap is fine
almost certainly not a fault with washer. check small filters in the fill hose and make sure hose not kinked
Jul 18, 2008 | LG WFT1071TP Top Load Washer
Price Pfister T26-4CBY Avalon 4 Hole Kitchen Faucet with Matching Side Spra... Logo
98 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
