Question about Samsung SCX 4200 All-In-One Laser Printer
My printer there is ''replace toner'' and it don't print. How do I solve it?
''replace toner'' & empty
Posted on Nov 23, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Faded printing issues with Brother MFC-9320
Try cleaning the corona wire on each toner cartridge. This may help solve your solution.
If this does not help try another thing.
Try and replace the toner cartridge. Maybe your toner cartridge needs to be replaced. Usualy when printed images are light or pale a toner cartridge replacement is recommended.
To see how to replace your toner cartridges check here
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
Drum motor noise
Need to open the entire printer, don't feelbad if you are capable you start to open other pl don't open it,its major issue..While printing main motor driving entire printer except fuser assm, entire printer load on Main motor assembly, in main motor assembly contains motor and gears, pl see the marked gear in snap I experienced this gear found warn out, this is suits hplj 5200 main motor gear, you can choose this gear and its easily available.. replace this gear, but opening the printer is difficulty.. thanks..
Feb 04, 2012 | HP® LaserJet M5035 MFP Laser...
Toner exhausted and replace toner how can solve this error without replace new cartridge
When the toner cartridge is exhausted or empty then the printerwill not be able to print further documents or the prints will be very faint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Jul 15, 2011 | Samsung SCX-4300 Monochrome Laser...
How to solve toner exausted problem through software
You cannot solve this problem with software. You need a new toner cartridge or a re-manufactured toner cartridge.
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
May 15, 2011 | Office Equipment & Supplies
I have refilled my TN2130 toner catridge, resetted it etc. It is now printing dirty printouts with too much ink on pages
You don't have say the model no. Of your printer. But don't worry I'll try to solve your problem. First check the tonner you have refilled was not bad and damped. Check also the paper you use is not damped or bad quality. Make sure the printer settings or resolution has not been changed. If you have refilled the toner cartridge for several times then the cartridge may need replace. Clear the cartridge carefully by cotton with a light touch. Check the printer settings and page setup. If it doesn't help you to solve your problem then you have to change the cartridge.
Apr 25, 2011 | Office Equipment & Supplies
There is a white stripe (miising writing) in the middle and in the left side of the printed paper. i have changed the toner, but the problem doesnt solve. maybe its the laser motor dirty? thnx for any help
Problem : white stripe (missing writing) in the middle and in the left side of the printed paper
Printer Laser Printer MF5650
Cause of the problem Dust
Solution Cleaning ..
There could be reasons for your problem
1) The TONER CARTRIDGE not clean - i think you replaced it
2) The Imaging Drum
3) Beam Alignment Lance (glass which reflect the rays)
1) there are toner and the drum
2) take out the Toner cartridge
3) there is a black roller on Toner Unit - clean it with the Cotton
4) Take out the Drum clean it (Don not use water or spirit to clean it )
5) Fuser Unit a Hot Unit the Red Color Roller no need to clean ..
Following Video will show you the over view of the Product
Video 1 use full video help you to understand the whole process
Jan 03, 2010 | Canon LaserBase MF5650 All-In-One Printer
Hi, I have a Samsung ML-1710P. Have just bought a new toner cartridge, when I print the paper ejects but with all the printing is done at the lower part of the page and the red error light shows. Having...
No need to buy another printer,it is good printer now this time Just thoroughly service it then solve your problem.How much money the new Toner please comments me.I shall help you.How can possible? use it simple coast.
Sep 18, 2009 | Samsung ML 1710 Laser Printer
Scx4300 toner exhausted problem
It sounds like you need a new Toner cartridge
Jun 24, 2009 | Samsung SCX-4300 Monochrome Laser...
Toner exhausted replace toner in Laser Printer SCX-4300
My laser Printer shows a message and do not prints any document. When i try to print any document. My printer shows a message "Toner Exhausted, Replace Toner". Plz tell me how can i solve my this printer's solution.
Mar 25, 2009 | Samsung SCX-4300 Monochrome Laser...
Samsung SCX 4200 All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
