Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
Today when I connected my maxtor portable hard disk, it was emitting some noise. my Pc was unable to pick up the drive. I tried with another pC. problem is same. it is about 18 months old and i have lost the invoice
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 11, 2010
I have a Maxtor one touch III 750. When I connect the drive to my PC and turn on the HD, it makes clicking and beeping sounds and wont connect or start up. Is there any way to retrieve that data from the...
Any Un-usual noise from the Disk is not a good sign. you can try the following
1. Try the device on another Computer.
2. Remove the Disk & try on Another Enclosure )Get some help if needed)
May 08, 2010 | Maxtor 1.5TB 7200RPM 16MB USB...
How to Connect Maxtor OneTouch 4 Mini 320Gb to PC
I have one as well running along with a PC. PCs and Macs are formatted differently. Go to www.maxtor.com and create a search for reformatting from a Mac to a PC with your Operating System in the search as well. Should have no problems after doing that. It will tell you and or show you where and how to reformat.
Oct 01, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor basics 160gb portable hard drive is showing error performi
go to my computer p[roperty then hardware -> device amnager then uninstall usb drivers from it then install aagain.
then connect your harddisk then it found.
Jun 23, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
Maxtor Basics external portable hard drive not getting detected
Right Click on My Computer, click on Manage, go to Disk Managment, if the drive is available you will see it there. Check to see if it has a drive letter assigned to it, if not right click on it and choose Change Drive letters. Make sure you are on the external drive though, you don't want to change your C drive accidentally. It should pop up in My Computer.
May 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Maxtor Portable 320 GB External Hard drive doesn't show on my Mac
If you can get a 3rd party disk utility like DiskWarrior because if the disc information has corrupted the computer cannot see it, the utility will re write this and if the drive is OK it will re appear
Dec 07, 2008 | Maxtor Hard Drive
Unable to see the 250Gb external drive shown on 'my computer' when plugged in
Hi - thanks for your quick response, much appreciated .........I will try again to explain!!
We have purchased a 250Gb Maxtor portable hard drive which I was told was plug and play. We have followed the instructions for connection but no drive letter is showing up and the external drive is lit up and making a constant beeping noise. The computer doesn't seem to be recognising that an external drive has been connected.
To test our computer out I have connected an 8Gb memory stick to the processor and it shows up as drive H immediately.
FYI - we have XP running on our machine.
Hope you can help!! Thanks
Oct 25, 2008 | Maxtor MaXLine Plus II 250GB 7200 RPM...
Broken portable hard drive - Maxtor (750)
I HAVE A RECOVERY UNIT IN MUMBAI INDIA . YOU CAN GET MY EMAIL ADDRESS FROM THIS SITE .. WE CAN BEGIN FROM THERE AS THERE IS A HARD DISK DAMAGE WHICH HAS TO BE RECTIFIED
Jun 13, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
I have a Western digital model wd2500b007-rnn
and I cannot get either my PC or my laptop to recognize the drive. I isolated the drive to another computer with the same error. It says USB device not reognized. I also tried a different port. I have not tried different cables. Can I retrieve the old data on the drive?
Did you find a resolution for this? I am having the same problem. None of my PCs can recognize the drive. Formatting seems to be the only choice but I need to recover my old data first.
Jun 06, 2008 | Computers & Internet
Help with Maxtor onetouch 4
The Maxtor OneTouch 4 Mini is a portable hard drive, with USB interface.
What you have to do is, just connect your Maxtor OneTouch 4 MiniT to the one end of USB cable, after that insert he other end to your laptop USB por.
Wait for few moments your operating system will read your new connected portable hard drive.
After that you can find a new drive letter in your My Computer, thats for your portable disk drive.
thanks
Iqbal
Mar 10, 2008 | Computers & Internet
Maxtor Personal Storage - beeping noise
consult the authorized service cenetr of amxtor as they can recover data from damged hard disk . carefull while connecting to pc . as it can damage pc if circuits are broken
Dec 03, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
62 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
