Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Bonaire evaporative water keeps running whne the unit is turned off
    Genius:
  • 1,015 Answers
I would check electric solenoid valve on water line to make sure it is shuting when power is off to blower. Some of these valves can be taken apart and cleaned if it has debris stopping valve ffrom fully closing. To do this shut power off to unit, shut main water supply to cooler. Usually there are four screws holding top cover on valve remove these,remove cover and clean valve. Reassemble making sure that cover gasket is in good condition and properly placed. Turn water and power back on and try unit. Hope this helps you. Thanks
Posted on Nov 11, 2010
Bonaire vulcan evaporative air conditioner
check your filter for dirts, clean or change it, check your evaporator and condenser coil and clean....
Jan 29, 2014 | Heating & Cooling
Bonaire evaporative cooler
Those pumps tend to pick up a lot of dirt and debris. You will have to take it apart and see if something is stuck in the pump or the tubing from the pump to the distributing bars.
May 22, 2013 | Dishwashers
Our bonaire evaporative unit will not switch on. l rang customer service and they advised l reset the unit as we recently changed the batteries l did the reset but the unit still does not work and after...
try reset the controller. turn off power to the unit then remove batteries from controler. press the power button on the controller to remove residual power. turn on the unit then install batteries. turn on controller within 4 minutes of turning on unit
Nov 23, 2010 | Mastercool 67471 Evaporative Cooler Air...
Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
Hi my Bonair Evaporative Cool is blowing hot air and the pads are dry,how can i fix it.
am assuming it is full of water, so you need to check to make sure the pump screen is not clogged up. make sure and unplug the unit before working on it. after checking the screen/filter, leave on panel off, plug it in and turn it on, look to see if you have any busted hoses that are leaking. if all seems ok, then you have a bad pump or switch.
Feb 03, 2010 | Mastercool 67680 Evaporative Cooler Air...
Ive got a mildewy smell coming from my evaporative cooler how do i get rid of it?
This unit needs to be serviced. Try replacing the pads with the sponge like pads.Drain the old water and clean up the pan and pump area. Go down to a pool supply store and buy some chlorine tablets and add to the water. In fact, they make these tablets just for the evaporator units. There are 3 states to water, solid, liquid and gas,
. This will get rid of the smell.
Sincerely, shastalaker7
Oct 28, 2009 | Mastercool 67471 Evaporative Cooler Air...
We bought a Bonaire cooling system at yard sale, it leaks water after it is running for awhile, plus it sprays water out the front
I take it this is a window Unit , the water is coming in the room because the Unit has to be pitched about 1/2 into the back ( outside ) or the drain line is clogged ( dirt) stopping water from flowing to condenser ( that cools the coil)
The water is condensation from warm air hitting the cold coil .
Jul 17, 2009 | Mastercool 67471 Evaporative Cooler Air...
Bonaire Cooling system that stopped working after power failure..
Unplug the unit or turn off the breaker to the unit for at least 30 seconds. If this reset does not work, the electronics may be damaged and need a repair person.
Jan 30, 2009 | Mastercool 67471 Evaporative Cooler Air...
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
505 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
