Question about Sport & Outdoor - Others
I am looking for Magtech 586 P pump action Gun owners manual
D669090 is the serial # of my Stevens 79 pump gun 30 barrel wanting to know the year it was made.
Have a read of these articles.
I Have Stevens Modle 79 Shotgun And Would Like To Know Rough ...
www.gunvaluesboard.com/i-have-stevens-modle-79-shotgun-and-would-like-to-kno...
  1. Cached
  2. Similar
I have Stevens Modle 79 shotgun and would like to know rough. ... hello,,your stevens model 79 pumpgun would be worth roughly around ... Serial number .
The Gun Digest Book of Exploded Gun Drawings: 975 Isometric Views
https://books.google.ca/books?isbn=0896891410 Harold Murtz - 2005 - ‎Antiques & Collectibles 845 Model 79-T Slide-Action Shotgun 845 Model 99 Lever-Action Rifle 846 ... 99C Lever-Action Rifle 847 Model 99C Series A Lever-Action Rifle (Serial No. ... Rifle 850 SAVAGE/STEVENS Model 89 Lever-Action Rifle 851 Model 94C Series M ...
Stevens 79 Shotgun Manufacture Date? - FirearmsTalk.com
www.firearmstalk.com > ... > Long Guns > General Shotgun Discussion
  1. Cached
May 19, 2011 - Twelve years ago I purchased a Stevens model 79 pump 12 gauge shotgun with a 30" barrel used. The serial # is 0982XXX. Does anyone ...
Stevens 79 Manufacture Date? - Long Range Hunting Online Magazine
www.longrangehunting.com > ... > Shotguns And Shotgunning (NOT Slugs)
  1. Cached
May 26, 2011 - 1 post - ‎1 author Twelve years ago I purchased a second hand Stevens model 79 pump 12 gauge shotgun with a 30" barrel and full choke. The serial # is ...
Nov 23, 2016 | The Optics
Anything you can tell me about Winchester Model 97 Ser# 201413. when it was made and value.
The Winchester Model 1897 evolved from the Winchester Model 1893. The Model 1897 and 1893 were both designed by John Browning. The Model 1897 is an external hammer shotgun lacking a trigger disconnector. This means that the user can hold the trigger down while cycling the shotgun and once the action is returned to battery the gun fires. The gun itself is classified as a slide action pump shotgun. It was the first truly successful pump-action shotgun produced. Throughout the time period the Model 1897 was in production, over a million of the type were produced in various grades and barrel lengths. 16-gauge guns had a standard barrel length of 28 inches, while 12-gauge guns were furnished with 30-inch length barrels. Special length barrels could be ordered in lengths as short as 20 inches, and as long as 36 inches. Along with various grades and barrel lengths, the Model 1897 came in two different chamberings. One was the 12 gauge and the other was the 16 gauge. The shells should be of the 2-¾ inch or 2-? inch model. Any shells larger are not recommended. An average Model 1897 held 5 shotgun shells in the magazine tube. After including the one shell that could be held in the chamber, the average Model 1897 held a total of 6 shotgun shells. However, this would vary from grade to grade. When working the action of the Model 1897 the forend (fore grip) is pulled back, forcing the breech bolt to the rear which extracts and then ejects the spent shell while simultaneously cocking the external hammer by pushing it to the rear. When the forend is slid forward again, the breech bolt pushes a fresh shell into the gun's chamber and locks into place. This action of sliding the forend back and forth (pumping) is why the gun is classified as a slide action (or pump) gun.
Oct 23, 2016 | Winchester Optics
How do I get the plug out that is in the chamber its a new gun
If you mean the MAGAZINE plug, look at your owner's manual:
file:///C:/Users/Guest/Downloads/om_870.pdf
It starts on the bottom of page 11
Sep 27, 2014 | Remington Model 870 Express Deer Pump...
I bought a Remington 870 at Christmas time. The first time i shot it the shells are jamming in the gun. I took it home cleaned it and oiled it real good. Went and shot it again same problem. Either...
If the 870 is a Magnum model it should accept 3" shells. After making absolutely sure you have an unloaded shotgun, both chamber and magazine are empty, empty, empty, proceed with these few checks.
Assuming it may be a 2 3/4' model, have you double checked on the left side of the barrel near the receiver? There will be gauge and shell length stampings on the barrel. If you are jamming 3" shells in to a 2 3/4" shotgun you will get jams as you describe. Look at the empty shell casings if you have any and see if the shell appears to be damaged from the chambered and firing process. This could also indicate you have a improper shell length issue.
If you are shooting reloaded ammo make sure it has been properly re-sized, crimped and reloaded.
sloppy reloading of shotgun shells can cause jams as you describe. Improperly re-loaded shells can also cause leaks of bb's, (shot) in to the receiver and bore area.
Check for a loose bb. or bb's, (shot) in the receiver and chamber area. A lodged bb. in these areas will cause problems you have described.
Run your fingers along the barrel and visually check it for any slight bulge. If you detect or suspect a bulge do not shoot or load the shotgun until a gunsmith or the factory check the barrel thoroughly. If someone had loaded a 20, 16 or similar smaller guage shell in the chamber by accident and the gun was fired it will usually cause at minimum a stressed and bulged barrel. Many times a slight bulge in the barrel may not be visually obvious.
Most of the time if a 12 gauge shell gets loaded behind that one and fired you will have catastrophic failures, i.e. the gun can blow up and cause serious harm, blindness or even death in rare cases to the shooter. Shooters call this a "20/12" catastrophic failure. This type of accident is not to be taken lightly! this is why shotgun shells of different gauges are different in color normally.
Never ever, mix shotgun gauge shells in a pouch or box.
If you pump the shotgun too easily, (i.e. wimpy) it can jam up. Always pump, "rack" a shotgun with vigor. I'm not suggesting abusive action, just don't be slow or overly gentle with the pump action that ejects a shell and reloads the next one. Something related to this is if your action/slide bar is out of alignment or has become torqued out of it's proper alignment this will cause problems as you have mentioned. The action/slide bar is a long single piece of flat metal that is in alignment with the barrel and is attached to the front forearm of the shotgun. This is the flat piece of metal that actually makes the action open and close as you pump the shotgun. There is one on the left underside of the bore and forearm of the shotgun. When you pump the action you will easily observe it moving with your pumping action.
Check how the empty action feels to you. While dry-firing, (using an unloaded shotgun), does the action feel smooth or perhaps, gritty, sluggish, overly tight? If any of the later the you need to double check for debris, shot, excessive old lubrication, gumming of the action, a bent action/slide bar, etc. A normal 870 has a very smooth action.
Also, check the bore for any obvious nicks or obstructions that don't belong there. A good quality shotgun such as your 870 should operate best with very little lubrication. Excessive lubrication over time can cause gumming up of the receiver area. Also, improper lubrication products. Improper lubrication can cause problems you have described.
I am not a gun smith. I am simply an avid gun enthusiast. If you have any doubts as to anything that you observe while performing these basic checks on your shotgun, I strongly advise you to call the factory or take it to a local gun smith. Many gun shops will give your shotgun a courtesy check over and if you don't find a solution, many times they will within a few minutes. Do not be embarrassed to take the gun in to a gunsmith! Trust me, they will most likely treat you and you gun with respect and courtesy. Otherwise they won't be in business much longer.
If the gun shop fixes your problem make sure and purchase some shells and perhaps something else from them. We must support our small business firearms dealers and gun smiths
Hope this helps you!
Feb 02, 2011 | Remington Shotgun Mount 12Ga Lh, B Square...
McCulloch FH160G has weak spray
There isn't much in the owners manual in the way of repairing this issue, asside from just replacing the gun. Most of the time it's as simple as an o ring, but because of their design it's easier just to replace the gun. But here's a link. http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-FH160G-6096160G04-966989801.pdf
Apr 21, 2010 | McCulloch 1400 Psi Electric Pressure...
Looking for a Free PDF manual for Mastercraft Snow Blower Model #319 586 515 that I can print. Is there such a thing?
Your snow blower was made by MTD. You can go to outdoordistributors.com/mtddoor.htm. Put in the model 319-586-515, This site will bring up a parts list and diagrams. Some are not an exact match to your model but I believe it will help with what you are looking for.
Good Day.
Oct 26, 2009 | Mastercraft Garden
Engine runs well but hardly and water comes out
A pressure washer pump shouldn't have to be primed, as it is under water pressure from your hose. You're right, the problem is somewhere in the pump. Try looking for the owners manual online. You can find most on the manufacturers website. no charge. See if the troubleshooting guide in the manual helps.
Mar 26, 2009 | Garden
Sport & Outdoor - Others Logo
319 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
