Question about Essick Air ED11800 Humidifier
It would seem I can't get my humidifier to work.It is a Essick Air ED11800.I have got it against a interior wall away from any heating vents,changed the filter,and set the humidity level at 60%,ran it for up to 48 hrs on high and it will not, or has not, left 45% humidity. It uses the heck out of the water ,I am with in the square footage suggested,so I am at a loss! Any Ideas would be very helpful!
    Genius:
  • 1,015 Answers
If you are using large amounts of water and it is not leaking anywhere than I would be inclined to think that your humidity indicator is not correct. Do you notice any differences since you have been using it,such as less static electricity,skin and hair not as dry as usual or house plants looking better if you have any. Also not knowing what area you live in I don't have any idea what your normal atmospheric temperature or humidity are. Other factors to consider is how well your house is insulated,number of doors and windows and how many times doors are opened. Without knowing these things your humidifier may be doing all it can. Hope this is of some help.Thank
Posted on Nov 11, 2010
Testimonial: "Thanks I will keep it in mind!"
New filter, not running and leaking all over
Customer Reviews: Essick Air 821-000 Digital Control ...
www.amazon.com/Essick-Air...Humidifier/.../B0000D...
Amazon.com, Inc.Essick Air 821-000 Digital Control Evaporative Console Humidifier ... Holds 6 gallons and will dump 6 gallons in to the air over a 24 hour period, which ... a pain to fill, eventually leak, or come defective from the factory (holes on seams). ... We left itrunning all night, and barely any water had evaporated by the next morning.
www.amazon.com/821...Humidifier/.../B0000D8EJZ?...
Amazon.com, Inc.Essick Air 821-000 Digital Control Evaporative Console Humidifier ... So although notas dry as the northeast, it gets dry when the temps go down. ..... Had this humidifierfor less than three months and it started leaking all over my hard wood ...
Jan 05, 2016 | Essick Air Humidifiers
Changed wicks and change wick light is still on. how to reset?
Humidifiers - Frequently Asked Questions - iAllergy
www.iallergy.com/humidifier_answers.html
Do I need to replace filters, and if so, how often? ... quietest humidifiers available, and the ideal choice when noise level is a concern (if you are a light sleeper). ... Most evaporative cool moisture humidifiers use replaceable wick filters, and these should bechanged every 2 months on average (wick filter life varies depending ...
[PDF]OWNER'S CARE & USE MANUAL - Appliance Factory Parts
www.appliancefactoryparts.com/content/pdfs/116710-1.pdf
Refill light with Automatic Shutoff. • 2-Speed Fan ... If it still does not fit, ... Thishumidifier is ETL listed with Essick Air brand evaporative wicks in place. ... wick, the water evaporates into the air, leaving behind any white dust, ... We recommendchanging the wick ... Use only Essick Air brand replacement wicks and chemicals.
Amazon.com - AIRCARE 1041 Replacement Console Wick ...
www.amazon.com/...Replacement...Wick/.../B0002GD...
Amazon.com, Inc.AHAM certified output; Longer lasting, still at 96-2/5-percent after 90 days; Less energy consumption ... Essick Air 1970 Humidifier Bacteriostatic Treatment, 1-Quart ... BestAir CB41 Essick 1041 Replacement Wick Filter ... Super Wicks trap minerals and other particulates to prevent white dust and sprays, which are often seen ...
Jan 04, 2016 | Humidifiers
Why ismy Essick humidifier registering over 20 on the humidity level. I have changed the filters several times using high end filters?? I also have wet the filters
Sorry to ask, for clarification is this a dehumidifier or a humidifier? Do you want to add water to your air or take water out of your air. A reading of 20 for a humidifier sounds pretty good to me. I didn't know there were filters on a humidifier, I thought most of the time you just filled the tank with distilled water, it got heated and vapor came out. I guess a filter to keep airborne bacteria from floating into the water tank would make some sense, maybe a water filter to pre-filter the water going into your humidifier, but I don't think any filter is your problem. If you are trying to remove water from your air, then a dehumidifier is needed and you just have to empty the tank when it's full.
Feb 19, 2015 | Essick Air Humidifiers
How do you reset the cf on essick humidifier
I just changed the filter and it started flashing CF. How do you reset this other than changing the filter?
Feb 04, 2013 | Essick Air Humidifiers
Just bought this humidifier yesterday -- cannot even get the fan to turn on....
Check that the light switch is on for that plug socket. Keep the receipt, its probably defective. Take that POS back to where it came from
Jan 22, 2011 | Essick Air ED11800 Humidifier
Cant get float area put back together
It can be a pain in the ****! You have to take the long handle peice,clip it back to the front of the humidifier,right to the right front of the unit top corner you should see a spot that is where you clip that handle to,it goes on a certain way,I learned by trail and error to make it work.Then you must put the float in the circle holder there is a hole in the top of the lid where the float sticks into,you have to hold the float into that hole and make sure it stays in there or it wont work.I wish I had a picture to show you sorry best I could do.
Nov 05, 2010 | Essick Air ED11800 Humidifier
Essick Air ED11800 Humidifier Logo
334 people viewed this question
Top Essick Air Humidifiers Experts
Mack Baxter
Joseph Mueller
Joseph Mueller
R Daniel Wolfe
Are you an Essick Air Humidifier Expert? Answer questions, earn points and help others
