Question about Belkin (F5D7633UK4A) Wireless Router
How to setup or enable wi fi from belkins to laptop wirelessly
  • Belkin Master
  • 7,733 Answers
  1. Connect the computer to one of the four LAN ports on your router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. Click on "Use as Access Point" on the left-hand side of the opened page.
    Select Enable. This will give you the options to set the IP Address and Subnet mask for the router. These settings should match your existing network settings; by default the IP address will be set to 192.168.2.254 and the Subnet mask will be 255.255.255.0
Alternatively:
1. Click on LAN settings in the left hand menu.
2. When the LAN settings page opens you will make two changes.
Change the IP Address to something such as 192.168.2.47 or you can use 192.168.2.200. As long as the first three sets of numbers match your existing network, you will be fine.
3. Secondly you are going to how to setup or enable - dhcp%20server.jpgff the DHCP server.
4. Click the Apply Changes button.
Posted on Nov 11, 2010
Router light turned into orange after changing password. i changed my router password and when i saved the new password the website told me something like 20 secs remaining. i had no idea what to do a
Sir
Please proceed with the instructions below.
Step 1:
Enable the Wi-Fi feature of your mobile device. Look for the wireless network name (SSID) of the WeMo Light Switch which will be WeMo.Light.xxx and tap it to connect your device.
QUICK TIP: If you have multiple WeMo devices, connect to the one with the same WeMo ID at the back of the device. The WeMo ID is the word WeMo followed by WeMo model,and then three (3) alphanumeric characters.
NOTE: To know how to enable the Wi-Fi feature of your mobile device, refer to your device\'s manual.
Wait until you are connected to the WeMo Light Switch network. A successful connection is indicated with check mark beside the WeMo Light Switch (SSID).
Step 2:
Launch the 7c714365-1d70-4873-b4f9-e5ddfff23375.pngApp.
Step 3:
Tap the wireless network name (SSID) of your router and enter the password when required.
NOTE: WeMo can only connect to your 2.4 GHz network.
Wait while the WeMo App attempts to connect. If the WeMo encounters difficulty connecting to the Wi-Fi network, try refreshing your mobile device\'s Wi-Fi and try connecting again. For more troubleshooting instructions,Click Hear,
The Remote Access Enabled message will then pop up. By default, the Remote Access feature is enabled.
Step 4:
When the WeMo Light Switch setup is completed, tap Done after viewing the information of the device.
QUICK TIP: You can customize the Name, Device Icon, and Email of your WeMo Light Switch. It is recommended to enable the Remember Wi-Fi Settings option so the WeMo App will automatically connect to your wireless network once it is in range.
The WeMo App will then refresh, look for devices and automatically detect your WeMo Light Switch.
You should now have installed the WeMo Light Switch with the WeMo App.
With the WeMo App, you can create different rules for your WeMo Light Switch.
If you Still having Belkin Basic Wireless Router Problem then visit official Belkin Website Support Belkin Problems,
Or
In Case You still need online Belkin Router Help,then follow us on for Belkin Support
Feb 27, 2014 | Belkin Basic Wireless Router
Enter client device pin
The client device PIN is a WPS method to connect to the network
I would suggest you disable the WPS feature and go with standard WPA or WEP
To get the PIN :
Turn off / Disable wifi in the laptop
  1. - Hardwire the computer and router
  1. - Open the router setup page ( http://192.168.2.1 )
  1. - Click wi fi Protected setup on the left side
  1. - Scroll down a little and you can find the router PIN
  1. - This is the number that you need to enter in the device
To Enable WPA Security in the wireless network
  1. - Leave the password blank and click submit
  1. - Disable Wi Fi Protected setup at the top and click Apply Changes
  1. - Click Security under wireless on the left side
  1. - Change the security mode to WPA
  1. - Type a password
  1. - Save the changes.
Dec 17, 2013 | Belkin F5D8631-4 Router (F5D8631au4A)
How to set up wireless printer on windows 7 net book
I have just bought an epson sx435 wireless printer. I have set it up on my xp desktop with usb cable. How do I set it up to be wireless on xp
and how to I set it up on my Acer Aspire one 522 netbook running windows 7.
Home > Printer Wi-Fi Setup Setting up a Printer Wi-Fi Network Using the Control Panel Using the Wi-Fi Setup Wizard with LCD panel WPS setup You can set up a Wi-Fi network for your printer by using the printer's control panel. Using the Wi-Fi Setup Wizard with LCD panel If your printer has an LCD panel, you can use the Wi-Fi Setup Wizard to simplify manual setup. mark_no.gifNote: This setting is not available for all printers or may not be enabled. Make sure that the Wi-Fi is enabled on your computer in advance. Check the SSID and password for your network as these are required during Wi-Fi setup. If you do not know the SSID and password, check with your network administrator. For step by step information on setting up a Wi-Fi connection using the Wi-Fi Setup Wizard, click the following link. This feature is not available for all printers or may not be enabled.
exlink.gif../p_body/panel/wizard/manual_01.htm
Well to start with xp look at the following.
http://support.epson-europe.com/onlineguides/en/sx430sx435w_nwg/html/index.htm
May 30, 2012 | Computers & Internet
I was on my ds and i went to Nintendo wi fi settings and it asked me to input my wep key and now i cant figure it out.
BELKIN ::::
Hi ,
By Default the security in the Belkin is WPA and unfortunately the DS Doesnt support this
To enable WEP in the Belkin follow the Steps Below
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Feb 13, 2011 | Belkin Basic Wireless Router
I was told by our Satellite Service to "secure"
Dec 21, 2010 | Belkin (F5D5231-4) Router
How do i reset my wps orange light stays on no internet
Sep 23, 2010 | Belkin (F5D7231-4) Wireless Router
Linksys WRT160 router doesn't work
Wi-Fi Protected Setup Button
If you have client devices, such as wireless adapters, that
support Wi-Fi Protected Setup, then you can
use Wi-Fi Protected Setup to automatically
configure wireless security for your wireless
network(s).
To use Wi-Fi Protected Setup, run the Setup
Wizard, or refer to the “Wireless > Basic Wireless
Settings” section of “Chapter 3: Advanced
Configuration".
Wi-Fi Protected Setup LED (Blue/Amber) It
lights up blue when wireless security is
enabled. The LED flashes blue for two
minutes during Wi-Fi Protected Setup.
The LED lights up amber if there is an error
during the Wi‑Fi Protected Setup process. Make
sure the client device supports Wi‑Fi Protected
Setup. Wait until the LED is off, and then try again.
The LED flashes amber when a Wi‑Fi Protected
Setup session is active, and a second session
begins. The Router supports one session at a
time. Wait until the LED is off before starting the
next Wi-Fi Protected Setup session.
Jan 01, 2010 | Linksys WRT160N Wireless Router
How can i ins tall my rangemax dual band wireless-n router wndr3300 to my laptop to setup wifi in my house
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | Computers & Internet
Have a linksys router and adapter not sure how to install, my daughter wants to use her laptop but cant get the internet
http://1921.168.0.1
Thanks.
Aug 29, 2009 | Linksys Wireless-G WRT54GS Router...
Wireless device disabled
Go into setup routine and enable wi-fi.Save and exit. Usuall you have to press delete or some other key when first turned on,to get into the setup screens and BIOS.
Dec 27, 2008 | Toshiba SATP L300D Notebook
Belkin (F5D7633UK4A) Wireless Router Logo
44 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
