Question about GE JE1660 Microwave Oven
When I turn on my microwave it is making a sparking sound and I see a flash of light behind the panel that is inside on the right. It's still working at the moment. Why is it sparking? What is wrong?
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave problem
That panel is probably mics, not netla, though it may look like metal. The job of the waveguide cover is to protect the waveguide (opening) and the magnetron from buildup of food particles and grease. When the grease and food particles build up on and behind the cover, they will carbonize and arc - and maybe even flame up! The solution is to clean it and keep it clean - but if it's too dirty or is burned, it must be replaced. Sometimes it's necessary to remove the cover to clean both sides of it, and to clean the edges of the opening it covers. It is sometimes held in place with a small plastic rivet (or screw) and once that is removed, the cover will slide over a little then drop down. Be VERY careful not to get cut on the potentially sharp edges of the opening, and do not spray anything into the opening. Apply an alcohol-based cleaner (such as the purple kind) and /or gentle scouring powder to a cloth or paper towel and carefully wipe it out, then when it's dry, reinstall the cover and the rivet. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics.
Posted on Apr 23, 2007
  • 833 Answers
SOURCE: microwave ovens
The cover is probably the magenetron. That is where the microwaves come from. If the bread was moist, it might have left condensate in the unit which is causing the sparking. Unplug the unit, leave the door open over night. If you can remove that cover, do so. Be sure to carefully replace it before using the unit. Never turn on a microwave with nothing in it.
Posted on Dec 17, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave started sparking and making
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
Posted on Aug 08, 2008
tiway1
  • 100 Answers
SOURCE: Makes a loud humming sound and blows fuse behind controll panel
Most likely a shorted capacitor is causing the fuse to blow. Easy and cheap to fix.
Check with www.martinmicrowave.com or call toll free 1-877-894-0035 for parts info
Posted on Sep 06, 2008
  • 181 Answers
SOURCE: microwave not working
faulty relay or solder joint on the power module, but a bad door switch is most common.
Posted on Nov 13, 2008
GE Spacemaker XL1800 sparking from behind wave stirrer cover
Microwaves use a magnetron to generate microwave energy and direct it a rotating blade wheel to spread them around the inside of the oven. If there is any metal in the area to be heated, or any of the blades are bent, even a bit, the microwave energy can be reflected back up to the magnetron area. In this area there is now too much power and it sparks away, so it does not heat the item in the oven.
Because it is sparking it is now a safety hazard the sparks may melt and set fire to plastic parts in it. This is serious it could burn your house down. Bin this microwave and cut the cable off it to make sure no one else ever uses it.
Dec 20, 2013 | GE Profile Spacemaker JVM1871 Microwave...
Kenmore microwave 80082 sparking from an inside panel
If your positive it is not arcing behind the waveguide cover I would think it has to be in the control area. You will have to turn off power to the unit and remove the control panel and look to see if you can find any burn marks or soot, to indicate where your problem may be. I have found burnt connectors at the relays or even possibly burnt wires to the door switches. Careful! the capacitor on these can hold a charge for a long time and can shock you pretty good. Only work on something like this with the power to it off and the capacitor discharged. Microwaves do not come through the little round holes those are typically an RF screen to prevent microwaves from getting through. A lot of times that is where the cavity lamp shines through.
Aug 14, 2017 | Microwave Ovens
When I turn on the microwave to heat anything, it makes a sizzling, cracking noise, and kinda looks like a fire, on the right hand side, as you are facing the microwave.... There is a screen area with the...
It sounds like what you are talking about is an issue with the waveguide cover. It is usually made of a material called Mica. Its purpose is to cover the aperture through which the microwaves enter the oven cavity from where they are produced by the Magnetron behind the control panel. It stops moisture and food particles getting into the "workings" of the microwave.
if your microwave is working ok and behaving itself then there is nothing to worry about, but there may be one of 3 problems that may arise which should be rectified.
1. Its fallen off.
2. It has a hole in it.
3. It is arcing or sparking during use.
In any eventuality it should be replaced. If it has fallen off or got a hole in it then there is the risk of food or moisture getting into the waveguide which will reduce the efficiency of the oven. If it is arcing or sparking then continued use will damage other components in the microwave including the oven cavity which could be costly to rectify.
If there are any issues with your waveguide cover it should be replaced. When new the mica sheet is rigid and firm. Over a period of time it absorbs moisture and gets food splatters on it. It then becomes soft and flexible. The cover can be replaced either with a suitable replacement made by the manufacturer of the microwave or if the old cover is in good enough shape to be used as a template, blank sheets of mica can be purchased and cut to fit.
Jul 07, 2011 | Dacor DMO24SS Microwave Oven
I have a GE JE1860SH04 cabinet mounted microwave oven. Intermittently, what appears to be sparks appear behind a platic cover in the right hand side panel. I think behind this panel is the magnatron,...
there should be a way to access the area to look at it closer,probably will be able to see some kind of flash mark{black burnt look} were it has been sparking.this should give you an idea of what the problem is.guessing it"s a wire coating problem or short
Oct 11, 2010 | GE Microwave Ovens
Sparks when micro turned on. it appears the pannel
Yes if you can find someone to supply it as a spare part. Clean any grease or debris from behind it too. Often there are little plastic rivets that hold it on. You might as well order them too. If it burnt too bad there will be a carbonisation on the panel too which must be cleaned off as it will attract the microwave energy.
Before ordering anything, remove the burnt panel and run the microwave with just a cup of water in it to make sure it still works fine.
Whatever you do, do not open up a microwave oven cabinet, they are very dangerous inside. If you cant remove the panel from within the cooking cavity then leave well alone and get an engineer to look at it.
Aug 04, 2010 | Dacor DMO24SS Microwave Oven
Sparking behind the wave guide in model NN-T664
The antenna on the magnetron is wearing out becuase it is damaged. Replacing the antenna from another magnetron normally solves his problem.
May 13, 2009 | Panasonic NN-T655SF Microwave Oven
Sparks
usually sparks come from turning and cooking with nothing inside the microwave..if there is grease or something on the bottom the heat will generate a spark
Mar 22, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Sparks pops odd burned smell
I would certainly take it to a repair shop if you want to try and salvage it. Until then keep it off and unplugged.
Feb 14, 2009 | Frigidaire PLMV168 Microwave Oven
GE microwave -crackles and sparks as if metal inside
The problem you are having is that the magnetron that does the heating is shorting out and it needs to be replaced before it damages the inside covering of the microwave. www.mwoparts.com is a good source for magnetrons or other similar sites. To replace is easy enough. Taking the cover off with the power off, you will find it behind and on the top right side of the control panel. It is held in place normally with just 4 screws and two wires with terminals attached to it. So removing and replacing is pretty straightforward. Just be sure all the power is off until you have everything back in place. Good luck.
Jan 23, 2009 | GE JES738 Microwave Oven
Short circuited Whirlpool MH1150XM while changing the bulb underneath. Need help to fix it, thanks :)
We replaced the board behind the control panel. $130.00. If you do this make sure you can put the wires back the right way. My husband finally got it and our micro is working like brand newThanks to all who tried to help.
Sep 29, 2008 | Whirlpool MH1150XM Convection/Microwave...
GE JE1660 Microwave Oven Logo
69 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
