Question about HP LaserJet 2430dtn Printer
My hp laserjet 2430 keeps showing paper jam on tray 2 but no paper jam there. I have to press the ok button always to proceed. what could be the problem
  • HP Master
  • 7,733 Answers
Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  • Press the Power button (my hp laserjet 2430 keeps - c01602202.gif ) to turn on the product.
  • Disconnect the power cord from the rear of the product.
    Remove the rear access door. Press in the release tab on the rear access door, and then pull the door away from the product. Figure 2: Remove the rear access doorc00909313.gif
  • Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull any whole sheets of paper to avoid tearing them.
    CAUTION: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur.
  • Check the rollers on the rear access door. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  • Press the Power button (c01602202.gif ) to turn on the product.
  • Open the cartridge door.
    Without turning off the product, disconnect the power cord from the back of the product.
    CAUTION: You must disconnect the power cord to move parts by hand without the risk of an electrical shock.
  • Disconnect the power cord from the wall outlet.
  • Look inside the product to see where the carriage is stuck, and then check for any torn paper or objects that might be restricting the carriage.
    NOTE: You might need a flashlight to illuminate areas for proper viewing.
  • Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side of the product , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side of the product , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle of the product , move the carriage to the right side of the product.
  • Remove all traces of paper or obstructions found.
  • Make sure the carriage can move freely across the width of the product. Firmly push the carriage to the left side of the product, and then to the right side.Close the cartridge door.Reconnect the power cord to the back of the product.Reconnect the power cord to the wall outlet.Presmy hp laserjet 2430 keeps - c01602202.gifutton (c01602202.gif ) to turn on the product.
  • Posted on Nov 11, 2010
    My HP 2430 continues to jam on Tray 2 only. Tray 3 and Tray 1 (manual feed) are fine. I have replaced rollers and it continues to jam paper.
    Common problem on this printer is for either the drive shaft for tray 2 to come lose or to break. Pull out the tray and try to rotate the roller. If it turns freely then the shaft is broken. The replacement procedure is too complex to describe here. If the roller does not turn freely then likely the pick solenoid has failed.
    Oct 12, 2016 | HP LaserJet 2430dtn Printer
    Hp Color Laserjet 1600 says Jam in tray 2 bt there is not paper jams
    Open the paper feed area and the printer, examine the paper feed path and make sure there isn't a page or piece of paper jammed in the path somewhere.
    Aug 21, 2014 | HP Color LaserJet 1600
    How to change paper trays
    Press menu button, scroll to tray behavior, in that select type of paper, default tray & paper size etc..
    Feb 02, 2012 | HP LaserJet 2430 Printer
    HP2430 PRINTER TRAY 2 SAYS JAM BUT NO PAPER IS STUCK IN THEIR
    look it the tray there is what we call a paper sensor or a paper flag it's a small lever that is spring loaded if there is a problem with that sensor the paper will not register as being picked up by the rollers. or the paper pick arm best way to fix would to provide the serial info and I can upload you a manual for if with detailed diagram that show how to replace this part.
    Mar 15, 2010 | HP LaserJet 2430 Printer
    Default paper tray selection for HP LaserJet 4200tn
    1) When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an “autoselect” process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
    2) If paper is loaded in tray 1 and tray 1 is set "TRAY 1 TYPE=ANY" and "TRAY 1 SIZE=ANY" on the
    Paper Handling menu, the printer will always pull paper from tray 1 first.
    Dec 09, 2009 | HP LaserJet 4200 Printer
    My HP Laserjet 2430dn makes a grinding noise after power on.
    CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
    Feb 26, 2009 | HP Office Equipment & Supplies
    My HP LaserJet 2430dtn Paper jam
    Try this, make a print from the by-pass tray, does it go OK or jam??
    If it jams then there is a problem with the paper feed from the tray.
    If it jams then
    1-check the drum and see if there is an image on it( you can put a mark on the edge to see if it's rotating, thus eliminating the drum unit)
    2-same for the reg roller
    3-check for labels ar foreign objects
    Oct 08, 2008 | HP LaserJet 2430dtn Printer
    HP 2430tn lj printer with 13.20 jam inside top cover error
    What is the exact error message shown on the display ?
    Does it makes any strange noise when you start it up ?
    Dec 31, 2007 | HP LaserJet 2420 Printer
    HP LaserJet 2430dtn Printer Logo
    952 people viewed this question
    Seeker5211
    Seeker5211
