Question about Microsoft Xbox 360 Console
Our sons xbox 360 will not turn on and the light on hard drive is red. We unplugged it over night and plugged it back in and it still will not turn on and light stays red.
  • 23 Answers
This seems to be a common problem and i have heard it referred to as the "Red light of Death". Here is a link that will shed some light & save me typing for an hour 8) TeamXbox
Posted on Nov 11, 2010
My xbox 360 is now showing flashing 1 red light on and off
These steps are taken from the support site as always, it's the first website where you should look.
Solution 1: Disconnect and reconnect cables
Here's how:
  1. Turn off your Xbox 360 console.
  2. Unplug all memory units, controllers, and accessories from your console.
  3. Unplug everything from the back of your console, including power and video cables.
    Don't remove the hard drive.
  1. Reconnect your console's power supply.
  2. Reconnect each accessory one at a time, starting with a controller.
  3. After you've reconnected every accessory, turn the console on.
Solution 2: Remove the hard drive
To see whether the problem involves the original Xbox 360 Hard Drive, temporarily remove the hard disk drive. Here's how.
Note Not all Xbox 360 consoles include a hard drive. If your Xbox 360 console doesn't have a hard drive, to go Solution 3.
  1. Turn off the console.
  2. Locate the hard drive on the top of the console (or on the left side, depending on how the console is oriented).
  • Press the release button on the hard drive.
  • Lift the hard drive away from the console.
hdseparating.jpg If these steps resolve the issue, reattach the hard drive to verify that the error occurs only when your Xbox 360 Hard Drive is connected.
Solution 3: Disconnect memory units or USB flash drives
Here's how:
  2. Unplug any memory units or USB flash drives attached to your console.
  3. Turn on the console.
If these steps resolve the problem, reattach the memory unit or USB flash drive to make sure the error occurs only when it's connected. If this is true, order a replacement memory unit or use another USB flash drive.
Solution 4: Request a repair
If the previous steps don't resolve the single flashing red light issue, there are no additional troubleshooting steps. Your original Xbox 360 console must be repaired at our service center. Start the repair process online.
Jan 09, 2015 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
1 red light on xbox 369
hi, here follows a possible solution from Microsoft support:
One light on the ring of light around the power button on your Xbox 360 console flashes red.
You might also see the following error message on your television screen or monitor: System Error. Contact Xbox Customer Support. This message is followed by an error code in the format of "Exx," where xx is a two-digit number.
Note If you see error code "E74" on your screen, click the following article number to view the article in the Microsoft Knowledge Base: 941377 E74 error appears when you use your Xbox 360 console Back to the top
CAUSE A single flashing light might indicate a hardware failure on your Xbox 360 console. Back to the top
THINGS TO TRY Step 1: Disconnect and reconnect all cables a. Turn off your Xbox 360 console. b. Unplug all memory units, controllers, and accessories from your console. c. Unplug everything from the back of your console, including power and video cables. d. Unplug your power supply from the wall, and then unplug the short cord from the power brick. e. Plug everything back in. Make sure that you make all connections firmly.
f. Turn on your console. If the problem still occurs, go to step 2. Back to the top
Step 2: Remove the hard drive To see whether the problem involves the Xbox 360 Hard Drive, temporarily remove the hard disk unit. If your Xbox 360 console does not have a hard disk, go to step 3. To remove the Xbox 360 Hard Drive, follow these steps: a. Turn off the console. b. Locate the hard disk on your console.
c. Press the release button on the hard disk, and then lift the hard disk from the console.
d. Turn on your console. If these steps resolve the issue, reattach the hard disk to verify that the error occurs only when your Xbox 360 Hard Drive is connected. If this is true, contact Xbox customer support to order a replacement hard disk. To contact Xbox customer support, visit the following Web site: http://www.xbox.com/support/contact If this does not resolve your issue, go to step 3. Back to the top
Step 3: Disconnect any memory units a. Turn off your Xbox 360console. b. Unplug any memory units attached to your console. c. Turn on the console. If these steps resolve the issue, reattach the memory units to verify that the error occurs only when a memory unit is connected. If this is true, contact Xbox Customer Support to order a replacement memory unit. To contact Xbox Customer Support, visit the following Web site: http://www.xbox.com/support/contact If this does not resolve your issue, go to step 4. Back to the top
Step 4: Request a repair If the previous steps do not resolve your single flashing light issue, there are no additional troubleshooting steps and your Xbox 360 console must be repaired at our service center. https://myservice.xbox.com/it-it/Pages/welcome.aspx
Jul 31, 2010 | Microsoft Xbox 360 Console
Power went out i tryed to turn the xbox360 back on it didnt work
Take the Hard drive off, unplug the power wire from the wall, and plug it in to a different outlet, make sure the RCA (red,white,yellow)cables are still connected from Xbox to TV(or this will give red lights when turned on) and with that done, turn the unit on. Are the lights gone?
Jul 15, 2010 | Microsoft Xbox 360 Console
Xbox will not boot up and shows 1 red light with an error code of x 75 on a black error screen. Any ideas out there? x
Turn off the 360 and unplug the hard drive from the top/side of the unit and turn the 360 on.
Once the "No Profiles Found" dashboard comes up, turn off the 360 and plug the hard drive back in and start it back up.
Dec 20, 2009 | 3Com OfficeConnect Wireless Router
MY XBOX 360 HAS 1 RED LIGHT FLASHING, WHEN STOOD ON ITS SIDE THE LIGHT IS BOTTOM RIGHT
one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables. first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more. If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you. The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Jun 06, 2009 | Microsoft Xbox 360 Console
Xbox 360 Wont Read Games or DVD's
take out your hard drive and then turn it on restore factory settings and plug it your hard drive back in
Feb 21, 2009 | Microsoft Xbox 360 Console
Xbox 360 elite 1 red light
The number for Microsoft is usually listed on the back of any game manual.
I hope I was able to fixya problem, and Happy Gaming!
Oct 18, 2008 | Microsoft Xbox 360 Elite Console
I have an xbox 360 system which i've owned for 2 years. I switched it on last night and the screen went green. When i loaded another game green square pixels broke up the graphics. I switched off the...
Clyde, turn off your xbox unplug the av cable .. turn on your xbox.. leave it run until it shuts off by itself ( couple minutes ).. plug your av cable back in and turn it on.. Good luck..
Jun 30, 2008 | Video Game Consoles & Games
Xbox 3 red lights problem help please
3 red lights normally means there is a general hardware failure.
Are the lights flashing?
Turn off the xbox and...
Try unplugging everything from your xbox, plug it back in and turn it on.
if that doesnt work, when your xbox is turned off, take the hard drive out and restart your xbox. If it works with the hard drive, try restarting it again after putting the hard drive back in.
Apr 10, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
37 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
