FixYa.com
Tags:
Remote Controls
Generic problem for all Remote Controls
Philips universal remote pm435s
posted by tazzie2008 on Jun 17, 2008
Don't know how 2 set remote up by using code search only
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 21, 2008
Not Rated (0)
aprmaejun
Rank:Guru Guru
Rating: 93%, 80 votes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE 84918 Remote Control GE JASRM24977 Remote Control GE RM24940 Remote Control GE RM24948 Remote Control GE RM24973 Remote Control GE RM24974 Remote Control Jensen SC-340A Remote Control
Can you Help with these Remote Controls problems?
GE RM24912 3-Device Universal Remote Remote...
ge universal remote code needed
a g e universal remote need... Answer This...
RCA RCR311B Remote Control
lost manuil need code
lost manuil need code Answer This...
Radio Shack (15-2142) Remote Control
innovage remote control code...
i have an elderly friend with a... Answer This...
Remote Controls
remote
how do i program my remote to... Answer This...
Philips Magnavox REM-350 Remote Control
I have lost my manual
I have lost my manual and need... Answer This...
Repair Service
Find Remote Control Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
