Question about Toshiba Satellite A135-S2386 Notebook (PSAD6U-01D00D) PC Notebook
Forget password bios configuration - Toshiba Satellite A135-S2386 Notebook (PSAD6U-01D00D) PC Notebook
  • 2,296 Answers
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Posted on Dec 23, 2010
I forget my lenovo 3000 y500 bios password, how do i bios open without open the cmos
Normally, you can just move a jumper or unplug the CMOS battery to clear the password. But, I found the following in the Ideapad Y500 repair manual:
"A supervisor password (SVP) protects the system information stored in the BIOS Setup Utility. The user must enter the SVP in order to get access to the BIOS Setup Utility and change the system configuration.
Attention: If the SVP has been forgotten and cannot be made available to the servicer, there is no service procedure to reset the password. The system board must be replaced for a scheduled fee."
http://download.lenovo.com/consumer/mobiles_pub/ideapad_y400y500_hmm_1st_edition_sep_2012_english.pdf
Oct 31, 2014 | Amstron Lenovo 3000 Y500 Laptop AC Power...
I cant remember my login password and f8 does not work in safe mode still asking the password
Once you assign a password to your HP computer's BIOS configuration utility, you will need to enter that password every time you attempt to access the BIOS.
If you forget this password, don't fret there is still a way to unlock your BIOS without actually knowing the original user defined password.
This involves using a "backdoor" password, which is something that is installed onto your BIOS at the factory level that never changes.
Turn on your HP computer.
Press "F2" to load your HP BIOS access screen.
A password prompt will load on your monitor.
Type "merlin" into the password field (with no quotes) and hit your "Enter" keyboard key to unlock your HP BIOS password.
Sep 20, 2013 | HEWLETT-PACKARD Computers & Internet
Power-on password on hp 8510p
Power On Password & Hard Disk Password
With your next laptop you should protect it with a Power On Password AND put a password on your hard disk. This will stop anyone from using your laptop and if they move the hard disk from your laptop to another laptop they cannot access the data on your hard disk with the hard disk password.
BUT you need to write down or remember these passwords; if you lose or forget them you cannot gain access to your laptop.
There are no backdoor passwords to remove these passwords.
To set up or change these passwords, go to the BIOS configuration - then security configuration. http://techtips.salon.com/reset-hp-laptop-bios-password-1476.html
Nov 26, 2012 | HP Compaq 8510p Notebook
Forget bios password on nec laptop versa
The BIOS password may be removed by removing the BIOS battery from the notebook for 20 mins. If you cannot wait for this period, then short out the battery contacts for a few secs.
Replace the BIOS battery and go to the BIOS configuration and set the Date & Time etc.
If this procedure does not work then try this WEB site for BIOS passwords :-
http://www.biosflash.com/e/bios-passwords.htm
Oct 07, 2010 | NEC Versa SXi Notebook
I have forgot my word password ,how can i open it.
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Mar 11, 2010 | Toshiba Satellite A100-S8111TD Notebook
When i turn on my emp thinkpad it's all black and on the top it says password but i dont know it.
Per Lenovo Support (they purchased IBM thinkpad a couple years ago)
ote: Do Not Forget Your Supervisor Password! If you forget your Supervisor password, there is no way to reset your password to enter the BIOS configuration. Setting a supervisor password automatically sets the hard drive password. If you do not remember your supervisor password you must have the system serviced to have the system board and hard drive replaced. Proof of purchase is required, and this repair is not covered under the warranty.
Sep 05, 2009 | IBM ThinkPad T21 Notebook
Bios password lose
Desktop
Power off the computer and make sure that it is unplugged.
Open up your computer case. You need physical access to the motherboard to complete this procedure.
Find a circular, (mostly) silver metallic object on the motherboard. This is the CMOS battery.
CAREFULLY remove the CMOS battery, avoid touching it with your fingers, and leave it out for about 120 seconds. This will flush the CMOS memory which stores the BIOS password and all other configuration. (See Warnings)
Set the battery back into place and power on the computer.
The computer should then warn you that the CMOS configuration could not be found. You can either reconfigure it yourself or restore defaults. Restoring the default configuration should be fine.
You will notice that the BIOS password has been cleared and you can boot without it. You may reset the BIOS password to something else by going into the BIOS configuration and setting a new User Password (The Supervisor Password controls access to the BIOS, NOT the computer!)
Laptop
Remember that laptops can be trickier, especially if it's a newer model. If it has a security chip on the motherboard forget about it. You either have to physically remove the chip or contact the mfg for the "master" password. If you can boot up off of a cd or floppy try any of these methods:Create a Win98SE bootable media "or anything that lets you boot into MS-DOS" and boot off of it.
When the A:\> prompt appears type debug and press enter.
You will then only see a "-".
Type o 70 2E "include the spaces" and press Enter.
Type o 71 ff "include the spaces" and press Enter.
Type q and press Enter.
Here are a list of common mfg backdoor passwords:
AWARD BIOS
AWARD SW, AWARD_SW, Award SW, AWARD PW, _award, awkward, J64, j256, j262, j332, j322, 01322222, 589589, 589721, 595595, 598598, HLT, SER, SKY_FOX, aLLy, aLLY, Condo, CONCAT, TTPTHA, aPAf, HLT, KDD, ZBAAACA, ZAAADA, ZJAAADC, djonet, %øåñòü ïpîáåëîâ%, %äåâÿòü ïpîáåëîâ%
AMI BIOS
AMI, A.M.I., AMI SW, AMI_SW, BIOS, PASSWORD, HEWITT RAND, Oder
Other passwords you may try (for AMI/AWARD or other BIOSes) - LKWPETER, lkwpeter, BIOSTAR, biostar, BIOSSTAR, biosstar, ALFAROME, Syxz, Wodj gvs
source:http://www.wikihow.com/Break-a-BIOS-Password
please rate!
Jan 21, 2009 | Toshiba Tecra S1 Notebook
Lost BIOS Password
ulta ho ke gand de de
Oct 19, 2008 | Computers & Internet
Sony vaio VGN FJ290P password reset sony vaio VGN FJ290P
I have set the password for administrator when i entered the bios set up. you can change its setting but not the configuration unless you've entered the password. you can't change the password with a new one if you cant enter the old password. Next time dont forget your password because laptops has its security even when stolen you cant open its bios set up if its protected by password. CMOS battery is in the mother board. You need a service technician to open your laptop to reset the bios setup battery.
Oct 11, 2008 | Computers & Internet
Bios master password
hey,
I have also try'ed that 4-5 years ago. But don't know if it works on today's motherboards. I removed the battery backup on the motherboard until the memory where cleared.
Also i know on some motherboards you can reset bios configuration, try to search for the motherboard manual to find the best solution.
best regards michael
DIY repair site 'Why pay when you can play'
Dec 14, 2007 | Dell Computer Refurbished PE3250 SYSTEM...
Toshiba Satellite A135-S2386 Notebook (PSAD6U-01D00D) PC Notebook Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
