ELECTROLUX Neocal Anti-Limescale Device - how do you install this product?
Water pours out in a trickle and takes forever to make a cup of coffee. What can I do to speed things up
You should consult the owner's manual and find out about the cleaning procedure. This sounds like limescale has built up and has furred the pipework. Some anti-limescale treatment should work but you don't want anything too harsh.
Jan 06, 2015 | Keurig Coffee Makers & Espresso Machines
My Electrolux ESI602 dishwasher has just started leaving rust spots on all my cutlery & a white residue on the inside of the dishwasher (like limescale). Any idea what the problem is ?
This is a something i see all the time always use the better dishwasher soap it cost a little more but in the long run it works better, also use less soap then what they say to use , so it will cost you less !
Dec 02, 2011 | Electrolux 23 in. ESI602X Built-in...
How do you clean the inside of your metal kettles
if you wish to remove limescale, then you can use limescale remover either liquid or powder.
follow directions on the product of choice.
alterativly use vinager, just pour undiluted vinegar into the kettle and let it rest for a while until it no longer produces bubbles. then rince well.
if there is still limescale then repeat the process.
Note
do not let the kettle boil with vinegar or limescale remover in it. they may cause a fault and some
very bad smells.
I hope this was useful..
May 23, 2011 | Morphy Richards 43691 Cordless Electric...
Do not connect to the terminal server using nc120 device after installation anti-virus program?
It seem it is for your firewall of Anti-virus! You should change you anti-virus firewall profile and add all application for the nc120 terminal to it as allow.
Make sure that
you have the correct ports open on the firewall to ensure proper execution of that product when this application is re-enabled. The correct ports to have opened on your firewall software are :
TCP-Protocol: 27605 , 3581 , 3597 , 3645 and UDP-Protocol: 1283 and 3581.
When dealing with firewall applications, you may need to make sure that .exe files have proper access to the network. These .exe files include:
KMSERVC.EXE
BOOTSRV.EXE
KMMSG.EXE
KMUPDATE.EXE
KMREGWIZ.EXE
Please make sure to Permit/Grant access to these applications or your product will not work properly. For a detailed compilation of which anti-virus/firewall applications have been tested and their known problems, please contact your vendor of that product.
Nov 29, 2010 | NComputing Co.,Ltd. - Korea UTSA/UTMA...
My PC is very slow and keeps coming up with Errors, How do I clean my computer?
1. Buy an external disk-drive.
2. Copy all your music & files & E-mail & contacts to that device.
3. Find your original manufacturer-supplied "System Restore" set of CD-ROMs.
4. Find your original CD-ROMs for purchased software (Photoshop? Adobe? Microsoft Office? Nero? Anti-Virus?)
5. Find the original "product-keys" so that you can re-install that commercial software.
6. Re-install Windows, using those "System Restore" disks.
7. Re-install your purchased software.
8. Install anti-virus software.
9. Access: http://WindowsUpdate.Microsoft.com
to get all the security-updates for Windows.
Repeat until you have no more updates to be applied.
10. Reload your data from the external device.
Oct 23, 2010 | Computers & Internet
THE anti flood device has been activated. I have emptied the salt tank, how do I reset the safety valve on the water inlet hose?
The answer is that you don't reset the anti-flood device. The anti-flood device re-sets itself when there is no risk of a leak. I don't really understand why you emptied the salt tank . . . ?
I cannot help you any further than this as you haven't specified your brand and model of dishwasher. If you can post these, I will try try to help further - if it's a model I support.
Oct 17, 2010 | Dishwashers
What can I do to remove limescale from my dishwasher water inlet hose
Sprayed Bam throgh water inlet hose to remove limescale. Plugged back in and water pressure cleared problem.
Oct 23, 2009 | Electrolux Dishwashers
Washing Machines Logo
198 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
