Question about Dell Computers & Internet
Dell Latitude D620 BIOS password help!!! I bought a Dell D620 and I noticed that some BIOS features are password protected. The previous owner said he doesn't know anything about it, so I'm not sure what should I do now. Any ideas would be appreciated. The laptops service tag is 4YXMT2J-595B, if it's of any help.
  • 5 more comments
  • limpangel Nov 11, 2010
    I have tried this in the past and tried it again now, but it does not solve the problem.
    Let me detail the problem: I can install the OS and use the computer, and I can view the BIOS settings, but I cannot edit them. I need the "master" password, which (from what I read on forums) is generated using the service tag I provided.
    In other posts on FixYa I saw experts that provided these passwords, but as they are attached to those users service tags are useless to me. I am waiting for one of those experts to help me too.
    Also advising me to buy 50$ worth of service/software to unlock my BIOS is not an option. I already paid FixYa for a premium response, so I'll wait just for that and hope it was worth my time.
    Removing the CMOS battery doesn't work. Tried it long before posting here.
    Also, I already have software that can remove/reset the BIOS password (for free), but as with any software there's a possibility it can brick my laptop. So I want to try the alternative before taking this risk.
  • limpangel Nov 12, 2010
    None of the bios tools from Ultimate Boot CD work for my laptop. Already tried it before posting on FixYa.
    My laptop is out of the warranty period so Dell support is not an option.
    Upgrading the firmware does not work. It says "Cannot run under a protected enviroment".
    I cannot, because my country is not supported. This laptop was bought outside of US. If Dell support was an option I wouldn't have come to FixYa.
    Guru:
  • 1,051 Answers
Dell usually sets a default password as password or admin Try those first. If no luck go into the bios setup by continually tapping the exc key while the computer boots. If your licky you may be able to set yourself as administrator and give yourself admin rights. With admin rights you can do anything.
Posted on Nov 12, 2010
  • 4,281 Answers
You can reset bios password with pull cmos cell from motherboard. For that open back cover of laptop then you can see motherboard chip set. Pull cmos cell from motherboard for 10 minutes then all settings goes to defaults. Then it will not ask for password. Let me know if you need further assistance.Thanks for using FixYa.
  • Upgrade your bios firmware.
    You can download it from dell web sites.
    You can download it from below link.
  • Dell Master
  • 13,433 Answers
Hey,
you can reset the bios with a boot cd called ultimatebootcd which is free.
http://www.ultimatebootcd.com/download.html
It contains a program called !bios or iBios from which you can run a reset / attack on the bios and it removes the password.
Or you can run the wipeCmos utility
they are all under the bios selection.
so you download the cd image from the above linked page (scroll down to find the links) burn it to a cd start the machine from the cd select bios run !bios perform the standard attack. restart the machine and the password should be gone.
Done it on my own laptop some time ago.
  • Ekse Nov 12, 2010
    Also there are bios password recovery utilities on the !bios program that might be able to read the password and show it to you.
  • 4,889 Answers
You can remove that password by removing all power sources to the laptop. Disconnect from AC power, remove the laptop battery, and then remove the CMOS battery located under the hinge cover. You can find detailed instructions with pictures here
http://support.dell.com/support/edocs/systems/latd620/en/SM/coincell.htm#wp1111212
Remove the CMOS battery and hold for a minute and put the battery back in. All BIOS settings including the password will be reset to factory defaults.
Posted on Nov 11, 2010
  • 656 Answers
The way to reset password is to remove the battery and restart the computer or you will see three pin with a jumber remove the jumber short pin 2 and pin 3 and restart your computer this will reset the bios when you restart you will see press del to go to bios or F1 to default setting pres del then adjust your bios if the password pop up click enter without entering the password in confirm password click enter blank password go to exit click save and exit on restarting and shut down your computer uplug the power cord if you have shorted the CMOS pin put them back to pin 1 and 2 and if you removed the CMOS battery replace them and restart your computer
Posted on Nov 13, 2010
    Top Expert:
  • Dell Master
  • 84,027 Answers
Hello
In order to reset the bios password you must remove the button/coin cell battery called the CMOS memory backup battery. Below you will find a link to the service manual section for your model D620 that explains with pictures how to remove/replace the battery, in your case remove the battery for 5 minutes, the Bios password will then be reset.
  • 2 more comments
  • Marvin
    Marvin Nov 12, 2010
    If you wish to replace the battery since you have it removed the number of the battery is "CR2032"
  • Marvin
    Marvin Nov 12, 2010
    This is the correct solution and is a standard bios password reset for all computer regardless of manufacturer.
  • Marvin
    Marvin Nov 12, 2010
    After submitting my solution for the Bios password reset I see you have already tried removing the battery (additional comments by you are only see after I submit my solution), so here is what is needed to clear the password, go to the Dell support link below, it provides the information on how to get the password reset in your model D620 Laptop, there is no "master password"
    http://support.dell.com/support/topics/g...
  • Marvin
    Marvin Nov 12, 2010
    PLEASE CONTACT DELL SUPPORT AT THE PROVIDED LINK ABOVE, THAT IS THE ONLY WAY TO SOLVE THIS, IT IS FREE.
Dell Latitude E5530 bios passowrd.
The easiest way is to contact the supplier if new or previous owner if not and ask for the password.
Jan 28, 2014 | Dell Computers & Internet
Hi, my laptop is a dell latitude D620 service tag: 5y2kr2j -595b. Help me unlock the bios. vangiezens@gmail.com.
I'm assuming you're referring to the Administrative password for this model.
You will have to contact Dell by phone and give evidence that you are the owner of the notebook on record with them. Once that has been done, they will give you a Master Password that you can use. There may be a charge for this assistance.
Dec 30, 2012 | Dell Latitude D620 Notebook
Unlock Bios Dell Latitude D620
You can't unlock laptop BIOS. This is to prevent theft. Possible Dell Support might be able to help you.
Sep 29, 2010 | Dell Latitude D620 Laptop (Latitude-C620)...
How to remove Dell Latitude D620 BIOS Password.
send me the service tag wich u can see on the bottom cover or trun on laptop u will see on screen hash code like this XXXXXXX-595B or D35b or 2A7B send me complete .ill send u password .
Jul 19, 2010 | Dell Latitude D620 Notebook
BIOS PASSWORD UNLOCK OR FALASHER BIOS "DELL LATITUDE D620" (revision A07)
if you do not have the bios password you have to open it ..and clear bios by short the pins if you find them...or remove the bios battery for 10 seconds..and will be on factory optimal defolts
Mar 27, 2010 | Dell Latitude D620 Laptop (Latitude-C620)...
Please help me bios password, which is admin system dell latitude D620
remove the laptop and, bios battery wait 10 minutes then reconnect the bios battery and repower with the power supply
May 28, 2009 | Dell Latitude D620 Notebook
Password lock,dell latitude d620
There a couple things you can try, however, if these don't work, you'l have to send it to dell and pay to havethem remove it. This a security feature built into the laptop by Dell.
1. Remove the battery on the motherboard, wait about 1-2 minutes and put it back in. Power it up and see what happens. If that don't work, go to step 2.
2. Go to this site: http://www.passwordmethod.com/PasswordMe Follow the on screen directions.
3. If 1 or 2 don't work, you'll have to send it off to Dell.
Mar 28, 2009 | IBM DB2 Connect Enterprise Edition for PC,...
Dell latitude d620 bios password removal
To remove a BIOS password will require the assistance of Dell Tech Support. 800-624-9896 You will have to be able to prove you are an authorized user and if out of warranty a Fee may be involved.
Mar 20, 2009 | Dell Latitude D620 Notebook
I got my Dell Master Password from http://www.bios-password.kickme.to/
This seems the best price in the net
Jun 20, 2008 | IBM ThinkPad T43 Notebook
Computers & Internet Logo
474 people viewed this question
Clive
Clive
Alun Cox
