Question about Frigidaire Washing Machines
During the spin cycle the tub is knocking and seems to be way out of balance no matter how you put the clothes in.
  • 147 Answers
The inner basket has to be replaced
Posted on Nov 11, 2010
Whirlpool trouble shooting
All Spin cycles regardless of load or even when unloaded and spinning?
If so suspension is broken.........Technician repair only, even the balance weights in the tub are too heavy for DIY to remove and replace springs
Sep 07, 2014 | Whirlpool WFW9550WW Duet 27" 4.4 cu. ft....
A knocking noise during agitation wash cycle
could be a bad counter balance , u can remove the front panel and run a spin or wash cycle and listen to where its coming from so u don't have to replace all the balancers. on some models theres a heavy ceramic weight at bottom that at times goes bad and throws it off balance, just run it and look where noise is coming from
Jul 25, 2014 | Maytag Performa PAV2200
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Jan 18, 2010 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Machine knocks and walks when spinning a small load
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
The problem is the brake. The odd time what happens is moisture gets on thebrake rotor and the squealing is heard when the brake stator is applied to stop the tub from spinning. This moisture, may drip down from the tub onto the brake rotor which could indicate a leaky tub seal. If you can't see any dripping when you fill the tub with water, don't worry about the tub seal. Many times than not the brake is just going sour on it's own.
Sometimes you can fix the squealing by cleaning the rotor and stator with a light sandpaper, such as emery/sand cloth. If that doesn't work you will need to replace the brake stator and rotor. If you need to replace them replace both parts together, don't just change the stator without also replacing the rotor, or vice versa. And here's a bonus tip: the brake spring exerts 200 pounds of force. If you try to remove the six 5/16" screws without using this brake removal tool, serious injury can/could happen!! The splined part in the middle of the brake needs to be greased really good before putting the brake back on!
Apr 01, 2009 | Maytag Washing Machines
Spin cycle noise
Most likely, your pulley is coming off, my pulley mad that knocking sound for a year before the belt fell off and I had to address it. see the previous post on how to fix this issue.
Oct 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Drum off balance
It's either a bad suspension spring or you have a crack in the tub support.
Jul 15, 2008 | Whirlpool LTE5243D Top Load Stacked...
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
GE WSM2780W Stacked Washer spin cycle
With no clothing in the wash tub take the following steps:
1. remove the front cover from the wash tub
2. run a full cycle of laundry and observe the tub's behavior
Potential Solutions:
A. If the tub begins to shake wildly during a full wash cycle with no clothing in it then you will need to adjust the 3 large springs on each side of the tub until the unit is working in a more-balanced position. This is simple to do by hand. If the tub appears to be shaking too far forward, then unhook the 2 large springs in back so they are tighter. Then run a full wash cycle again with no clothing.
* note: there are smaller springs too - you don't have to adjust these to fix your issue
B. If the tub works fine with no clothing during a full wash cycle, then try to load your clothing in a more balanced fashion. For example: if your wash load is only a small kitchen or bath rug then when the unit spins it will spin off balance with a wet & heavy item on only one side of the tub.
C. If you'd like to replace the 3 large springs, I can get you the part numbers. There are specific springs for both sides of the wash tub and they are different part numbers. The full replacement of the 3 large springs can be done by hand.
thanks,
Chris I.
Sep 24, 2007 | GE WSM2780W Stacked Washer / Dryer
Washing Machines Logo
20 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
