Symphonic WF32L6 LCD TV with vertical lines that used to go away when set warmed up, but now just move to the left, but is still watchable. What board is the one I need to replace? The power supply? I know many products had bad caps during this time frame.\r\ndanl@mvn.net 618-732-6215
5 Suggested Answers
SOURCE: Symphonic WF32L6
I had the exact same issue . The TV literally stopped working 2 year after the manufacture date. Since I had nothing to loose I opened it up and found that the fuse had blown. I put a new one in and if blew also. I work with some electrical engineers and they said first to look at the Diodes. They lent me their diode checker, and the first diode I checked was bad. I'm sorry I don't have any pictures but it was one of the diodes closest to the where the power cord connects to the board. I took the board out and brought it to work and had the electrical guys pull the diode. I got a replacement diode, (.20 cents or so) and had them solder it back in. The Diode number is IN540, you can buy these online, DIGIKEY.COM is one place too look. I took it home put everything back together, including a new fuse and BOOM it fired right up. I did this about 2 weeks ago and it is still going strong, I should probably knock on wood right about now. If you have an questions please feel free to ask. I am not a TV repair guy, just someone who got lucky. Good luck!
Posted on Oct 13, 2008
SOURCE: remote codes for Emerson Symphonic tv?
I have a symphonic tv and a emerson universal remote cannot find code anywhere for this tv???? anyone know what to do cheap tv
Posted on Sep 06, 2009
  • 8457 Answers
SOURCE: Symphonic WF32L6 on power up power light flashes
Ur Main Tuner signal board is dead.Replaced this board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner Signal board for the replacement.
Posted on Mar 08, 2010
Testimonial: "Sounds reasonable. Thanx!"
smarthome2
  • 1114 Answers
SOURCE: I have a symphonic wf32L6
Yes it has a Digital Tuner/ HDTV Tuner. Go into the setup menu of the TV and do a digital channel scan. If you still have an issue, post a reply/comment and I will help you further.
Posted on Jun 01, 2011
Symphonic WF32L6 on power up power light flashes about twice per second for 20 seconds. Screen displays ''DIGITAL TELEVISION'' then power light flashes about 4 times per second for perhaps 10 seconds more,...
Mar 08, 2010 | Televison & Video
Mitsubishi 40" TV, LT-40134 Vertical lines on left side of screen
I've got the same TV with the same problem. Sometimes by moving it on the stand the lines will go away but it only sometimes temporarily fixes the problem. For a while it seemed like it needed to heat up to go away but that is not the case. It seems like there is a bad connection somewhere but i cant seem to find it. One day, one thing will fix it, then the next day it wont do the trick. It gets very irritating.
Oct 09, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
LCD TV vertical line
If the line is vertical and "One Pixel Wide" (Pinstripe) then the LCD Panel is bad and needs to be replaced. Contact 1-800-SAMSUNG to set up service.
Jul 14, 2009 | Televison & Video
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Blue color spread over the pictures
This sounds classic to a thermo problem where a part(s) are becoming thermo sensitive with aga and use. When the set is cold and then warmed up, the defective part(s) is changing characteristics.
Some components became thermo sensitive that are driving the display. Or an embeded component in the display itself became thermo sensitive. It is very possible that the fault is on the board that does the X - Y addressing or on the backplane electronics of the display screen itself.
Using the set with defective components is a bad idea. If the part(s) fail completely and go shorted or opened, other more costly damage can be done.
The service rep for the manufacture of your set is equiped and trained to be able to troubleshoot and service your set.
You will have to take the set in to have it serviced.
Jerry G.
Apr 17, 2008 | Vizio GV46L 46 in. LCD Television
Remote codes for Emerson Symphonic tv?
Dec 22, 2007 | Televison & Video
LCD TV - Vertical Blue line
use menu and h/v then change then move to higher level and it will take it away.
Oct 09, 2007 | Vizio Gallevia GV42LF 42 in. LCD...
Televison & Video Logo
313 people viewed this question
Top Televison & Video Experts
