Question about RCA L32WD22 32 in. LCD HDTV
My RCA TV -L32WD22 turns on only after 8 minutes of trying. After 5/6 minutes a message appears about failing power and setting correct time. It does't hold set time. Next day time is back to 1AM. Thank you.
  • RCA Master
  • 5,138 Answers
Remove the back and look for Bad Capacitors on the power supply board they will be vented or puffed up on Top 2200uf 3300uf 10v 1000uf 16v, if you do not see any bad caps then try resoldering the power supply board and the main signal board, sometime Poor solder connections can do this.
Posted on Nov 11, 2010
Tv has to be turned on many times before it will come on
It is likely that the power supply is failing. It has to be "shocked" into operation but eventually that won't work anymore
Sep 23, 2013 | RCA L32WD22 32 in. LCD HDTV
I have no remote for an rca l32wd22 hdtv lcd tv and cannot find the inputs to change to HDMI?
Unfortunately, the L32WD22 doesn't have an Input button on the front panel of the TV. You need a remote control that matches the Input code for the remote. Here's one link to a remote that should work: http://remotes.com/store/rca/l32wd22.html . Other universal remotes may work if you find the correct code if the remote has an Input or Source button.
I hope this helps.
Apr 16, 2013 | RCA L32WD22 32 in. LCD HDTV
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
Our tv when itis on for a while some times the picture freezes an then goes blank an a loud hissing an squeech sound we have to unplug it to turn it off.
Hissing sound normally from Power Supply unit(PSU), usually from Transfomers in the PSU. Usually caused by bad capacitors. Try this capacitor replacement kit, on ebay only $15. http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
Could not find any PSU board available at the moment, but have tried that kit and it works.
Nov 30, 2011 | RCA L32WD22 32 in. LCD HDTV
RCA L32WD22 32" HDTV LCD TV turns on, blue light on front is on but there is no sound and no picture. I left it unplugged for an hour and turned it on again. As soon as I plugged it in, an orange light on...
kkl,
these tvs have a power supply defects. Follow these instructions and get yourself a free tv.
Take your unit to a service center. Since they have no service manual they wii not be able to repair it.
With the Work Order or a copy of it call 1-877-297-8391 and you will get a tv no questions asks
Jun 05, 2010 | RCA L32WD22 32 in. LCD HDTV
RCA L32WD22 with no picture.
The backlight has failed. May be the power supply for it, the inverter board or the lamps. Not something you can fix unless you are a tech.
Mar 10, 2010 | RCA L32WD22 32 in. LCD HDTV
I have a rca l32wd22 screen weht black with no
Aboyd992,
Take your tv to a service center and ask them to fix it. If they cant...
Have them make out a work order and then you call 1-877-297-8391. The people at the other end ot the tele number will give another tv
Jan 09, 2010 | RCA L32WD22 32 in. LCD HDTV
Have an rca l32wdww, the tv turns on and then turns off in a second with a message of ''some settings may be incorrect after a power outage, please check clock under options'' but doesn't give you a chance...
Highlander90,
Get ready to watch TV.
Take your Tv to a service center and ask them to fix it. They won't be able to because there are no repair manuals. So when they say,"We can't fix it" you take the work order and call 1-877-297-8391
Oct 10, 2009 | RCA L32WD22 32 in. LCD HDTV
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
RCA L32WD22 32 in. LCD HDTV Logo
152 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
