Windows Startup When I turned my computer on this a.m. (Medion 4100) I got this error message: Windows could not start because the following file is missing or corrupt: WindowsSystem32ConfigSystem. It was working fine last night when I shut it down.
  • Anonymous Aug 20, 2008
    The same thing happened to me and It says I should use the factory reset disk to try to repair it, but I don't have it...
  • 385 Answers
Your ram either needs some cleaning and dusting out or it may have gone bad. Try cleaning it and see if that works. If not then one of your memory may be bad. In some cases, replacing with a good memory in itself may solve this problem. In other cases, you may need to perform a checkdisk to repair the filesystem. You will need to obtain a Windows XP cd and boot to it. Go into recovery console and select the C:\Windows to log into. If the administrator account has a password, enter it. If it doesn't have any password or you are not sure, just press enter. Then at the c:\windows prompt, type: chkdsk c: /r and then press enter. This should take about 15 - 30 minutes depending on how fast computer is.
After that is finished, type exit and then ctrl+alt+del to restart.
It should boot up fine now but do let me know what happens.
Thanks,
Lolita
Posted on Jun 17, 2008
PoweReadACValue error
Probably it is cause due to power management system corruption
Try following steps
Perform a Clean Boot
If your computer is not starting normally, or if you receive errors when you start your computer that you cannot identify, you could consider performing a "clean boot." This operation starts the computer by using a minimal set of drivers and startup programs. This can help you troubleshoot the problem.
Method :Perform a Clean Boot
Step 1: Start the System Configuration Utility
1. Click Start, click Run, type msconfig, and then click OK.
2. The System Configuration Utility dialog box is displayed.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked. 5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, and then click OK.
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. If you are prompted, log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK.
Note: Start Windows in Normal State
Steps to configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows to start normally.
1. Click Start, and then click Run.
2. Type msconfig, and then click OK.
3. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
4. When you are prompted, click Restart to restart the computer.
Sep 04, 2010 | HP Pavilion dv7-1130us laptop
Tip
Cannot Print from Internet Explorer
Issue: Cannot Print from Internet Explorer
Symptoms : When you attempt to print a document or look at it in print preview, you may receive the following error message:
Line: 539
Char: 2
Error: Invalid argument.
Code: 0 URL: res://C:WINDOWSSYSTEMSHDOCLC.DLL/preview.dlg
CAUSE : This issue can occur if the Iepeers.dll file is corrupted or is the incorrect version
Resolution: To resolve this issue, replace the Iepeers.dll file. To do this, follow these steps:
1. Restart the computer in MS-DOS mode or with a startup disk.
a. For Windows 98 and Windows 95 , click Start, click Shut Down, click Restart the computer in MS-DOS mode, and then click Yes.
b. For Windows Millennium Edition (Me), use a Windows Me startup disk and click Start Computer without CD-ROM Support.
For additional information about how to create a Windows Me startup disk, click the article number below to view the article in the Microsoft Knowledge Base:
267287 (http://support.microsoft.com/kb/267287/EN-US/) How to Create a Startup Disk in Windows Me
2. Type the following commands, pressing ENTER after each command:
c:
cdwindowssystem
ren IEPEERS.dll IEPEERS.old
exit
3. Extract a new copy of the Iepeers.dll file to the WindowsSystem folder. You can extract the Iepeers.dll file from the following location:
The IE_5.cab cabinet file included with Internet Explorer 5.5 for Windows 98.
4. Register the Iepeers.dll file. To do this, click Start, point to Run, and then type the following line:
regsvr32 IEPEERS.DLL
5. Click OK.
6. Restart your computer normally.
on May 30, 2008 | Microsoft Windows Vista Home Premium with...
Runtime error
Method 1: Clean Boot with Only MoSearch loadTOCNode(2, 'resolution'); The Mosearch.exe (Microsoft Office Search Service) and Mosdmn.exe (Microsoft Office 10 Search Filter Daemon) Startup items may be conflicting with some other program (or programs) running in the background. Therefore, clean boot your computer with only MoSearch selected on the Startup menu to determine whether this program is the source of the conflict. To do this, follow these steps:
  2. In the Open box, type msconfig.exe, and then click OK.
  3. On the General tab, click Selective startup.
  4. On the Startup tab, click to clear all check boxes except for MoSearch.
    NOTE: In Microsoft Windows Millennium Edition (Me), leave the *StateMgr check box selected as well.
  5. Click OK, and then click Yes when you are prompted to restart the computer.
  6. If the error message can be reproduced, repeat the preceding steps. In step 3, also click to clear the Process System.ini file and Process Win.ini file check boxes.
If the error message cannot be reproduced, this indicates that MoSearch is conflicting with some other program or programs running in the background. Follow these steps to locate the conflicting program:
  3. On the Startup tab, click to select one of the check boxes.
  4. Click OK, and then click Yes when you are prompted to restart the computer.
  5. If the preceding steps reproduce the error message, the last item added to the Startup menu is causing the conflict. If the error message is not reproduced, repeat these steps until all Startup menu check boxes are selected.
  6. If all the Startup menu check boxes are selected and the error message is still not reproduced, start Msconfig again, and then click to select the Process System.ini file and Process Win.ini file check boxes.
If these steps don't help you find and eliminate the conflict, proceed to the following method. uparrow.gifBack to the top Method 2: Uninstall the "Support for Fast Searching" Feature loadTOCNode(2, 'resolution'); To uninstall the "Support for fast searching" feature from all Office XP products that are installed on your computer, follow these steps.
Note This applies only to computers that are running Microsoft Windows 98 or Microsoft Windows Millennium Edition.
  1. Quit all Office programs.
  2. Click Start, point to Settings, and then click Control Panel.
  3. Double-click Add/Remove Programs.NOTE: Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
  4. On the Install/Uninstall tab, click Microsoft Office XP product, where Office XP product is the name of the specific Office product in question. If you are using a stand-alone version of one of the Office programs, click the appropriate product in the list.
  5. Click Add/Remove.
  6. In the Maintenance Mode Options dialog box, click Add or Remove Features, and then click Next.
  7. Click the plus sign (+) next to Office Tools, point to the icon next to Support for fast searching, and then click Not Available.
  8. Click Update.
  9. Repeat steps 2 through 8 for all other Office XP products installed on your computer.
  10. Restart your computer.
Apr 18, 2010 | Microsoft Windows Vista Home Premium with...
I have a invalid boot diskette a error message.
1.at startup press f8 2.in menu use arrows to safemode3.start windows in safe mode 4.delete any new startup software.
Oct 16, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Error communicating with kernel
try to instal the antivirus again there is some files corrupted
ok ;)
May 28, 2009 | Encore Computers & Internet
Every time I start my computer running Windows XP, I get the following message: ''Windows cannot find 'C:WINDOWSSystem32WinSit.exe'. Make sure you typed the name correctly, and then try again. To search...
just click start and select run and typr msconfig. u will get a menu and in that click startup ..u will get a list of files loading in startup. untick the one appearing in ur error. and restart
Apr 10, 2009 | Computers & Internet
When I turn my computer on, I get a runtime error.
If this doesn't fix it, let me know and I'll post another, more advanced repair.
Good luck, and please let me know how you do.
~ Spoem
Mar 24, 2009 | HP Computers & Internet
When I click Microsoft LifeCam VX-1000 to run but window message error appear said "LIFEcAM.EXE HAS STOPPED WORKING" and the program will close. Thanks for your help.
hi,
if your running windows xp on your pc please try this
Clean boot procedure on Windows XP loadTOCNode(3, 'resolution'); To perform a clean boot procedure on Windows XP, follow these steps:
Warning You may temporarily lose functionality of some services when you follow these steps. When you restore the settings, the services are restored. However, when you restore the functionality, the original error message or behavior may return. Step 1: Start the System Configuration Utility loadTOCNode(4, 'resolution'); To start the System Configuration Utility in Windows XP, click Start, type msconfig in the Start box, and then press ENTER. Step 2: Turn off programs and services loadTOCNode(4, 'resolution'); To do this, follow these steps:
  1. On the General tab, click Selective Startup, and then click OK.
  2. Under Selective Startup, click to clear the following check boxes:
    • Process SYSTEM.INI File
    • Process WIN.INI File
    • Load Startup Items
  3. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
  4. Click OK, and then click Restart.
Dec 16, 2008 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
UMAX 4100 Driver for Vista
go to UMAX 4100 scanner installation CD that comes with the scanner and find the setup.exe file and on it clik left mouse and then right mouse and choose properties and then choose "Install in WinXP-Sp2 compaitibility mode" ...Thats its . Then it will install in Visa and will work perfectly. Only when you startup the Vista it gives you some error message "incompitable Os" etc ..just cancells the message ..and your Umax 4100 Scanner will work perfectly.
Ray
Jun 02, 2008 | Umax Astra 4000 USB Flatbed Scanner
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
