Question about Tricity Bendix WDR1040W Front Load Washer / Dryer
My Bendix WDB1074T front loader washing machine/dryer will not actually wash! It fills with water, drains and spins at all the right times but the drum does not turn during the washing cycle, so the clothes come out dirty. The machine is now 12 years old. Could you please tell me what might the problem be, and the approximate cost to fix it. Thanks.
  • 15,935 Answers
If you hear the motor during the time it SHOULD be agitating - it is likely a failed clutch.
This part can be replaced for $150-$200USD
Thanks!
Posted on Nov 19, 2010
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Roper top loader problem with a RTW43408q0. Washer wouldn't spin at first. I ran that cycle again. It filled with water and didn't agitate or drain the water at all.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Apr 21, 2011 | Roper Washing Machines
What is the quickest wash cycle for the tricity bendix wdr1040w front loader
This is relating to the 2006 model.The times are not printed in most manuals like they used to but on this machine most probably the quickest prog. would be( 4 ) this is 3 rinses and a long spin at 40 deg. If you are experiencing long times on your washes do check that your water pressure is good as that will shorten the duration of all cycles and save on electric.
Hope this was helpful.
Good Luck
May 04, 2010 | Tricity Bendix WDR1040W Front Load Washer...
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Bendix aw1054 front loader wont fill as continually pumps water
If the pump is on all the time, then you definately have a timer and or control board prob, the only other possibility is if the drain outlet hose is to low.
This will cause the water to syhon out , thereby giving the impression that it is pumping out all the time.
To check this, try lifting the drain hose higher, and see if that solves the prob.
Plz rate my solution.
thanks.
Jan 12, 2009 | Tricity Bendix AW1054 Front Load Washer
Frigidaire Front Loader Won't Drain
if your washer is digital or with elecronic control board check the the motor control board located at the bottom difiniely you have to call a tech to confirm that. other model like wd5595 and wd 8095 has the same problem and it is the motor control unit that always fails.
Mar 21, 2008 | Frigidaire GLTF1670A Front Load Washer
Help me to wash!!
hi
    this sounds like a syphoning problem this means the outlet /drain pipe at the back of the machine has been pushed to far into the drain upstand pipe causing the water to syphon straight through the machine make sure that the drain pipe is only part way down the drain pipe, hope this works for you
cliff
Oct 14, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Bendix Washer/Dryer - softener dispenser not working
the softer dispenser is blocked, remove drawer wash it out with hot water ,clean out small hole in softer compartment close IRE bye
Aug 16, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Tricity Bendix WDR1040W Front Load Washer / Dryer Logo
90 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
