Question about Hotpoint Ariston AW125 Washer
What does f-08 mean when it comes up on your waching machine? hotpoit wt960
2 Suggested Answers
  • 12 Answers
SOURCE: hotpoint ultima wt960
this m,eans the water is not entering the machine it iseither the inlet valve or water off at tap
Posted on Dec 21, 2008
WT960 hotpoit washing machine shows F10 and stops
* F01 - Short circuit motor traic - Book a service engineer.
* F02 - Motor jammed or fan blocked - Book a service engineer.
* F03 - Front thermistor open/short circuit - Book a service engineer.
* F04 - No pump piloting - Book a service engineer.
* F05 - No feedback from the pump - Book a service engineer.
* F08 - Static heater relay with contact welded closed - Book a service engineer.
* F09 - Eeprom is not programmed or not functioning - Book a service engineer.
* F10 - Common of heater open or one shot open - Book a service engineer.
* F11 - No pump connection - Book a service engineer.
* F12 - Communication error between boards - Book a service engineer.
* F13 - Rear thermistor open/short circuit - Book a service engineer.
* F15 - Dynamic heater relay with contact welded closed - Book a service engineer.
* F-17 - Master relay welded closed - Book a service engineer.
Apr 06, 2015 | Washing Machines
Hotpoint washing machine wt960 not working because fo8 code come
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Wayne
Nov 20, 2014 | Hotpoint Washing Machines
Code F-02 on hotpoint WT960
Check and clean the filter and drain hose. Make sure the hose isn't kinked.
Apr 22, 2012 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint washing machine wt960 keeps displaying the fault code f-08 when trying to do a 40 c wash
Error code F08 is indicating that the heater relay cannot be activated.
Check all connections on pressure switch----module---- and heater.element.
Hope this helps, this is the recommended procedure.
Dec 01, 2009 | Washing Machines
Hotpoint wt960 keeps stopping and displays F-08, any ideas, Thanks
  1. F08 is a sticking heater relay.
  2. Check connections on pressure switch
  3. Check heater connections.
  4. Check module connections.
  5. Check pump filter is clear.
Please rate my solution.
Thanks.
Nov 16, 2009 | Washing Machines
I CANNOT READ THE INFORMATION ON THE LCD DISPLAY ON MY HOTPOINT WASHING MACHINE MODEL WT960 ULTIMA
some times in many m/c it has a code for the status of the m/c
i mean not complet words like F2 IT MEANS FOR REPAIR MAN THE FAULT NO 2
THANKS
Jul 11, 2009 | Hotpoint Washing Machines
Hotpoint wt960 comes up with test all the time
Press the Start/Cancel button until all the console Led's Illuminate
Press both Start/Cancel and On/Off buttons together until 'd off' appears
Normal screen should return and you can select a new programme. (GL = good luck)
Mar 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
SAMSUNG waching machine doesn't want to drain and spin.
drain pump blocked. remove bottom bung filter where hose comes out. will be a hair pin, bread tag stuck in fan blades
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
Hotpoint ultima wt960
Dec 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ariston AW125 Washer Logo
99 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
