Question about Pantech Duo Smartphone
Replacing Battery WIll it help if I replace my Battery?
  • Tadams34 Jun 17, 2008
    thank you so much for all your help.
  • 87 Answers
Yeah.. that will fix it for sure..
please rate this solution
Posted on Jun 17, 2008
How to remove
Will, Check links below or Re POST year, make, model, and complete question so we can here at fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Remove and Install Car Battery
Replacing Your Car Battery DIY Battery Replacing Pep Boys
How to change car battery safely
How to disconnect replace car battery touching 12v safety and tips Buick...
May 21, 2016 | Cars & Trucks
Windscreen wipers wont turn off
I can think of several possibilities:
1. When replacing the battery, some sort of shortcircuit might have occurrred messing up the fuses.
Solution: Refer to your user's manual to identify where the wipers' fuse is located and try replacing it.
2. As far as I'm concerned, a way to "reset" the computer in the car is disconnecting the battery, so the computer may have been reset with wrong parameters.
Solution: Have you tried disconnecting the battery for a couple of minutes? and plug it back?.
3. If your model has automatic wipers, try switching from auto to manual mode and viceversa.
4. When the battery on my 206 was almost worn out, the lights kept turning on after killing the switch, followed by a quick beeping (which normally indicates the power in the battery is draining). At first, I thought it was the switch of the headlamps, but after replacing the battery with a new one, the problem got solved. Maybe the battery you just put in is faulty?
Hope any of the above helps.
Nov 21, 2013 | 1999 Peugeot 206
Van won't start,rapid clicking heard when key is turned. need help/directions replacing starter relay for gmc vandura 2500, 1991
Check battery connections and battery fuse. Battery may not be large enough for the size of your van
Jan 18, 2013 | GMC Cars & Trucks
When i plugged in my laptop for charging,a note appears in the charging icon that says "consider replacing your battery"? is there any remedy regarding the problem of my battery without replacing...
Hi! Well for this one let me ask you first . Is the battery is beyond 1year? If it is then consider replacing your battery is the answer of that. But if not you can call your manufacturer as all the battery has it 1 year limited warranty. Just to let you know all the battery is consumable, sometimes it depends on how you use it .Hope this will help you. God Bless.
Apr 22, 2011 | Acer Aspire One PC Notebook
My dell beeps 5 times when plugged in, but...
First try replacing the CMOS battery.See http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/parts.htm#wp1533609 for the procedure. This is a cell battery on the motherboard. Most of these are 2032 batteries but check the specs for your machine.
If replacing the battery doesn't help, then the 5 beep code means that the motherboard is bad and needs to be replaced.
I hope this helps.
Jan 24, 2011 | Dell Inspiron 530 Desktop Computer
Battery does not last even a day
Hi, it seems like the battery will need replacing, this is a common problem with cell phones and replacing the battery will solve it.
Hope this helps
Muzzi_123
Nov 14, 2009 | Motorola Mobility RAZR V3
Electrical--windows, ac, radio and fan stoppped after battery replacement
Check the fuses. There is a good chance you might have blown one or a few if you some how didnt connect the jumper correctly which would explain some of the accessories not working.
Oct 08, 2008 | 2002 Kia Sportage
All Led's keeps flashing in the battery charge bar graph after replacing batteries.
just remove the battery again & dont put it back till 30 minutes then connect ur batter again.
Dec 27, 2007 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
Pantech Duo Smartphone Logo
27 people viewed this question
Top Pantech Computers & Internet Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
