Question about Motorola Mobility W375 Cellular Phone
Power save mode
I have a pcs w385 phone and it goes into power save mode when switching between home and roaming signal, why does it do this, i have to open the phone so it can finish searching for the signal, and there is no way to turn it off.
I prchues a modle no. W375 4 month ago but the cell gives up a 5 hours chagrining. So I want to replays this modle cell any other company (like that Relines, Nokia, sum san ext. ) pl. tell me how what I do said the shoppers
Posted on Jun 19, 2008
Richiesta attivazione sulla rubrica e d internet e messaggi da telefonino al pc
Posted on Jun 18, 2008
Hi. I have a FLATRON W1934S computer. Every time I switch it on it says "power saving Mode". How can I fix it?
Hello, I didn't understand the problem.
1.After switch on and it goes to power saving mode , which can be visibly seen by changing the color of power led from green9or blue) to yellow.
First thing to be done is when it goes to that state "power saving mode" remove the video VGA cabl , and if the unit gives video message "no video signal" which stays for a while and usually goes again to power saving mode , this is OK,
So if there is no video signal on input it should work like this. so you have to check you PC.
Another way is to use laptop or other PC to check the monitor itself.
Hope this helps a bit
Oct 29, 2014 | Computers & Internet
LG 2542T goes dark after showing "analog power saving mode" message
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
Is your computer working?
May 16, 2008 | LG L1717S-BN 17" LCD Monitor
Weak signal as compared to other phones
try updating your roaming capabilities usually a number to call for verizon its *228 also make sure you have your software up to date. To simply refresh your phone hold the lock and home button until your phone shuts off and comes back to the apple logo as well as that you can put your phone in airplane mode and then take it back out again and it well search for service and should guarantee best signal.
Mar 10, 2014 | Apple Cell Phones
My smart roaming sim lost its signal..i dont know why but still it has a remaining balance..what should i do??
You can powercycle your phone. Turn off phone,remove the sim card,memory card, and battery. Wait for at least 5 minutes then after 5minutes,you can put back the sim card,memory card at battery. Try to check if your roaming card will again work. If this doest work you need to contact smart telecommunications and ask them to deactivate then reactivate the roaming of your sim. Because if your sim wont work,there will be no access for you to retrieve the load of your sim.
Dec 02, 2011 | Cell Phones
Samsung mobile SGH-L700. There is a network problem in my set. The phone often goes in searching mode. Please advice how to solve this error.
go into the connection options and set the roaming to off.
,many times when it is on auto the phone will get stuck jumping between local and roaming towers and never really connects to one for very long....when the signal is low or the phone is on the fritz
just make that change though and you will be good to go.
GOOD LUCK AND PLS RATE THIS POST
Apr 07, 2011 | Samsung SGH-L700 Cell Phone
I put my mytouch 4g on airplane mode for an international flight. after I took it off airplane mode, i don't get ANY signal. I've turned the phone off, taken the battery out, everything. Whenever i go into...
If you're out of your home cellular network (T-Mobile) and you're in another country, maybe you don't have the roaming service active in your number profile, then you can have an error message, but if you have roaming activated, sometimes it's necessary to manually register into one of the available networks where you are.
Mar 15, 2011 | T-Mobile My Touch Cell Phone
My phone is saying digital roam mode when i make an outgoing call, how do i take it off so i can make outgoing call with no problem.
This is pretty much what you need to do. Just turn off all the roaming features. However when you roam it typically means you dont have service through Sprint so dont be surprised if when you turn off roaming capabilities your phone doesn't get ANY signal. Here's the link to your phones manual page 112 is about roaming.
Setting Roam Mode
Your phone allows you to control your roaming
capabilities. By using the Roaming menu option, you
can determine which signals your phone accepts.
Choose from two different settings on your phone to
control your roaming experience.
1. Press > Settings > More... > Roaming > Set Mode.
2. Highlight an option and press .
n Sprint Only to access only the Sprint network and
prevent roaming on other networks.
n Automatic to seek service on the Nationwide Sprint
Network. When Sprint service is unavailable, the
phone searches for an alternate service.
Call Guard
Your phone has two ways of alerting you when you are
roaming off the Nationwide Sprint Network: the
onscreen roaming icon and Call Guard. Call Guard
makes it easy to manage your roaming by requiring an
extra step before you can place or answer a roaming
call. (This additional step is not required when you make
or receive calls while on the Nationwide Sprint Network.)
To turn Call Guard on or off:
Call Guard.
2. Select On or Off.
To place roaming calls with Call Guard on:
1. From standby mode, dial 1 + area code + the
seven-digit number and press .
2. Read the message and press .
Note Call Guard is turned on by default on yourphone.
To answer incoming roaming calls with Call Guard on:
1. Press .
Data Roam Guard
Depending on service availability and roaming
agreements, yourphone may be able to access data
services while roaming on certain other networks. You
can set your phone to alert you when you are roaming
off the Nationwide Sprint Network and try to use data
services such as messaging.
To set your Data Roam Guard notification:
Data Roaming.
n Always Ask (default mode) sets your phone's Data
Roam Guard feature on. You will see a prompt that
will require you to respond anytime you access
data services while roaming.
n NeverAsk turns your phone's Data Roam Guard
feature off. Your phone will not notify you of your
roaming status when you access data services.
Touse data services when Data Roam Guard is active:
© When a notification appears informing you that data
roam charges may apply, press ROAM (left softkey)
to connect.
Note If the Call Guard feature is set to On, you need to
take extra steps to make and receive roaming calls.
Mar 08, 2011 | Sanyo SCP-2700 Cell Phone
I have a cell motorola w385 and i need to download pic to compute
You can try setting the USB mode to memory you may also need to obtain a copy of Motorola Phone Tools
Jan 05, 2009 | Motorola Mobility W385 Cellular Phone
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Motorola Mobility W375 Cellular Phone Logo
41 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
