I HAVE ROXIO MEDIA CREATOR 9 AND GET TO THE VERY END OF TRYING TO BURN A SLIDESHOW OF 750 SLIDE VS AND 7 AUDIO TRACKS AND AT THE VERY LAST MINUTE THE BURNING FAILS CODE 800700E ERROR WHILE ENCODING MENU. WHAT DOES THID CODE MEAN AND WHAT CAN i DO TO ENABLE ME TO BURN THE COMPLETE SLIDE SHOW ON TO DVD tHANKS David
  • Anonymous Dec 21, 2008
    Same problem, but on Asus W2W notebook running Vista. I get the error message when trying to make a DVD through Cyberlink Power Director 7.
  • pberryhill Apr 13, 2009
    I have the same problem. I have Roxio Media Creator 10. Initially I had an error that read 8004525e and updating the driver was suggested. I did that and it appeared the DVD was burning. At the end the error message was 800700 and I am looking for the next procedure to fix this problem. It seems the Roxio Media Creator isn't an easy program to use to get a DVD compelted. I am using an HP Media Center PC. Thanks for any help.
    Sergeant:
  • 275 Answers
You haven't mention which OS you are working with. I guess it is Windowsxp. Download nero and install it. It might help you to burn your files.I think that Roxio media creator is incompatible with your current OS.
Posted on Jun 17, 2008
How do I burn multiple slide shows to DVD using Roxio 2011
Create the multiple slide shows and store them in a directory that you have created on your hard disk just for those slide shows. When all the slide shows are present in that directory, start Roxio, use the Add Files function and go to that directory and select all of the files you want on the DVD. Name the DVD to something that indicates what is on it and start the Create/Burn to make your DVD.
Feb 07, 2017 | Roxio Computers & Internet
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
IS THIS SOFTWARE SUITABLE FOR USE WITH SONY DVD RW
Yes it certainly should be compatible with the CD/DVD drive.
Roxio has it's own burning software included with the program, you will just have to explore the software until you work out how to burn a CD using Roxio itself.
If you want to try another burning program try Nero 9 trial. All you have to do is enter your email address and then download the software. Nero is an excellent bit of software, i personally have never had any problems with it.
Get Nero 9 here >>>>>>>>>>
http://www.nero.com/eng/downloads-nero9-trial.php
Regards.
Sep 29, 2009 | Roxio Easy Media Creator 7
Will not load on windows vista not compatable
Previous versions of Roxio or Sonic branded software that are not listed below as Vista compatible may run into compatibility issues. The following Roxio applications that work with Windows Vista are:
Easy Media Creator 9 and above
WinOnCD 9 and above
Easy CD & DVD Burning ("Vista Compatible" labeled boxes only)
RecordNow 9 and above
MyDVD 9 and above
You will have to upgrade the software to an vista compatible version:
http://kb.roxio.com/search.aspx?URL=/content/kb/General%20Information/000004GN&PARAMS=
Mar 01, 2009 | Roxio Easy Media Creator 7
Can't install Roxio Creator 2009
There is a patch from Roxio to resolve this error!
http://kb.roxio.com/content//kb/Creator/000217CR
Deadog4201
Feb 05, 2009 | Roxio Easy Media Creator 10 Suite
Have Roxio 7 and want to install it on Windows Vista
Easy Media Creator 7 is not supported on Vista. Easy Media Creator 9 and above are only supported. Anything lower may be able to go onto Vista, but Tech Support is not going to be able to assist you if you have problems.
Jan 24, 2009 | Roxio Easy Media Creator 7
Error Message:Sonic Cineplayer Decoder Pack E:\7da4c.msi
This whole error code is a pal around back scratch between Roxio and Windows. To get rid of the "error message" which they created, you have to pay $70.00 for their crapp- axx software that is not even very good in the first place, Too bad Apple is not such junk and expensive, or I would change over. Thanks for really sticking it to us Microsoft!!!
Dec 19, 2008 | Roxio Easy Media Creator 9 Suite (227100)...
In my Roxio Easy Creator 10, I put together a picture slideshow with audio. At the completion of burning a disk I received an error message: 80045020 Error while recording Slideshow. What went wrong?
Im not so familiar with roxio but i suggest that you use Ulead Producer or any Ulead softwares and Nero for burning. it so easy to use and user friendly too. hope that helps
CHARCOIS
Nov 03, 2008 | Computers & Internet
Copying slideshow from hard drive to DVD
use nero 7 program u have just aint great used it dont ever do what u wann does it so use nero 7 8 ok so easy slide shows perfect quilty on dvd music dvd menu fr videos and slide shows cool icons back ground wallpapers best
Jan 21, 2008 | Roxio Easy CD & DVD Creator 6...
Computers & Internet Logo
216 people viewed this question
David Payne
David Payne
