Question about Intel D945GNT Motherboard
Hook-Up EZ-Swap2 removable hard drive rack to D945GNT MB
Reading the directions that came with the EZ-Swap2 removable hard drive rack it says - along with other instructions - "Connect the red and white HDD Access/Activity signal cable to the HDD signal pins on your system board."
Is this instruction saying to look for an extra set of pins somewhere on the board or will the set presently used by the internal HD be used by the removable rack activity indicator?
Maybe it's necessary to splice the wires so both can use the connector or maybe just not have the internal drive indicator function.
Thanks in advance, Tommy
  • 416 Answers
Red & white connector is for the Audio. yes. you will have to look forthe Audio connector on the motherboard.
more info for you
http://hi-techreviews.com/nuke/ezswap2/ezswap1.htm
Posted on Jan 15, 2009
Steering is sometimes hard to turn,sometimes you have to drive for 1 hour before this happens
Since the rack was replaced and it works initially you may have air in the lines. Try this: While in park remove the filler cap. Start vehicle and turn the steering wheel all the way I'm both directions several times. Replace the cap. If the problem persists, you may need to bleed the lines.
Apr 24, 2015 | 2004 Ford Escape
My computer won't power on after using backup now ez
when it is not compatible with the configuration of the computer,how can windows 7 be installed! you can reinstall the OS but only try xp if it is not compatible!
Apr 07, 2012 | NTI Backup Now EZ
My 4gb pan driv reading only 16 mb
This is because you pen drive is formatted to 16 Mb. So it will show only 16Mbs. To recover your 4Gb you have to partition it using a software.
Think this is helpful !
Aug 11, 2010 | SanDisk Computers & Internet
Motherboard LED on, board will not turn on.
Clicking noise!! If its a lil similar to the peeping sound it must be the RAM try removing the Ram and then cleaning the Slot maybe interchange the slots. If not i guess ur RAM's a goner.
May 20, 2010 | Intel D945GNT Motherboard
My external hard drive fell (simpledrive 1TB), he light comes on but my computers are not reading it.
had the same thing happen to me last year. does it still have a waranty on it. if it doesn't you can open it up hook it up to your computer directly get the stuff off it. not much else if the contacts are brocken you try to resoder them
Mar 22, 2010 | SimpleTech 1TB External USB 2.0 Hard Drive...
Intel motherboard D945GNT - which is the most compatible ram
According to Intel's site:
DDR2 667, DDR2 533, or DDR2 400 MHz SDRAM DIMMs
Jun 21, 2009 | Intel D945GNT Motherboard
PC w Intel D945GNT shut down suddenly, will not restart
Motherboard most likely blown, contact me on my support pages on http://www.motherboardsrus.net Use the email contact us button for more help. Chris, the computer doctor.
Jun 06, 2009 | Intel D945GNT Motherboard
Alienware Desktop will not boot
Try removing the RAM as well and see if it beeps...
Feb 11, 2009 | Intel D945GNT Motherboard
My External USB 250hard drive shows error Drive is not accessible
You most likely need to delete the partition on your external hard drive, then create a new one and format it again. You will lose the data on your external hard drive.
1. Go to the Control Panel, click on Administrative Tools, click on Computer Management, then Disk Management. (You will need Administrators rights to carry out the following tasks)
2. On the lower Right Panel select the External drive, this will be displayed as Disk 1, Right click on this drive (MAKE SURE YOU DON"T SELECT THE C: DRIVE which will be displayed as Disk 0)
and then Delete the partition.
3. This drive should then be Unallocated, Right Click on this drive and create a New Partition.
4. Then select Primary partition.
5. Check that the maxium disk size matches close to 240000(MB) you about 10+MB in the formating process
6. Click Assign the following drive letter (let the computer select this.
7. Chick Format the partition with the following settings
File System = NTFS
Allocatin unir size = Default
Volume label = "name of your choice eg. BACHUP DATA"
DON'T TICK Perform a quick format & Enable file & folder compression
8. Click Finish
Nov 27, 2008 | Western Digital 250GB MyBook External USB...
Playing mp3 songs on the ps3 --- 80gb
Whether you are hooking up your device through a USB cable or removable memory (SD card/Flash drive) the PS3 should recognize and play the titles. Here are a few steps to help you along.
1. Hook up device to your PS3
2. Select PS3 media icon where files files should be located
3. Press triangle button on controller
4. Sub menu will show up on side of screen
5. Select the 'display all' option
6. Files should now be accessable/loadable/playable
Playing files directly from the Mp3 player or loading them on the hard drive are both do-able and both methods should work.
Jan 13, 2008 | Sony Playstation 3 (PS3) Console
Intel D945GNT Motherboard Logo
384 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
