We need to remove the agitator to remove debris from under it. Please respond ASAP
    President:
  • 1,554 Answers
We were not able to respond because we do not know what to advise since the exact model number of the machine is not specified. Please explicitly indicate the exact model number of the machine. You don't have to accept or reject this post in order to add information or post comments and follow-up questions. But accepting a solution will not prevent you from communicating with the expert. You can still communicate with the expert at no further cost as long as you need assistance regarding the issue stated herein.
Posted on Nov 11, 2010
  • Jahn27
    Jahn27 Nov 11, 2010
    The agitator assembly can be removed usually by removing the stud that holds the agitator assembly to the drive shaft. Remove the agitator cap, the one that covers the top of the agitator assembly expose the stud under it. Remove the stud, usually 7/16", and the agitator assembly can be lifted out.
I need 2 know ASAP thank you
What is it you need to know? Your post is only you need to know asap under 48" Deck 23 Hp mowers. Please restate your question and I will try to respond.
Oct 01, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
2008 model number not found on selection list, model #nfw7200tw washer did not spin and drain out dirty water and complete rinse and spin dry cycle, tried to reset by manual instructions and it would...
Hi
It seems that something is stuck and you'll have to remove the agitator to clean it. If this is an old style washer, then it should have a bolt under the cap that must be removed to remove the agitator, then grab hold of the agitator and lift up. If it's a not too old then the agitator just pulls out, remove cap, if no bolt, just grab hold and lift it up hard... see the picture. Hope this helps...please post back for further assistance.
Daniel
Feb 05, 2011 | Amana Washing Machines
How to take agitator off
If the model number is correct, the agitator is removed by following these steps:
1. Using a flat blade screwdriver, pry up on the agitator center post cap and remove.
2. Under the agitator center post cap is a 7/16" hex bolt. Using a rachet and socket, remove the bolt and washer.
3. With the bolt removed, grasp the agitator on each side of the bottom flange at the bottom of the wash tub and lift straight up.
NOTE: Detergent can often leave soap deposits under the agitator and make it diffult to remove. You may have to rock the agitator from side to side a little to break it free.
If this is NOT your model number, please post back with your correct information. if you have questions, or need additional assistance, please post back and let me know. I hope this helps you.
Oct 13, 2010 | Roper RAK2751WWH Top Load Washer
Vaccum cleaner belt change
If you've put a new belt on and you still are getting a rubber smell, then odds are that your agitator (the rotating brush) is not turning freely, and that means either (a) you need to remove the end caps and remove any hair / debris that is under those end caps, or (2) the bearing(s) of the agitator are bad. Depending on the model of the Sharp (which was not provided), you may be able to order just the defective bearings and replace them (or take the agitator to a vacuum shop to have them do it), or you can (or may need to) order the agitator assembly complete.
May 05, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
A button has gone under the agitator. will this harm the pump
Most top loader machines have some sort of fastener in the center at the top of the agitator. You should look right at it when you open the lid. Once you figure out how you remove the fastener, the agitator should pull straight up. It is usually connected by a spline. You may have to pull pretty hard if it has never been apart. Once the agitator pulls out, you should be able to see the debris you are looking for.
I am not familiar with your exact machine, but yours should be similar. Hope this helps.
Jan 16, 2009 | Hoover Nextra HNT 2135 Top Load Washer
We have a kitchenaid model kaws850gq0 dont wash
dont reeally undserstand question, you can freely turn the agitator freely, in both directions??? with no resistance??? if so you need to replsce the agitator dogs, part number 80040, probly under $20, to replace youll need to remove the agitator form the tub( 7/16 bolt under the fabric softener cup "pop" it off with the palm of your hand!
Dec 08, 2008 | KitchenAid KAWS850L Top Load Washer
Agitator not working properly
This is a fairly simple process. Just follow these steps:
1. Remove dispenser cap by pulling off.
2. Under the dispenser cap is another plastic cap with a washer. Pull this out to expose the agitator bolt underneath.
3. Using a socket and rachet (easiest method) remove agitator bolt and remove entire agitator by pulling from the bottom flanges and lifting straight up.
If you go to searspartsdirect.com and type in your model number, there's an excellent drawing of your agitator and components under the "Agitator, Basket and Tub" heading. Use this as a reference for reinstalling any parts.
I hope this helps you. If you still require assistance, please let me know.
Aug 25, 2008 | Whirlpool Washing Machines
Changing out memory
On that model, the memory is under the keyboard.
Here is a good tutorial on disassembly:
Although this tutorial is for hinge replacement, you will see the memory under the keyboard in step 17.
http://www.irisvista.com/tech/laptops/ToshibaA45/Satellite-A45-remove-hinges-1.htm
Feb 11, 2008 | Toshiba A45-S121 Notebook
Fridgidaire gallery
From the sounds of things, you are talking about a front loading dryer. The agitators in the dryer can get coins stuck inside them. Remove the top and rotate the drum to reveal the screws which hold the agitators to the drum. Remove the screws and the agitators, empty the coins or other debris and reinstall.
The loud squeal sounds like the pad under the open side of the drum is worn out. There may also be a dry main bearing in the rear of the dryer. Lubricate the bearing and reinstall the drum. The squeal should disappear.
If this is not a dryer or a front loading washer, none of these suggestions will apply, Sorry
Feb 08, 2008 | Washing Machines
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
